程序分享出來(lái)給需要的人作參考
- #include <stdio.h>
- #include <reg52.h>
- #include <intrins.h>
- #define MAIN_Fosc 11059200UL //宏定義主時(shí)鐘HZ
- #define PCF8591_ADDR 0x90 //PCF8591地址
- #define DACOUT_EN 0x40 //DAC輸出使能
- 自定義類型名
- typedef unsigned char INT8U;
- typedef unsigned char uchar;
- typedef unsigned int uint;
- typedef unsigned int INT16U;
- 硬件接口位聲明
- sbit SDA = P2^0; //I2C串行數(shù)據(jù)
- sbit SCL = P2^1; //I2C串行時(shí)鐘
- //sbit DU = P2^6; //數(shù)碼管段選
- //sbit WE = P2^7; //數(shù)碼管位選
- sbit LED1= P1^0; //讀取AD的值是否成功(亮成功,滅失。
- sbit LED2= P1^1; //DAC成功輸出(亮成功,滅失敗)
- sbit BEEP= P2^3; //蜂鳴器引腳定義
- sbit LCD_RS=P3^5; //lcd1602讀
- sbit LCD_RW=P3^6; //lcd1602寫
- sbit LCD_EN=P3^4; //lcd1602使能
- uchar AD_Value; //存儲(chǔ)AD轉(zhuǎn)換回的數(shù)字量
- /*函數(shù)聲明*/
- bit ADC_Read(uchar CON);
- bit DAC_OUT(uchar DAT);
- void Delay_Ms(INT16U ms);
- void Delay5us();
- void Display(INT8U Value, INT8U col );
- void I2C_init();
- uchar I2C_read_byte();
- void I2C_send_byte(uchar byte);
- void I2C_Start();
- void I2C_Stop();
- void lcd_read_busy();
- void lcd_set_init();
- void lcd_write_cmd(uchar cmd);
- void lcd_write_dat(uchar dat);
- bit Test_ACK();
- void Master_ACK(bit i);
- 共陰極數(shù)碼管段選碼
- uchar code table[]={
- //0 1 2 3 4 5 6 7 8
- 0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F,
- //9 A B C D E F - . 關(guān)顯示
- 0x6F, 0x77, 0x7C, 0x39, 0x5E, 0x79, 0x71, 0x40, 0x80, 0x00
- 數(shù)碼管位選碼
- //第1位 2位 3位 4位 5位 6位 7位 8位
- uchar code T_COM[] = {0xfe, 0xfd, 0xfb, 0xf7, 0xef, 0xdf, 0xbf, 0x7f};//數(shù)碼管位碼
- /*LCD函數(shù)*/
- /*判斷忙不忙,忙則等待 */
- uchar busy;
- P0=0xff;
- LCD_RS=0;
- LCD_RW=1;
- do{
- LCD_EN=1;
- busy=P0;
- LCD_EN=0;
- }while(busy&0x80);
- /*寫命令 寫一個(gè)字節(jié)*/
- lcd_read_busy(); //判斷忙不忙
- LCD_RS=0;
- LCD_RW=0;
- P0=cmd;
- LCD_EN=1;
- LCD_EN=0;
- /*寫數(shù)據(jù) 寫一個(gè)字節(jié)*/
- lcd_read_busy();//判斷忙不忙
- LCD_RS=1;
- LCD_RW=0;
- P0=dat;
- LCD_EN=1;
- LCD_EN=0;
- /*LCD1602 設(shè)置初始化*/
- lcd_write_cmd(0x33); //
- lcd_write_cmd(0x38); //設(shè)置16*2顯示模式
- lcd_write_cmd(0x01); //清屏
- lcd_write_cmd(0x0f); //開顯示,不顯示光標(biāo),光標(biāo)不閃爍
- lcd_write_cmd(0x06); //讀寫一個(gè)字符后地址指針加一
- lcd_write_cmd(0x80); //數(shù)據(jù)指針設(shè)置
- 函數(shù):void Delay_Ms(INT16U ms)
- 參數(shù):ms,毫秒延時(shí)形參
- 描述:12T 51單片機(jī)自適應(yīng)主時(shí)鐘毫秒級(jí)延時(shí)函數(shù)
- INT16U i;
- do{
- i = MAIN_Fosc / 96000;
- while(--i); //96T per loop
- }while(--ms);
- 函數(shù):void Delay5us()
- 描述:12T 51單片機(jī)5微秒延時(shí)函數(shù)自適應(yīng)時(shí)鐘(11.0592M,12M,22.1184M)
- void Delay5us()
- #if MAIN_Fosc == 11059200
- _nop_();
- #elif MAIN_Fosc == 12000000
- _nop_();
- #elif MAIN_Fosc == 22118400
- _nop_(); _nop_(); _nop_();
- #endif
- 函數(shù):void Display(INT8U Value)
- 參數(shù):Value,顯示值 取值0-255
- 描述:LCD1602顯示函數(shù)可顯示一個(gè)字節(jié)的數(shù)
- { uchar bai,shi,ge;
- bai=Value/100;
- shi=Value/10%10;
- ge=Value%10;
- //lcd_set_init();
- lcd_write_cmd(0x80+col);
- lcd_write_dat(bai+'0');
- lcd_write_dat(shi+'0');
- lcd_write_dat(ge+'0');
- void Display(INT8U Value)
- DU = 1;
- P0 = table[Value/100]; //管顯示百位
- DU = 0;
- P0 = 0xff; //清除斷碼
