基于HLW8012芯片的pfc功率因數(shù)測試儀制作資料,下面是stm32工程元源碼.
- #include "stm32_usart.h"
- #include "stm32_delay.h"
- #include "stm32_led.h"
- #include "stm32_key.h"
- #include "sys.h"
- #include "stm32_oled.h"
- #include "stm32_timer.h"
- char tempStr[30];
- int tempStrLen;
- int tempI;
- float hlw8012_f;
- float hlw8012_P;
- float hlw8012_Pp = 103.5 / 21.6;
- extern recType tRecType;
- u32 countTotal;
- float hlw8012_f;
- u32 freq_arr;
- #define CNT_TO_US(cnt) (u32)((cnt + (TIM4_FREQ / 2000000)) / (TIM4_FREQ / 1000000) ) // 獲取周期 ((cnt + 36) / 72) (cnt / 72) 四舍五入 u16 or u32
- #define CNT_TO_FREQ(cnt) (u32)((TIM1_FREQ + (cnt / 2 )) / cnt ) // 獲取頻率 (72000000 / cnt) 四舍五入 u32
- #define FREQ_TO_CNT(freq) (u32)((TIM1_FREQ + (freq / 2 )) / freq ) // 獲取計數(shù)值 (72000000 / freq) 四舍五入 u32
- #define US_TO_CNT(us) (u32)((TIM1_FREQ / 1000000) * us ) // 獲取技術(shù)值 (72 * us) u32
- #define U16_TO_U32(H, L) (u32)((u32)(H << 16) + L)
- unsigned char data_check (recType *pRec, float *modePow);
- int main(void)
- float Pow_mode;
- delay_init(); //延時初始化
- NVIC_Configuration(); //設(shè)置NVIC中斷分組2:2位搶占優(yōu)先級,2位響應(yīng)優(yōu)先級
- uart_init(115200);
- keyInit();
- OLED_Init();
- LED_Init();
- TIM3_Int_Init(5000, 7200-1);
- OLED_Clear();
- // OLED_ShowString(10 * 8,6," KEY ");
- OLED_ShowCHinese(28 + 0,0,0);
- OLED_ShowCHinese(28 + 16,0,1);
- OLED_ShowCHinese(28 + 32,0,2);
- OLED_ShowCHinese(28 + 48,0,3);
- // //OLED_ShowString(0,3," www.szlcsc.com");
- // OLED_ShowString(16,6,"1234");
- TIM1_Cap_Init(65536 - 1, TIM1_PSC);
- RCC_ClocksTypeDef RCC_ClocksStatus;
- RCC_GetClocksFreq(&RCC_ClocksStatus);
- printf("SYSCLK_Frequency: %d Hz\r\n", RCC_ClocksStatus.SYSCLK_Frequency);
- printf("HCLK_Frequency: %d Hz\r\n", RCC_ClocksStatus.HCLK_Frequency);
- printf("PCLK1_Frequency: %d Hz\r\n", RCC_ClocksStatus.PCLK1_Frequency);
- printf("PCLK2_Frequency: %d Hz\r\n", RCC_ClocksStatus.PCLK2_Frequency);
- while(1) {
- TIM1->SR = (uint16_t)~TIM_IT_CC1; // 清中斷
- TIM1->SR = (uint16_t)~TIM_IT_Update; // 清中斷
- TIM_ITConfig(TIM1, TIM_IT_Update | TIM_IT_CC1, ENABLE);
- TIM_Cmd(TIM1, ENABLE);
- // 捕捉超過3秒
- if ((tRecType.currOverCnt > (TIM1_FREQ / 65536) * 3) || (tRecType.size > 10)) {
- TIM_ITConfig(TIM1, TIM_IT_Update | TIM_IT_CC1, DISABLE);
- TIM_Cmd(TIM1, DISABLE);
- data_check(&tRecType, &Pow_mode);
- tRecType.size = 0;
- tRecType.currOverCnt = 0;
- if (Pow_mode > 5)
- showPower(1, Pow_mode);
- else
- showPower(1, 20000);
- return 1;
- //u32 mYverage (u) 遞歸法:假設(shè)前n個數(shù)的平均數(shù)為avg, 那么前n+1個數(shù)的平均數(shù)avg = ((avg * n) + X) / (n + 1) = avg - avg / (n + 1) + X / (n + 1) = avg + (X - avg) / (n + 1)
- float mYverage (float avg, float X, u32 n)
- if (n == 0) {
- return 0;
- } else if (n == 1) {
- return X;
- } else if (n > 1) {
- if (X > avg) {
- return (avg + (X - avg) / n);
- } else {
- return (avg - (avg - X) / n);
- } else {
- return 0;
- unsigned char ret = 1;
- float fAvg;
- u32 u32Temp1, u32Temp2;
- u16 i = 0, j = 0;
- if (pRec->size == 0 || pRec->size == 1) { // 不夠1Hz
- *modePow = 0;
- ret = 0;
- goto end;
- // 矯正 數(shù)據(jù)中 溢出中斷 與 捕獲中斷 并發(fā) 造成的 溢出數(shù)據(jù)(overCnt) 順序混亂的情況
- for (i = 0; i < pRec->size; i++) {
- if (pRec->overCnt[i] == pRec->overCnt[i + 1]) {
- if (pRec->cnt[i] > pRec->cnt[i + 1]) { // 后面的數(shù)據(jù)小于前面的數(shù)據(jù)--這種情況不應(yīng)該發(fā)生
- pRec->overCnt[i + 1]++;
- // 將 數(shù)據(jù) 由 絕對值 換算為 相對值
- for (i = 0; i < pRec->size - 1; i++) {
- u32Temp1 = U16_TO_U32(pRec->overCnt[i + 0], pRec->cnt[i + 0]);
- u32Temp2 = U16_TO_U32(pRec->overCnt[i + 1], pRec->cnt[i + 1]);
- pRec->overCnt[i] = (u16)((u32Temp2 - u32Temp1) >> 16);
- pRec->cnt[i] = (u16)((u32Temp2 - u32Temp1) >> 0);
- pRec->size -= 1; // 數(shù)量減一
- // 刪除 波形中 的高頻毛刺
- u32Temp1 = U16_TO_U32(pRec->overCnt[i], pRec->cnt[i]);
- if (CNT_TO_FREQ(u32Temp1) > 100000) { // TIM1_FREQ / 100KHz = 720 過濾掉>100KHz的波形
- for (j = i; j < pRec->size - 1; j++) {
- pRec->overCnt[j] = pRec->overCnt[j + 1];
- pRec->cnt[j] = pRec->cnt[j + 1];
- pRec->size--;
- // 將 高頻數(shù)據(jù) 整合在一起 求平均
- fAvg = 0;
- fAvg = mYverage(fAvg, (float)u32Temp1, i + 1);
- *modePow = hlw8012_Pp * CNT_TO_FREQ((u32)fAvg); // 計算功率
- /********************************打印數(shù)據(jù)************************************************/
- tempStrLen = sprintf(tempStr,"%f", *modePow);
- txNByte(USART1, tempStr, tempStrLen);
- txStr(USART1, "w\r\n");
- end:
- return ret;
單片機(jī)源碼及固件下載.zip
(3.99 MB, 下載次數(shù): 271)
2017-9-3 08:40 上傳
點擊文件名下載附件
