查看: 6667|回復(fù): 4
zigbee cc2530 time1,time3 16khz PWM占空比變化輸出 可調(diào)LED七彩燈
ID:229131 發(fā)表于 2017-8-25 09:27 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
可調(diào)LED七彩燈
  1. /**************************************/
  2. /*           WeBee團(tuán)隊(duì)                */
  3. /*         Zigbee學(xué)習(xí)例程             */
  4. /*例程名稱(chēng):點(diǎn)亮LED                  */
  5. /*建立時(shí)間:04/18               */
  6. /*描述:點(diǎn)亮LED1
  7. **************************************/
  8. #include <ioCC2530.h>
  9. typedef unsigned int uint;
  10. typedef unsigned char uchar;
  11. uchar h=0x00;
  12.   uchar js=0;
  13.   uchar a=1;
  14. void DelayMs(uint msec)
  15. {
  16.   uint i,j;
  17.   for(i=0;i<msec;i++)
  18.     for(j=0;j<535;j++);
  19. }
  20. void T1Init()
  21. {
  22.     CLKCONCMD &= ~0x40;         //設(shè)置系統(tǒng)時(shí)鐘源為32MHZ的晶振
  23.     while(CLKCONSTA & 0x40);    //等待晶振穩(wěn)定為32MHZ
  24.     CLKCONCMD &= ~0x07;         //設(shè)置系統(tǒng)主時(shí)鐘頻率為32MHZ
  25.     CLKCONCMD |= 0x18;          //定時(shí)器標(biāo)記輸出為250KHZ
  26.
  27.     PERCFG |= 0x23; // Timer 3 Alternate location 2 ,Timer 1 Alternate location 1
  28.     P2SEL |= 0x20;  //timer3 priority to usart
  29.
  30.     P0SEL |= 0x7C;  // Set P0_2-P0_5 to peripheral
  31.     P0DIR |= 0x7C;
  32.     P1SEL |= 0xC0; // Peripheral function on P1_6 P1_7
  33.     P1DIR |= 0xC0; // P1_7 = output
  34.     P2SEL &= ~0x10;             //相對(duì)于Timer4,定時(shí)器1優(yōu)先
  35.     P2DIR |= 0xC0;              //定時(shí)器通道2-3具有第一優(yōu)先級(jí)
  36.
  37.     T3CC0 = 0x64;     // PWM duty cycle, Channel 0 (P1_6)
  38.     T3CCTL0 = 0x2C;
  39.
  40.     T3CC1 = 0x64;     // PWM duty cycle, Channel 1 (P1_7)
  41.     T3CCTL1 = 0x2C;
  42.     T3CTL |= 0x1c; //start timer3
  43.
  44.     //定時(shí)器模式設(shè)置
  45.     T1CTL = 0x02;               //250KHZ不分頻,模模式
  46.
  47.     //裝定時(shí)器通道0初值
  48.     T1CC0H = 0x00;
  49.     T1CC0L = 0xFF;              //PWM信號(hào)周期為1ms,頻率為1KHZ
  50.
  51.     T1CC1L = 0x64;  // PWM duty cycle, Channel 1 (P0_3)
  52.     T1CC1H = 0x00;
  53.     T1CCTL1 = 0x1c; // Channel 1 in compare mode, Set output on compare-up, clear on compare-down
  54.
  55.     //裝定時(shí)器通道2比較值
  56.     T1CC2H = 0x00;    //// PWM duty cycle, Channel 2 (P0_4)
  57.     //T1CC2L = 0xF7; //1%的正占空比
  58.     //T1CC2L = 0xE1; //10%的正占空比
  59.     //T1CC2L = 0xC8; //20%的正占空比
  60.     //T1CC2L = 0xAF; //30%的正占空比
  61.     //T1CC2L = 0x96; //40%的正占空比
  62.     T1CC2L = 0x7D; //50%的正占空比
  63.     //T1CC2L = 0x64; //60%的正占空比
  64.     //T1CC2L = 0x4B; //70%的正占空比
  65.     //T1CC2L = 0x32; //80%的正占空比
  66.     //T1CC2L = 0x19; //90%的正占空比
  67.     //T1CC2L = 0x0A; //99%的正占空比
  68.     //T1CC2L = 0x01; //設(shè)置通道2比較寄存器初值
  69.     T1CCTL2 = 0x1C;             //比較相等置1,計(jì)數(shù)器回0則清零
  70.
  71.     T1CC3L = 0x4B;  // PWM duty cycle, Channel 3 (P0_5)
  72.     T1CC3H = 0x00;
  73.     T1CCTL3 = 0x1c; // Channel 3 in compare mode, Set output on compare-up, clear on compare-down
  74.     T1CC4L = 0x32;  // PWM duty cycle, Channel 4 (P0_6)
  75.     T1CC4H = 0x00;
  76.     T1CCTL4 = 0x1c; // Channel 4 in compare mode, Set output on compare-up, clear on compare-down
  77. }
  78.
  79. void main()
  80. {
  81.     uint i;
  82.     uint rate[11]={0xF7,0xE1,0xC8,0xAF,0x96,0x7D,0x64,0x4B,0x32,0x19};
  83.     T1Init();
  84. while(1)
  85.     {
  86. //          for(i=0;i<11;i++)
  87. //        {
  88. //          T1CC4H = 0x00;
  89. //          T1CC4L = rate[i];
  90. //          T1CC3H  = 0x00;
  91. //          T1CC3L = rate[i];
  92. //          DelayMs(500);
  93. //        }
  94.
  95. //         for(i=0;i<240;i++)
  96. //        {
  97. //          T1CC4H = 0x00;
  98. //          T1CC4L = i;
  99. //          T1CC3H  = 0x00;
  100. //          T1CC3L = rate[i];
  101. //          DelayMs(25);
  102. //        }
  103. //
  104. //        for(i=240;i>0;i--)
  105. //        {
  106. //          T1CC4H = 0x00;
  107. //          T1CC4L = i;
  108. //          T1CC3H  = 0x00;
  109. //          T1CC3L = rate[i];
  110. //          DelayMs(25);
  111. //        }
  112.
  113.        if ((T1STAT&0x04)>0)
  114.       {
  115.         // T1STAT=T1STAT&0xfb;
  116.          T1STAT=T1STAT&0x0b;
  117.
  118.          js++;
  119.          if(js>=1)
  120.          {
  121.            js=0;
  122.            if(a == 1)
  123.            {
  124.             h=h+1;
  125.             DelayMs(10);
  126.            }
  127.             else
  128.             {
  129.             h=h-1;
  130.            DelayMs(10);
  131.             }
  132.
  133. ……………………
  134. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
time1和time3 16khz_pwm占空比變化.rar (67 KB, 下載次數(shù): 44)
參與人數(shù) 1黑幣 +2 收起 理由
Ritayang + 2 正需要這個(gè)!��!非常有用很好的幫到了忙
收藏收藏4 分享淘帖 頂 踩
ID:261759 發(fā)表于 2017-12-15 21:36 | 只看該作者
不錯(cuò),好東西,我喜歡!
ID:598449 發(fā)表于 2019-8-27 14:22 | 只看該作者
兄弟,你這代碼什么都沒(méi)有啊。。。。。。
ID:616445 發(fā)表于 2019-9-25 22:49 | 只看該作者
不錯(cuò),謝謝!
ID:624381 發(fā)表于 2020-4-30 22:47 | 只看該作者
不錯(cuò),謝謝!
