- #include<reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit Seg_W1 = P2^0;
- sbit Seg_W2 = P2^1;
- sbit Seg_W3 = P2^2;
- sbit Seg_W4 = P2^3;
- uint code biao[]={0xC0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
- //uint array[]={0,1,2,3,4,5,6,7,8,9};
- uchar displayDelayCount = 0;
- uchar displayIndex = 0;
- uint displayData = 0;
- uchar count;
- void xianshi(void)//
- if(displayDelayCount >1)//
- displayDelayCount = 0;
- if(displayIndex < 4) //
- displayIndex ++;
- else
- displayIndex = 0;
- if(displayIndex == 0)
- // P1=0xff;
- Seg_W1=1;
- P1=biao[displayData%10];
- Seg_W1=0;
- if(displayIndex == 1)
- Seg_W2=1;
- P1=biao[displayData/10%10];
- Seg_W2=0;
- if(displayIndex == 2)
- Seg_W3=1;
- P1=biao[displayData/100%10];
- Seg_W3=0;
- if(displayIndex == 3)
- Seg_W4=1;
- P1=biao[displayData/1000%10];
- Seg_W4=0;
- void time0()interrupt 1
- TH0=(65536-2000)/256;
- TL0=(65536-2000)%256; //原來(lái)這里這位0.6ms,時(shí)間太短
- displayDelayCount++; //數(shù)碼管點(diǎn)亮?xí)r間,這里設(shè)為2ms(@12MHz)
- count++;
- if(count==100)
- count=0;
- displayData++; //顯示數(shù)碼 200ms加1
- if(displayData==9999)
- displayData=0;
- void main()
- EA=1;
- ET0=1;
- TMOD=0X01;
- TR0=1;
- while(1)
- xianshi();
復(fù)制代碼 |
