查看: 2023|回復(fù): 0
51驅(qū)動(dòng)6050,好不容易找到的。
ID:226157 發(fā)表于 2017-8-9 15:41 | 顯示全部樓層 |閱讀模式
#include <REG52.H>
#include <math.h>    //Keil library
#include <stdio.h>   //Keil library
#include <INTRINS.H>
typedef unsigned char  uchar;
typedef unsigned short ushort;
typedef unsigned int   uint;
// 定義51單片機(jī)端口
#define DataPort P2     //LCD1602數(shù)據(jù)端口
sbit    SCL=P3^0;           //IIC時(shí)鐘引腳定義
sbit    SDA=P3^1;           //IIC數(shù)據(jù)引腳定義
sbit    LCM_RS=P0^7;    //LCD1602命令端口
sbit    LCM_RW=P0^6;    //LCD1602命令端口
sbit    LCM_EN=P0^5;    //LCD1602命令端口
// 定義MPU6050內(nèi)部地址
#define SMPLRT_DIV      0x19    //陀螺儀采樣率,典型值:0x07(125Hz)
#define CONFIG              0x1A    //低通濾波頻率,典型值:0x06(5Hz)
#define GYRO_CONFIG     0x1B    //陀螺儀自檢及測(cè)量范圍,典型值:0x18(不自檢,2000deg/s)
#define ACCEL_CONFIG    0x1C    //加速計(jì)自檢、測(cè)量范圍及高通濾波頻率,典型值:0x01(不自檢,2G,5Hz)
#define ACCEL_XOUT_H    0x3B
#define ACCEL_XOUT_L    0x3C
#define ACCEL_YOUT_H    0x3D
#define ACCEL_YOUT_L    0x3E
#define ACCEL_ZOUT_H    0x3F
#define ACCEL_ZOUT_L    0x40
#define TEMP_OUT_H      0x41
#define TEMP_OUT_L      0x42
#define GYRO_XOUT_H     0x43
#define GYRO_XOUT_L     0x44
#define GYRO_YOUT_H     0x45
#define GYRO_YOUT_L     0x46
#define GYRO_ZOUT_H     0x47
#define GYRO_ZOUT_L     0x48
#define PWR_MGMT_1      0x6B    //電源管理,典型值:0x00(正常啟用)
#define WHO_AM_I            0x68   //IIC地址寄存器(默認(rèn)數(shù)值0x68,只讀)
#define SlaveAddress    0xD0    //IIC寫入時(shí)的地址字節(jié)數(shù)據(jù),+1為讀取
//定義類型及變量
uchar dis[4];                           //顯示數(shù)字(-511至512)的字符數(shù)組
int dis_data;                       //變量
//int   Temperature,Temp_h,Temp_l;  //溫度及高低位數(shù)據(jù)
//函數(shù)聲明
void  delay(unsigned int k);                                        //延時(shí)
//LCD相關(guān)函數(shù)
void  InitLcd();                                                        //初始化lcd1602
void  lcd_printf(uchar *s,int temp_data);
void  WriteDataLCM(uchar dataW);                                    //LCD數(shù)據(jù)
void  WriteCommandLCM(uchar CMD,uchar Attribc);             //LCD指令
void  DisplayOneChar(uchar X,uchar Y,uchar DData);          //顯示一個(gè)字符
void  DisplayListChar(uchar X,uchar Y,uchar *DData,L);  //顯示字符串
//MPU6050操作函數(shù)
void  InitMPU6050();                                                    //初始化MPU6050
void  Delay5us();
void  I2C_Start();
void  I2C_Stop();
void  I2C_SendACK(bit ack);
bit   I2C_RecvACK();
void  I2C_SendByte(uchar dat);
uchar I2C_RecvByte();
void  I2C_ReadPage();
void  I2C_WritePage();
void  display_ACCEL_x();
void  display_ACCEL_y();
void  display_ACCEL_z();
uchar Single_ReadI2C(uchar REG_Address);                        //讀取I2C數(shù)據(jù)
void  Single_WriteI2C(uchar REG_Address,uchar REG_data);    //向I2C寫入數(shù)據(jù)
//整數(shù)轉(zhuǎn)字符串
    if(temp_data<0)
        temp_data=-temp_data;
        *s='-';
    else *s=' ';
    *++s =temp_data/100+0x30;
    temp_data=temp_data%100;     //取余運(yùn)算
    *++s =temp_data/10+0x30;
    temp_data=temp_data%10;      //取余運(yùn)算
    *++s =temp_data+0x30;
//延時(shí)
    unsigned int i,j;
    for(i=0;i<k;i++)
        for(j=0;j<121;j++);
//LCD1602初始化
void InitLcd()
    WriteCommandLCM(0x38,1);
    WriteCommandLCM(0x08,1);
    WriteCommandLCM(0x01,1);
    WriteCommandLCM(0x06,1);
    WriteCommandLCM(0x0c,1);
    DisplayOneChar(0,0,'A');
    DisplayOneChar(0,1,'G');
//LCD1602寫允許
void WaitForEnable(void)
    DataPort=0xff;
    LCM_RS=0;LCM_RW=1;_nop_();
    LCM_EN=1;_nop_();_nop_();
    while(DataPort&0x80);
    LCM_EN=0;
//LCD1602寫入命令
    if(Attribc)WaitForEnable();
    LCM_RS=0;LCM_RW=0;_nop_();
