DS18B20溫度,調(diào)上下限,數(shù)碼管顯示,超出閾值報警
單片機源程序如下:
- #include<reg52.h>
- #include<intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- bit flag;
- sbit ds=P2^2;
- sbit beep=P1^0;
- uint temp;
- sbit led3=P1^2;
- sbit dula=P2^6;
- sbit wela=P2^7;
- sbit key1=P3^4;
- sbit key2=P3^6;
- sbit key3=P3^7;
- uchar num,num_shang=0,num_xia=0,numled,flag_qiehuan;
- uchar code table_du[]={
- 0x3f,0x06,0x5b,0x4f,
- 0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,
- 0x39,0x5e,0x79,0x71};
- void delay(xms) //延時函數(shù)
- uint i,j;
- for(i=xms;i>0;i--)
- for(j=100;j>0;j--);
- void delayus(uint t)
- while(t--);
- void init() //初始化函數(shù)
- TMOD=0x01; //設(shè)置定時器0位工作方式(00000001)
- TH0=(65536-22500)/256; //裝初值
- TL0=(65536-22500)%256;
- EA=1; //開總中斷
- ET0=1; //開定時器0中斷
- TR0=1;
- void display_shumaguan() //顯示子函數(shù),中間兩位數(shù)碼管
- uchar qian,bai,shi,ge;;
- qian=num_shang/10; //分離要顯示的函數(shù)
- bai=num_shang%10;
- dula=1;
- P0=table_du[qian]; //送千位段選
- dula=0;
- P0=0xff; //送位選數(shù)據(jù)前關(guān)閉所有顯示
- wela=1;
- P0=0xfb; //送位選數(shù)據(jù)
- wela=0;
- delay(4);
- dula=1; //送各位段選函數(shù)
- P0=table_du[bai];
- dula=0;
- P0=0xff;
- wela=1;
- P0=0xf7;
- wela=0;
- delay(4);
- shi=num_xia/10;
- ge=num_xia%10;
- dula=1;
- P0=table_du[shi];
- dula=0;
- P0=0xff;
- wela=1;
- P0=0xef;
- wela=0;
- delay(4);
- dula=1;
- P0=table_du[ge];
- dula=0;
- P0=0xff;
- wela=1;
- P0=0xdf;
- wela=0;
- // delay(1);
- void ds_reset() //復(fù)位函數(shù)
- ds=1;
- delayus(5); // 延時
- ds=0;
- delayus(80);
- ds=1;
- delayus(14);
- if(ds==0)
- flag=1;
- else
- flag=0; //flag作為標(biāo)志位,等1表示18b20存在
- delayus(20);
- bit ds_read_bit(void) //讀一位數(shù)據(jù)函數(shù)
- bit dat;
- ds=0;
- _nop_(); //延時機器周期
- _nop_();
- ds=1; //釋放總線
- _nop_();
- dat=ds;
- delayus(10); //延時100us
- return dat;
- uchar ds_read_byte() //讀一個字節(jié)函數(shù)
- uchar i,j,k;
- for(i=0;i<8;i++) //一個字節(jié)8位組成,循環(huán)八次
- j=ds_read_bit();
- k=(j<<7)|(k>>1); //讀出的數(shù)據(jù)最低位在最前面
- return k;
- void ds_write_byte(uchar dat) //寫一個字節(jié)的函數(shù)
- uchar i;
- for(i=0;i<8;i++) //循環(huán)八位將一個字節(jié)由低到高寫入
- ds=0;
- _nop_();
- ds=dat&0x01; //保留dat的最低位
- delayus(6);
- ds=1; //釋放總線
- dat=dat>>1;
- delayus(6);
- uint read_temp() //讀取溫度函數(shù)
- uchar a,b;
- ds_reset();
- ds_write_byte(0xcc);
- ds_write_byte(0xbe);
- a=ds_read_byte(); //讀低八位
- b=ds_read_byte(); //讀高八位
- temp=b;
- temp=temp<<8;
- temp=temp|a;
- temp=temp*0.0625; //得到實際溫度值
- return temp;
- void display(uint temp)
- P0=table_du[temp/10];
- dula=1;
- dula=0;
- P0=0xff;
- wela=1;
- P0=0xfe;
- wela=0;
- delay(4);
- P0=table_du[temp%10];
- dula=1;
- dula=0;
- P0=0xff;
- wela=1;
- P0=0xfd;
- wela=0;
- // delay(1);
- void keyscan()
- if(key1==0)//按鍵1處理
- if(flag_qiehuan==0)
- flag_qiehuan=1; //切換設(shè)置上限
- else if(flag_qiehuan==1)
- flag_qiehuan=0; //切換設(shè)置下限
- if((key2==0)&&(flag_qiehuan==0)) //k2長按
- delay(30);
- num_xia++;
- else if((key2==0)&&(flag_qiehuan==0)) //K2短按
- delay(3);
- num_xia++;
- while(!key2);
- if((key3==0)&&(flag_qiehuan==0))
- delay(30);
- num_xia--;
- else if((key3==0)&&(flag_qiehuan==0)) //K3短按
- delay(3);
- num_xia--;
- while(!key3);
- if((key2==0)&&(flag_qiehuan==1))
- delay(30);
- num_shang++;
- else if((key2==0)&&(flag_qiehuan==1))
- delay(3);
- num_shang++;
- while(!key2);
- if((key3==0)&&(flag_qiehuan==1))
- delay(30);
- num_shang--;
- else if((key3==0)&&(flag_qiehuan==1))
- delay(3);
- num_shang--;
- while(!key3);
- void deal()
- if((temp>=num_xia)||(temp<=num_shang))
- beep=0;
- if((temp<num_xia)&&(temp>num_shang))
完全品.zip
(39.28 KB, 下載次數(shù): 108)
2017-8-23 15:49 上傳
點擊文件名下載附件
DS18B20溫度,調(diào)閾值報警
