查看: 12879|回復(fù): 14
單片機按鍵&串口控制步進電機正反轉(zhuǎn)調(diào)速含程序和仿真
ID:163705 發(fā)表于 2017-8-11 08:40 | 顯示全部樓層 |閱讀模式
        包含程序和仿真
        功能:按鍵或串口發(fā)送字符指令,控制步進電機正轉(zhuǎn)、反轉(zhuǎn)、停止、加速、減速動作
    仿真過程可直接通過按下電腦鍵盤控制
單片機源程序如下:
  1. #include<reg52.h>
  2. #define uint  unsigned int
  4. //------8拍-----
  5. uchar code zz[]={0x01,0x03,0x02,0x06,0x04,0x0c,0x08,0x09};                        //正轉(zhuǎn)
  6. uchar code fz[]={0x09,0x08,0x0c,0x04,0x06,0x02,0x03,0x01};                        //反轉(zhuǎn)
  7. sbit K1=P3^0;        //停止
  8. sbit K2=P3^1;        //正轉(zhuǎn)
  9. sbit K3=P3^2;        //反轉(zhuǎn)
  10. sbit K4=P3^3;        //加速
  11. sbit K5=P3^4;        //減速
  12. uchar state=0;        //狀態(tài)變量
  13. uint Time=60;         //延時時間,用于調(diào)速
  14. unsigned char receiveData='0';
  15. void UsartConfiguration();           //初始化串口
  16. void delay(uint ms)                           //延時,用于調(diào)速
  17. {
  18.         uint t;
  19.         while(ms--)
  20.                 for(t=0;t<120;t++);
  21. }
  22. void motor_zz()                  //正傳函數(shù)
  23. {
  24.         uint j;
  25.         for(j=0;j<8;j++)
  26.         {
  27.                 if(P3==0xfb)
  28.                         break;
  29.                 P1=zz[j];
  30.                 delay(Time);
  31.         }
  32. }
  33. void motor_fz()                  //反轉(zhuǎn)函數(shù)
  34. {
  35.         uint j;
  36.         for(j=0;j<8;j++)
  37.         {
  38.                 if(P3==0xfb)
  39.                         break;
  40.                 P1=fz[j];
  41.                 delay(Time);
  42.         }
  43. }
  44. void main()
  45. {
  46.         UsartConfiguration();
  47.         while(1)
  48.         {
  49.                 while(state==0)                        //狀態(tài)0,停止
  50.                 {
  51.                         if((K2==0)||(receiveData=='z'))           //按下K2或串口接收到'z',電機正轉(zhuǎn)
  52.                         {
  53.                                 state=1;
  54.                                 receiveData='0';
  55.                                 break;
  56.                         }
  57.                         if((K3==0)||(receiveData=='f'))           //按下K3或串口接收到'f',電機反轉(zhuǎn)
  58.                         {
  59.                                 state=2;
  60.                                 receiveData='0';
  61.                                 break;
  62.                         }
  63.                         P0=0xfb;
  64.                         P1=0x03;
  65.                 }
  66.
  67.                 while(state==1)                        //狀態(tài)1,正轉(zhuǎn)
  68.                 {
  69.                         if((K1==0)||(receiveData=='t'))           //按下K1或串口接收到'f',電機反轉(zhuǎn)
  70.                         {
  71.                                 state=0;
  72.                                 receiveData='0';
  73.                                 break;
  74.                         }
  75.                         if((K2==0)||(receiveData=='z'))                //按下K2或串口接收到'z',電機正轉(zhuǎn)
  76.                         {
  77.                                 state=1;
  78.                                 receiveData='0';
  79.                                 break;
  80.                         }
  81.                         if((K3==0)||(receiveData=='f'))                //按下K3或串口接收到'f',電機反轉(zhuǎn)
  82.                         {
  83.                                 state=2;
  84.                                 receiveData='0';
  85.                                 break;
  86.                         }
  87.                         if((K4==0)||(receiveData=='+'))                //按下K4或串口接收到'+',電機加速
  88.                         {
  89.                                 Time=Time-5;
  90.                                 if(Time<20)
  91.                                 Time=20;
  92.                                 while(K4==0);
  93.                         }
  94.                         if((K5==0)||(receiveData=='-'))                //按下K5或串口接收到'-',電機減速