    DataPort=CMD;_nop_();
    LCM_EN=1;_nop_();_nop_();LCM_EN=0;
//LCD1602寫入數(shù)據(jù)
    WaitForEnable();
    LCM_RS=1;LCM_RW=0;_nop_();
    DataPort=dataW;_nop_();
//LCD1602寫入一個(gè)字符
    Y&=1;
    X&=15;
    if(Y)X|=0x40;
    X|=0x80;
    WriteCommandLCM(X,0);
    WriteDataLCM(DData);
//LCD1602顯示字符串
    uchar ListLength=0;
    Y&=0x1;
    X&=0xF;
    while(L--)
        DisplayOneChar(X,Y,DData[ListLength]);
        ListLength++;
        X++;
//延時(shí)5微秒(STC90C52RC@12M)
//不同的工作環(huán)境,需要調(diào)整此函數(shù)
//當(dāng)改用1T的MCU時(shí),請(qǐng)調(diào)整此延時(shí)函數(shù)
void Delay5us()
    _nop_();_nop_();_nop_();_nop_();
//I2C起始信號(hào)
void I2C_Start()
    SDA = 1;                    //拉高數(shù)據(jù)線
    SCL = 1;                    //拉高時(shí)鐘線
    Delay5us();                 //延時(shí)
    SDA = 0;                    //產(chǎn)生下降沿
    SCL = 0;                    //拉低時(shí)鐘線
//I2C停止信號(hào)
void I2C_Stop()
    SDA = 0;                    //拉低數(shù)據(jù)線
    SDA = 1;                    //產(chǎn)生上升沿
//I2C發(fā)送應(yīng)答信號(hào)
//入口參數(shù):ack (0:ACK 1:NAK)
    SDA = ack;                  //寫應(yīng)答信號(hào)
//I2C接收應(yīng)答信號(hào)
bit I2C_RecvACK()
    CY = SDA;                   //讀應(yīng)答信號(hào)
    return CY;
//向I2C總線發(fā)送一個(gè)字節(jié)數(shù)據(jù)
    uchar i;
    for (i=0; i<8; i++)         //8位計(jì)數(shù)器
        dat <<= 1;              //移出數(shù)據(jù)的最高位
        SDA = CY;               //送數(shù)據(jù)口
    I2C_RecvACK();
//從I2C總線接收一個(gè)字節(jié)數(shù)據(jù)
    uchar i;
    uchar dat = 0;
    SDA = 1;                    //使能內(nèi)部上拉,準(zhǔn)備讀取數(shù)據(jù),
        dat <<= 1;
        dat |= SDA;             //讀數(shù)據(jù)
    return dat;
//向I2C設(shè)備寫入一個(gè)字節(jié)數(shù)據(jù)
    I2C_Start();                  //起始信號(hào)
    I2C_SendByte(SlaveAddress);   //發(fā)送設(shè)備地址+寫信號(hào)
    I2C_SendByte(REG_Address);    //內(nèi)部寄存器地址,
    I2C_SendByte(REG_data);       //內(nèi)部寄存器數(shù)據(jù),
    I2C_Stop();                   //發(fā)送停止信號(hào)
//從I2C設(shè)備讀取一個(gè)字節(jié)數(shù)據(jù)
    uchar REG_data;
    I2C_SendByte(REG_Address);     //發(fā)送存儲(chǔ)單元地址,從0開始
    I2C_SendByte(SlaveAddress+1);  //發(fā)送設(shè)備地址+讀信號(hào)
    REG_data=I2C_RecvByte();       //讀出寄存器數(shù)據(jù)
    I2C_SendACK(1);                //接收應(yīng)答信號(hào)
    I2C_Stop();                    //停止信號(hào)
    return REG_data;
//初始化MPU6050
void InitMPU6050()
    Single_WriteI2C(PWR_MGMT_1, 0x00);  //解除休眠狀態(tài)
    Single_WriteI2C(SMPLRT_DIV, 0x07);
    Single_WriteI2C(CONFIG, 0x06);
    Single_WriteI2C(GYRO_CONFIG, 0x18);
    Single_WriteI2C(ACCEL_CONFIG, 0x01);
//合成數(shù)據(jù)
int GetData(uchar REG_Address)
    char H,L;
    H=Single_ReadI2C(REG_Address);
    L=Single_ReadI2C(REG_Address+1);
    return (H<<8)+L;   //合成數(shù)據(jù)
//在1602上顯示10位數(shù)據(jù)
void Display10BitData(int value,uchar x,uchar y)
    value/=64;                                  //轉(zhuǎn)換為10位數(shù)據(jù)
    lcd_printf(dis, value);         //轉(zhuǎn)換數(shù)據(jù)顯示
    DisplayListChar(x,y,dis,4); //啟始列,行,顯示數(shù)組,顯示長(zhǎng)度
//主程序
    delay(500);     //上電延時(shí)
    InitLcd();      //液晶初始化
    delay(150);
        Display10BitData(GetData(ACCEL_XOUT_H),2,0);    //顯示X軸加速度
        Display10BitData(GetData(ACCEL_YOUT_H),7,0);    //顯示Y軸加速度
        Display10BitData(GetData(ACCEL_ZOUT_H),12,0);   //顯示Z軸加速度
        Display10BitData(GetData(GYRO_XOUT_H),2,1);     //顯示X軸角速度
        Display10BitData(GetData(GYRO_YOUT_H),7,1);     //顯示Y軸角速度
        Display10BitData(GetData(GYRO_ZOUT_H),12,1);    //顯示Z軸角速度
        delay(500);
