查看: 1734|回復(fù): 0
基于C52關(guān)于AD代碼
ID:225501 發(fā)表于 2017-8-7 15:52 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
* AD PCF8591
* Dy×aμçλÆ÷£¬′®¿úÖúêÖ½«êÕμ½2»í¬μÄêy¾Y
#include <reg51.h>
#include <intrins.h>
typedef unsigned char uint8;
typedef unsigned int uint16;
#define SLAVEADDR  0x90                 //¶¨òåÆ÷¼tμØÖ·
#define nops()  do{_nop_();_nop_();_nop_();_nop_();_nop_();} while(0) //¶¨òå¿ÕÖ¸áî
sbit SCL = P2^1;       //I2C  ê±Öó
sbit SDA = P2^0;       //I2C  êy¾Y
sbit DS1302 = P2^4;
void delay(uint16 n)
        while (n--);
* oˉêy: i2c_start()
* 1|Äü: Æô¶ˉi2c                  Æeê¼DÅoÅ
void i2c_start()
        SCL = 1;
        nops();
        SDA = 1;
        nops();
        SDA = 0;
        nops();
        SCL = 0;
* oˉêy: i2c_stop()
* 1|Äü: í£Ö1i2c
void i2c_stop()
        SCL = 0;
        nops();
        SDA = 0;
        nops();
        SCL = 1;
        nops();
        SDA = 1;
        nops();
* oˉêy: i2c_ACK(bit ck)
* 1|Äü: ckÎa1ê±·¢Ëíó|′eDÅoÅACK,
*       ckÎa0ê±2»·¢ËíACK
void i2c_ACK(bit ck)
    if (ck)
                SDA = 0;
                SDA = 1;
    nops();
    SCL = 1;
    nops();
    SCL = 0;
        nops();
    SDA = 1;
    nops();
* oˉêy: i2c_waitACK()
* 1|Äü: ·μ»ØÎa0ê±êÕμ½ACK
*       ·μ»ØÎa1ê±Ã»êÕμ½ACK
bit i2c_waitACK()
        SDA = 1;
        nops();
        SCL = 1;
        nops();
        if (SDA)
                SCL = 0;
                i2c_stop();
                return 1;
                SCL = 0;
                return 0;
* oˉêy: i2c_sendbyte(uint8 bt)
* 1|Äü: ½«êäèëμÄò»×Ö½úêy¾Ybt·¢Ëí
void i2c_sendbyte(uint8 bt)
    uint8 i;
    for(i=0; i<8; i++)
        if (bt & 0x80)
                        SDA = 1;
                        SDA = 0;
        nops();
        SCL = 1;
        bt <<= 1;
        nops();
        SCL = 0;
* oˉêy: i2c_recbyte( )
* 1|Äü: ′ó×üÏßéϽóêÕ1×Ö½úêy¾Y
uint8 i2c_recbyte()
        uint8 dee, i;
        for (i=0; i<8; i++)
                SCL = 1;
                nops();
                dee <<= 1;
                if (SDA)
                        dee = dee | 0x01;
                SCL = 0;
                nops();
        return dee;
* oˉêy: i2c_readbyte
* êäèë: addr
* 1|Äü: ¶á3öò»×Ö½úêy¾Y
* ·μ»ØÖμ: 0->3é1|  1->ê§°ü
bit i2c_readbyte(uint8 com, uint8 *dat)
        i2c_start();
        i2c_sendbyte(SLAVEADDR);    //μØÖ·
    if (i2c_waitACK())
                return 1;
        i2c_sendbyte(com);        //¿ØÖÆ×Ö½ú
    if (i2c_waitACK())
                return 1;
        i2c_start();
        i2c_sendbyte(SLAVEADDR+1); //μØÖ·
    if (i2c_waitACK())
                return 1;
        *dat = i2c_recbyte();      //¶áêy¾Y
        i2c_ACK(0);                //òòÎaÖ»¶áò»×Ö½úêy¾Y£¬2»·¢ËíACKDÅoÅ
        i2c_stop();
        return 0;
* UART3õê¼»ˉ
* 2¨ìØÂê£o9600
void uart_init(void)
    ET1=0;
    TMOD = 0x21;        // ¶¨ê±Æ÷11¤×÷Ôú·½ê½2£¨×Ô¶ˉ֨װ£©
    SCON = 0x50;        // 10λuart£¬ÔêDí′®DD½óêü
    TH1 = 0xFD;
    TL1 = 0xFD;
    TR1 = 1;
* UART ·¢Ëíò»×Ö½ú
void UART_Send_Byte(uint8 dat)
        SBUF = dat;
        while (TI == 0);
        TI = 0;
main()
        uint8 ans;
        uart_init();
        DS1302 = 0;
                i2c_readbyte(0x42, &ans);
                UART_Send_Byte(ans);
                delay(50000);