  95.                         {
  96.                                 Time=Time+5;
  97.                                 if(Time>100)
  98.                                 Time=100;
  99.                                 while(K5==0);
  100.                         }
  101.                         motor_zz();                 //狀態(tài)1,正轉(zhuǎn)
  102.                 }
  103.                 while(state==2)                   //狀態(tài)2,反轉(zhuǎn)
  104.                 {
  105.                         if((K1==0)||(receiveData=='t'))                 //按下K1或串口接收到'f',電機反轉(zhuǎn)
  106.                         {
  107.                                 state=0;
  108.                                 receiveData='0';
  109.                                 break;
  110.                         }
  111.                         if((K2==0)||(receiveData=='z'))                 //按下K2或串口接收到'z',電機正轉(zhuǎn)
  112.                         {
  113.                                 state=1;
  114.                                 receiveData='0';
  115.                                 break;
  116.                         }
  117.                         if((K3==0)||(receiveData=='f'))                  //按下K3或串口接收到'f',電機反轉(zhuǎn)
  118.                         {
  119.                                 state=2;
  120.                                 receiveData='0';
  121.                                 break;
  122.                         }
  123.                         if((K4==0)||(receiveData=='+'))                   //按下K4或串口接收到'+',電機加速
  124.                         {
  125.                                 Time=Time-5;
  126.                                 if(Time<20)
  127.                                 Time=20;
  128.                                 while(K4==0);
  129.                         }
  130.                         if((K5==0)||(receiveData=='-'))                   //按下K5或串口接收到'-',電機減速
  131.                         {
  132.                                 Time=Time+5;
  133.                                 if(Time>100)
  134.                                 Time=100;
  135.                                 while(K5==0);
  136.                         }
  137.                         motor_fz();                //狀態(tài)2,反轉(zhuǎn)
  138.                 }
  139.         }
  140. }
  141. /************************************************************************
  142. * 函數(shù)名         :UsartConfiguration()
  143. * 函數(shù)功能                   :設(shè)置串口
  144. * 輸入           : 無
  145. * 輸出                  : 無
  146. *************************************************************************/
  147. void UsartConfiguration()
  148. {
  149.         SCON=0X50;                        //設(shè)置為工作方式1
  150.         //TMOD=0X20;                        //設(shè)置計數(shù)器工作方式2
  151.         TMOD=0X21;                        //設(shè)置計數(shù)器工作方式2         和定時器0
  152.         PCON=0X80;                        //波特率加倍
  153. ……………………
  154. …………限于本文篇幅 余下代碼請從51黑下載附件…………
按鍵&amp;串口控制步進電機正反轉(zhuǎn)調(diào)速.zip (163.03 KB, 下載次數(shù): 644)
參與人數(shù) 2黑幣 +55 收起 理由
方法啊 + 5
admin + 50 共享資料的黑幣獎勵!
ID:258841 發(fā)表于 2017-12-7 21:35 | 顯示全部樓層
樓主好棒棒!好資料,51黑有你更精彩!!!
ID:305304 發(fā)表于 2018-4-12 12:26 來自觸屏版 | 顯示全部樓層
怎么打開
ID:282650 發(fā)表于 2018-5-24 22:40 | 顯示全部樓層
打不開的改拓展名為rar
ID:243748 發(fā)表于 2018-6-21 11:04 來自觸屏版 | 顯示全部樓層
下載了,打不開,請問樓主這個用什么軟件打開的?
ID:362567 發(fā)表于 2018-7-1 16:09 | 顯示全部樓層
很不錯的程序。謝謝樓主。
ID:366035 發(fā)表于 2018-7-11 10:25 | 顯示全部樓層
那個黑屏是啥
ID:369596 發(fā)表于 2018-11-15 10:21 | 顯示全部樓層
請問這個接線復(fù)雜嗎?
ID:183659 發(fā)表于 2018-11-15 22:08 來自觸屏版 | 顯示全部樓層
謝謝大佬的資料
ID:427714 發(fā)表于 2018-11-16 14:39 | 顯示全部樓層
用什么打開
ID:434106 發(fā)表于 2018-11-27 12:53 | 顯示全部樓層
感謝大佬分享
ID:434106 發(fā)表于 2018-11-29 13:29 | 顯示全部樓層
很有用 感謝分享
ID:891484 發(fā)表于 2021-3-15 14:00 | 顯示全部樓層
怎么按按鍵電機沒有反應(yīng)
ID:97350 發(fā)表于 2021-5-15 16:04 | 顯示全部樓層
為什么里面的仿真圖只能用Proteus8.8打開?
ID:782212 發(fā)表于 2021-5-16 16:36 | 顯示全部樓層
有交流電機調(diào)速的仿真能發(fā)我一份嗎
