查看: 6698|回復(fù): 6
各種BGA及芯片PCB封裝
ID:224275 發(fā)表于 2017-8-3 10:07 | 顯示全部樓層 |閱讀模式
非常全的PCB封裝!!
Axial Lead Diode.PcbLib
BGA (0.8mm Pitch, Square).PcbLib
BGA (1.0mm Pitch, Square1).PcbLib
BGA (1.0mm Pitch, Square2).PcbLib
BGA (1.0mm Pitch, Square3).PcbLib
BGA (1.0mm Pitch, Square4).PcbLib
BGA (1.0mm Pitch, Square5).PcbLib
BGA (1.0mm Pitch, Square6).PcbLib
BGA (1.27mm Pitch, Square1).PcbLib
BGA (1.27mm Pitch, Square2).PcbLib
BGA (1.27mm Pitch, Square3).PcbLib
BGA (1.27mm Pitch, Square4).PcbLib
BGA (1.27mm Pitch, Square5).PcbLib
BGA (1.5mm Pitch, Square1).PcbLib
BGA (1.5mm Pitch, Square2).PcbLib
BGA (1.5mm Pitch, Square3).PcbLib
BGA (1.5mm Pitch, Square4).PcbLib
BGA (~0.6mm Pitch, Square).PcbLib
BGA - Rectangle.PcbLib
Bridge Rectifier.PcbLib
Bumpered QFP - Centre Index.PcbLib
Bumpered QFP - Corner Index.PcbLib
CAN - Circle pin arrangement.PcbLib
CAN - Rectangle pin arrangement.PcbLib
Capacitor Electrolytic Mount Ring.PcbLib
Capacitor Electrolytic Snap-In.PcbLib
Capacitor Non-Polar Axial.PcbLib
Capacitor Non-Polar Dipped Radial.PcbLib
Capacitor Non-Polar Disc.PcbLib
Capacitor Non-Polar Tubular.PcbLib
Capacitor Polar Axial.PcbLib
Capacitor Polar Radial Cylinder.PcbLib
Capacitor Tantalum Leadless.PcbLib
Capacitor Tantalum Radial Bead.PcbLib
Capacitor Tantalum Radial Oval.PcbLib
Capacitor Tantalum Radial Rectangle.PcbLib
CCGA - Square.PcbLib
Ceramic DFP.PcbLib
Ceramic QFP (Square).PcbLib
Chip Capacitor - 2 Contacts.PcbLib
Chip Diode - 2 Contacts.PcbLib
Chip Inductor - 2 Contacts.PcbLib
Chip Resistor - 2 Contacts.PcbLib
Chip Resistor Array - Panasonic.PcbLib
Con 050 DSubminiature.PcbLib
Con Audio.PcbLib
Con CardEdge.PcbLib
Con CompactPCI.PcbLib
Con DIN Circular.PcbLib
Con Docking Station.PcbLib
Con FPC-FFC.PcbLib
Con High-Speed PCB.PcbLib
Con IDC.PcbLib
Con IEEE1394.PcbLib
Con Mains Power.PcbLib
Con Mod Jack PCB.PcbLib
Con Rect Stag PCB.PcbLib
Con RF Coaxial.PcbLib
Con USB.PcbLib
Contents_390805.txt
Crystal Oscillator.PcbLib
Cylinder with Flat Index.PcbLib
D-PAK.PcbLib
Diamond Base CAN - 2 Leads.PcbLib
Diamond Base CAN - 3+ Leads.PcbLib
DIP - LED Display.PcbLib
DIP - Peg Leads.PcbLib
DIP, Modified - Trimmed Leads.PcbLib
DIP, Shrink - Stub Leads.PcbLib
Dual-In-Line Package.PcbLib
Flange Mount with Rectangular Base.PcbLib
FQFP (0.3mm Pitch, Square) - Corner Index.PcbLib
FQFP (0.4mm Pitch, Square) - Corner Index.PcbLib
FQFP (0.5mm Pitch, Square) - Corner Index.PcbLib
FQFP - Rectangle.PcbLib
Horizontal, Flange Mount with Tab.PcbLib
Leaded Chip Carrier (Square) - Centre Index.PcbLib
Leaded Chip Carrier - Rectangle.PcbLib
Leadless Chip Carrier - Rectangle.PcbLib
Leadless Chip Carrier - Square.PcbLib
Log390805.txt
Low Profile Module (LPM).PcbLib
MELF - Diode.PcbLib
MELF - Resistor.PcbLib
Miscellaneous Connector PCB.PcbLib
Miscellaneous Devices PCB.PcbLib
Miscellaneous.PcbLib
Pin Grid Array Package (PGA).PcbLib
QFP (~0.6mm Pitch, Square) - Centre Index.PcbLib
QFP (~0.6mm Pitch, Square) - Corner Index.PcbLib
QFP (~0.8mm Pitch, Square) - Corner Index.PcbLib
Quad Flat No Lead Square.PcbLib
Quad In-Line Package (QUIP).PcbLib
Resistor - Axial.PcbLib
Shrink Small Outline (~0.6mm Pitch).PcbLib
Single In-Line with Mounting Hole.PcbLib
Single In-Line with no Mounting Hole.PcbLib
Single-In-Line Package - 5+ Leads.PcbLib
Small Outline (+1.27mm Pitch).PcbLib
Small Outline (~0.8mm Pitch).PcbLib
Small Outline (~1.27mm Pitch) - 22+ Leads.PcbLib
Small Outline (~1.27mm Pitch) - 6to20 Leads.PcbLib
Small Outline Diode - 2 C-Bend Leads.PcbLib
Small Outline Diode - 2 Flat Leads.PcbLib
Small Outline Diode - 2 Gullwing Leads.PcbLib
Small Outline Diode - 2 Yoke Leads.PcbLib
Small Outline Diode - 2 Z-Bend Leads.PcbLib
Small Outline Diode - 3+ Flat Leads.PcbLib
Small Outline with C-Bend Leads.PcbLib
Small Outline with J Leads.PcbLib
SOT - 3 Flat Leads.PcbLib
SOT 143.PcbLib
SOT 223.PcbLib
SOT 23 - 5 and 6 Leads.PcbLib
SOT 23.PcbLib
SOT 343.PcbLib
SOT 89.PcbLib
TSOP (0.4mm Pitch).PcbLib
TSOP (0.5mm Pitch).PcbLib
TSOP (~0.6mm Pitch).PcbLib
Vertical, Dual-Row, Flange Mount with Tab.PcbLib
Vertical, Single-Row, Flange Mount with Tab.PcbLib
Zig-Zag-In-Line Package Odd Lead Number.PcbLib
Zig-Zag-In-Line Package, Even Lead Number.PcbLib
全部資料下載地址:
fgnfg.zip (2.49 MB, 下載次數(shù): 103)
ID:289699 發(fā)表于 2018-3-9 16:01 | 顯示全部樓層
你好,能不能發(fā)郵箱。謝謝,幣不夠 506152091@QQ.COM
ID:88868 發(fā)表于 2018-8-21 11:16 | 顯示全部樓層
感謝分享。。。。。。。。。。。。。。。
ID:406027 發(fā)表于 2018-10-7 09:40 | 顯示全部樓層
感謝分享。
ID:640016 發(fā)表于 2019-11-11 20:56 | 顯示全部樓層
感謝樓主的無(wú)私分享!
ID:640016 發(fā)表于 2019-11-11 23:20 | 顯示全部樓層
好資料,感謝樓主無(wú)私分享
ID:611216 發(fā)表于 2020-1-29 16:48 | 顯示全部樓層
感謝分享
