最小陀螺儀資料
stm32單片機源程序如下:
- #include "main.h"
- //定義MPU6050內(nèi)部地址
- #define SMPLRT_DIV 0x19 //陀螺儀采樣率 典型值 0X07 125Hz
- #define CONFIG 0x1A //低通濾波頻率 典型值 0x00
- #define GYRO_CONFIG 0x1B //陀螺儀自檢及測量范圍 典型值 0x18 不自檢 2000deg/s
- #define ACCEL_CONFIG 0x1C //加速度計自檢及測量范圍及高通濾波頻率 典型值 0x01 不自檢 2G 5Hz
- #define INT_PIN_CFG 0x37
- #define INT_ENABLE 0x38
- #define INT_STATUS 0x3A //只讀
- #define ACCEL_XOUT_H 0x3B
- #define ACCEL_XOUT_L 0x3C
- #define ACCEL_YOUT_H 0x3D
- #define ACCEL_YOUT_L 0x3E
- #define ACCEL_ZOUT_H 0x3F
- #define ACCEL_ZOUT_L 0x40
- #define TEMP_OUT_H 0x41
- #define TEMP_OUT_L 0x42
- #define GYRO_XOUT_H 0x43
- #define GYRO_XOUT_L 0x44
- #define GYRO_YOUT_H 0x45
- #define GYRO_YOUT_L 0x46
- #define GYRO_ZOUT_H 0x47
- #define GYRO_ZOUT_L 0x48
- #define PWR_MGMT_1 0x6B //電源管理 典型值 0x00 正常啟用
- #define WHO_AM_I 0x75 //只讀 默認讀出應(yīng)該是 MPU6050_ID = 0x68
- #define MPU6050_ID 0x68
- #define MPU6050_DEVICE_ADDRESS 0xD0
- #define MPU6050_DATA_START ACCEL_XOUT_H //由于數(shù)據(jù)存放地址是連續(xù)的,所以一并讀出
- MPU6050_RAW_DATA MPU6050_Raw_Data;
- MPU6050_REAL_DATA MPU6050_Real_Data;
- int gyroADC_X_offset=0,gyroADC_Y_offset=0,gyroADC_Z_offset=0;
- //MPU6050 初始化,成功返回0 失敗返回 0xff
- int MPU6050_Initialization(void)
- unsigned char temp_data = 0x00;
- IIC_GPIO_Init(); //初始化IIC接口
- HEAT_Configuration();
- if(IIC_ReadData(MPU6050_DEVICE_ADDRESS,WHO_AM_I ,&temp_data ,1)==0) //確定IIC總線上掛接的是否是MPU6050
- if(temp_data != MPU6050_ID)
- printf("error 1A\r\n");
- return 0xff; //校驗失敗,返回0xff
- else
- printf("error 1B\r\n");
- return 0xff; //讀取失敗 返回0xff
- if(IIC_WriteData(MPU6050_DEVICE_ADDRESS,PWR_MGMT_1,0x01) == 0xff) //解除休眠狀態(tài)
- printf("error 1C\r\n");
- return 0xff;
- if(IIC_WriteData(MPU6050_DEVICE_ADDRESS,SMPLRT_DIV,0x07) == 0xff)//cyq:07 更新頻率1khz
- printf("error 1D\r\n");
- return 0xff;
- if(IIC_WriteData(MPU6050_DEVICE_ADDRESS,CONFIG,0x00) == 0xff)
- printf("error 1E\r\n");
- return 0xff;
- if(IIC_WriteData(MPU6050_DEVICE_ADDRESS,GYRO_CONFIG,0x08) == 0xff)
- printf("error 1F\r\n");
- return 0xff;
- if(IIC_WriteData(MPU6050_DEVICE_ADDRESS,ACCEL_CONFIG,0x08) == 0xff)
- printf("error 1G\r\n");
- return 0xff;
- if(IIC_WriteData(MPU6050_DEVICE_ADDRESS,INT_PIN_CFG,0x00) == 0xff)
- printf("error 1H\r\n");
- return 0xff;
- if(IIC_WriteData(MPU6050_DEVICE_ADDRESS,INT_ENABLE,0x01) == 0xff)
- printf("error 1I\r\n");
- return 0xff;
- //MPU6050_Interrupt_Configuration(); //MPU6050中斷初始化
- return 0;
- //MPU6050 數(shù)據(jù)讀取,成功返回0 失敗返回 0xff
- int MPU6050_ReadData(void)
- u8 buf[14];
- if(IIC_ReadData(MPU6050_DEVICE_ADDRESS,MPU6050_DATA_START,buf,14) == 0xff)
- printf("error 1J\r\n");
- return 0xff;
- else
- //讀取寄存器原生數(shù)據(jù)
- MPU6050_Raw_Data.Accel_X = (buf[0]<<8 | buf[1]);
- MPU6050_Raw_Data.Accel_Y = (buf[2]<<8 | buf[3]);
- MPU6050_Raw_Data.Accel_Z = (buf[4]<<8 | buf[5]);
- MPU6050_Raw_Data.Temp = (buf[6]<<8 | buf[7]);
- MPU6050_Raw_Data.Gyro_X = (buf[8]<<8 | buf[9]);
- MPU6050_Raw_Data.Gyro_Y = (buf[10]<<8 | buf[11]);
- MPU6050_Raw_Data.Gyro_Z = (buf[12]<<8 | buf[13]);
- //將原生數(shù)據(jù)轉(zhuǎn)換為實際值,計算公式跟寄存器的配置有關(guān)
- MPU6050_Real_Data.Accel_X = (float)(MPU6050_Raw_Data.Accel_X)/8192.0; //見datasheet 30 of 47
- MPU6050_Real_Data.Accel_Y = (float)(MPU6050_Raw_Data.Accel_Y)/8192.0; //見datasheet 30 of 47
- MPU6050_Real_Data.Accel_Z = (float)(MPU6050_Raw_Data.Accel_Z)/8192.0; //見datasheet 30 of 47
- MPU6050_Real_Data.Temp = (float)(MPU6050_Raw_Data.Temp)/340.0+36.53;//見datasheet 31 of 47
- MPU6050_Real_Data.Gyro_X = (float)(MPU6050_Raw_Data.Gyro_X - gyroADC_X_offset)/65.5; //見datasheet 32 of 47
- MPU6050_Real_Data.Gyro_Y = (float)(MPU6050_Raw_Data.Gyro_Y - gyroADC_Y_offset)/65.5; //見datasheet 32 of 47
- MPU6050_Real_Data.Gyro_Z = (float)(MPU6050_Raw_Data.Gyro_Z - gyroADC_Z_offset)/65.5; //見datasheet 32 of 47
- return 0;
- void MPU6050_Gyro_calibration(void)
- u16 i;
- float x_temp=0,y_temp=0,z_temp=0;
最小陀螺儀.zip
(6.85 MB, 下載次數(shù): 63)
2017-8-9 13:53 上傳
點擊文件名下載附件