- WE = 1;
- P0 = T_COM[0]; //第一位數(shù)碼管
- WE = 0;
- Delay_Ms(5);
- DU = 1;
- P0 = table[Value%100/10]; //顯示十位
- DU = 0;
- P0 = 0xff; //清除斷碼
- WE = 1;
- P0 = T_COM[1]; //第二位數(shù)碼管
- WE = 0;
- Delay_Ms(5);
- DU = 1;
- P0 = table[Value%10]; //顯示個(gè)位
- DU = 0;
- P0 = 0xff; //清除斷碼
- WE = 1;
- P0 = T_COM[2]; //第三位數(shù)碼管
- WE = 0;
- Delay_Ms(5);
- 函數(shù):I2C_init()
- 描述:I2C總線初始化
- void I2C_init()
- SDA = 1; //數(shù)據(jù)總線高
- _nop_();
- SCL = 1; //時(shí)鐘總線高
- _nop_();
- 函數(shù):I2C_Start()
- 描述:I2C起始信號(hào)
- void I2C_Start()
- SCL = 1;
- _nop_();
- SDA = 1;
- Delay5us();
- SDA = 0;
- Delay5us();
- 函數(shù):I2C_Stop()
- 描述:I2C停止信號(hào)
- void I2C_Stop()
- SDA = 0;
- _nop_();
- SCL = 1;
- Delay5us();
- SDA = 1;
- Delay5us();
- 函數(shù):Master_ACK(bit i)
- 參數(shù):i 為0時(shí)發(fā)送非應(yīng)答 為1時(shí)發(fā)送應(yīng)答
- 描述:I2C主機(jī)發(fā)送應(yīng)答
- SCL = 0; // 拉低時(shí)鐘總線允許SDA數(shù)據(jù)總線上的數(shù)據(jù)變化
- _nop_(); // 讓總線穩(wěn)定
- if (i) //如果i = 1 那么拉低數(shù)據(jù)總線 表示主機(jī)應(yīng)答
- SDA = 0;
- else
- SDA = 1; //發(fā)送非應(yīng)答
- _nop_();//讓總線穩(wěn)定
- SCL = 1;//拉高時(shí)鐘總線 讓從機(jī)從SDA線上讀走 主機(jī)的應(yīng)答信號(hào)
- _nop_();
- SCL = 0;//拉低時(shí)鐘總線, 占用總線繼續(xù)通信
- _nop_();
- SDA = 1;//釋放SDA數(shù)據(jù)總線。
- _nop_();
- 函數(shù):Test_ACK()
- 返回:0為非應(yīng)答 1為應(yīng)答
- 描述:I2C檢測(cè)從機(jī)應(yīng)答
- bit Test_ACK() // 檢測(cè)從機(jī)應(yīng)答
- SCL = 1;//時(shí)鐘總線為高電平期間可以讀取從機(jī)應(yīng)答信號(hào)
- Delay5us();
- if (SDA)
- SCL = 0;
- I2C_Stop();
- return(0);
- else
- SCL = 0;
- return(1);
- 函數(shù):I2C_send_byte(uchar byte)
- 參數(shù):byte 要發(fā)送的字節(jié)
- 描述:I2C發(fā)送一個(gè)字節(jié)
- uchar i;
- for(i = 0 ; i < 8 ; i++)
- SCL = 0;
- _nop_();
- if (byte & 0x80) //
- SDA = 1;
- _nop_();
- else
- SDA = 0;
- _nop_();
- SCL = 1;
- _nop_();
- byte <<= 1;
- SCL = 0;
- _nop_();
- SDA = 1;
- _nop_();
- 函數(shù):I2C_read_byte()
- 返回:讀取的字節(jié)
- 描述:I2C讀一個(gè)字節(jié)
- uchar i, dat;
- SCL = 0 ;
- _nop_();
- SDA = 1;
- _nop_();
- SCL = 1;
- _nop_();
- dat <<= 1;
- if (SDA)
- dat |= 0x01;
- _nop_();
- SCL = 0;
- _nop_();
- return(dat);
- /*DAC輸出*/
- I2C_Start();
- I2C_send_byte(PCF8591_ADDR+0);
- if (!Test_ACK())
- return(0);
- I2C_send_byte(DACOUT_EN); //DA輸出使能
- if (!Test_ACK())
- return(0);
- I2C_send_byte(DAT);
- if (!Test_ACK())
- return(0);
- I2C_Stop();
- return(1);
- /*讀AD數(shù)據(jù)*/
- I2C_Start();
- if (!Test_ACK())
- return(0);
- I2C_send_byte(CON);
- Master_ACK(0);
- I2C_Start();
- I2C_send_byte(PCF8591_ADDR+1);
- if (!Test_ACK())
- return(0);
- AD_Value = I2C_read_byte();
- Master_ACK(0);
- I2C_Stop();
- return(1);
- void main()
- I2C_init();
- lcd_set_init();
- while(1)
- //單端輸入,讀出通道2的值
- if (ADC_Read(0x01)) LED1 = 0; else LED1 = 1;
- if (DAC_OUT(AD_Value)) LED2 = 0; else LED2 = 1;
- Display(AD_Value,0);
- if (ADC_Read(0x02)) LED1 = 0; else LED1 = 1;
- Display(AD_Value,8);
- if (ADC_Read(0x03)) LED1 = 0; else LED1 = 1;
- Display(AD_Value,0x40);
- if (ADC_Read(0x04)) LED1 = 0; else LED1 = 1;
- Display(AD_Value,0x48);
- if (AD_Value > 150) BEEP = 0; else BEEP = 1;
- Delay_Ms(100);
