查看: 1944|回復(fù): 0
stm32 八位驅(qū)動LCD
ID:231183 發(fā)表于 2017-9-5 16:31 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "LCD2.h"
void LCD2_GPIO_Init()
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOD | RCC_APB2Periph_AFIO, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                         //¿úÏß·-×aËù¶èÎa50MHz
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        //8λêy¾Yêä3ö
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
        GPIO_Init(GPIOD, &GPIO_InitStructure);
//×îμ×2ãêy¾Y′«êäoˉêy
//D′Ãüáî
void Write_Cmd(unsigned char DH,unsigned char DL)
        LCD2_CS=0;
        LCD2_RS=0;
        DataPort=DH;
        LCD2_RW=0;
        LCD2_RW=1;
        DataPort=DL;
        LCD2_RW=0;
        LCD2_RW=1;
        LCD2_CS=1;
//D′êy¾Y Ë«8λ
void Write_Data(unsigned char DH,unsigned char DL)
        LCD2_CS=0;
        LCD2_RS=1;
        DataPort=DH;
        LCD2_RW=0;
    LCD2_RW=1;
        DataPort=DL;
        LCD2_RW=0;
        LCD2_RW=1;
        LCD2_CS=1;
//D′êy¾Y Ë«8λ
void Write_Data2(unsigned char DH,unsigned char DL)
        DataPort=DH;
        LCD2_RW=0;
    LCD2_RW=1;
        DataPort=DL;
        LCD2_RW=0;
        LCD2_RW=1;
//μ÷óÃéÏÃæ×îμ×2ãêμÏÖéÔ¸ß2ãD′Ãüáîoíêy¾Yoˉêy
                         D′Ãüáî¡¢D′êy¾Y
êäèë2Îêy£ox DèòaêäèëμÄÃüáî 16λ
          y DèòaêäèëμÄêy¾Y 16λ
void  Write_Cmd_Data (unsigned char x,unsigned int y)
        unsigned char m,n;
        m=y>>8;
        n=y;
        Write_Cmd(0x00,x);
        Write_Data(m,n);
                         D′16λêy¾Y
void  Write_Data_U16(unsigned int y)
//        unsigned char m,n;
//        m=y>>8;
//        n=y;
//        Write_Data2(m,n);
        DataPort=y>>8;
        LCD2_RW=0;
    LCD2_RW=1;
        DataPort=y;
        LCD2_RW=0;
        LCD2_RW=1;
                            òo¾§3õê¼»ˉ
void LCD2_Init(void)
        LCD2_CS=1;
        DELAY_MS(5);
        LCD2_RES=0;
        DELAY_MS(5);
        LCD2_RES=1;
        DELAY_MS(50);
        Write_Cmd_Data(0x0001,0x0100);
        Write_Cmd_Data(0x0002,0x0700);
        Write_Cmd_Data(0x0003,0x1030);
        Write_Cmd_Data(0x0004,0x0000);
        Write_Cmd_Data(0x0008,0x0207);
        Write_Cmd_Data(0x0009,0x0000);
        Write_Cmd_Data(0x000A,0x0000);
        Write_Cmd_Data(0x000C,0x0000);
        Write_Cmd_Data(0x000D,0x0000);
        Write_Cmd_Data(0x000F,0x0000);
        //power on sequence VGHVGL
        Write_Cmd_Data(0x0010,0x0000);
        Write_Cmd_Data(0x0011,0x0007);
        Write_Cmd_Data(0x0012,0x0000);
        Write_Cmd_Data(0x0013,0x0000);
        //vgh
        Write_Cmd_Data(0x0010,0x1290);
        Write_Cmd_Data(0x0011,0x0227);
        //DELAY_MS(100);
        //vregiout
        Write_Cmd_Data(0x0012,0x001d); //0x001b
        //DELAY_MS(100);
        //vom amplitude
        Write_Cmd_Data(0x0013,0x1500);
        //DELAY_MS(100);
        //vom H
        Write_Cmd_Data(0x0029,0x0018);
        Write_Cmd_Data(0x002B,0x000D);
        //gamma
        Write_Cmd_Data(0x0030,0x0004);
        Write_Cmd_Data(0x0031,0x0307);
        Write_Cmd_Data(0x0032,0x0002);// 0006
        Write_Cmd_Data(0x0035,0x0206);
        Write_Cmd_Data(0x0036,0x0408);
        Write_Cmd_Data(0x0037,0x0507);
        Write_Cmd_Data(0x0038,0x0204);//0200
        Write_Cmd_Data(0x0039,0x0707);
        Write_Cmd_Data(0x003C,0x0405);// 0504
        Write_Cmd_Data(0x003D,0x0F02);
        //ram
        Write_Cmd_Data(0x0050,0x0000);
        Write_Cmd_Data(0x0051,0x00EF);
        Write_Cmd_Data(0x0052,0x0000);
        Write_Cmd_Data(0x0053,0x013F);
        Write_Cmd_Data(0x0060,0xA700);
        Write_Cmd_Data(0x0061,0x0001);
        Write_Cmd_Data(0x006A,0x0000);
        Write_Cmd_Data(0x0080,0x0000);
        Write_Cmd_Data(0x0081,0x0000);
        Write_Cmd_Data(0x0082,0x0000);
        Write_Cmd_Data(0x0083,0x0000);
        Write_Cmd_Data(0x0084,0x0000);
        Write_Cmd_Data(0x0085,0x0000);
        Write_Cmd_Data(0x0090,0x0010);
        Write_Cmd_Data(0x0092,0x0600);
        Write_Cmd_Data(0x0093,0x0003);
        Write_Cmd_Data(0x0095,0x0110);
        Write_Cmd_Data(0x0097,0x0000);
        Write_Cmd_Data(0x0098,0x0000);
        Write_Cmd_Data(0x0007,0x0133);
        //        Write_Cmd_Data(0x0022);//
                         éèÖÃ×ø±ê
                            諾ֱäá¿
#define WINDOW_XADDR_START        0x0050 // Horizontal Start Address Set
#define WINDOW_XADDR_END        0x0051 // Horizontal End Address Set
#define WINDOW_YADDR_START        0x0052 // Vertical Start Address Set
#define WINDOW_YADDR_END        0x0053 // Vertical End Address Set
#define GRAM_XADDR                    0x0020 // GRAM Horizontal Address Set
#define GRAM_YADDR                    0x0021 // GRAM Vertical Address Set
#define GRAMWR                             0x0022 // memory write
void LCD_SetPos(unsigned int x0,unsigned int x1,unsigned int y0,unsigned int y1)
        Write_Cmd_Data(WINDOW_XADDR_START,x0);
        Write_Cmd_Data(WINDOW_XADDR_END,x1);
        Write_Cmd_Data(WINDOW_YADDR_START,y0);
        Write_Cmd_Data(WINDOW_YADDR_END,y1);
        Write_Cmd_Data(GRAM_XADDR,x0);
        Write_Cmd_Data(GRAM_YADDR,y0);
        Write_Cmd (0x00,0x22);//LCD_WriteCMD(GRAMWR);
                            ÏÔê¾RGBÑÕé«
êäèë2Îêy£ox0£¬y0 Æeê¼×ø±ê
          x1£¬y1 ½áêø×ø±ê
                  Color  ±3¾°ÑÕé«
void Show_RGB (unsigned int x0,unsigned int x1,unsigned int y0,unsigned int y1,unsigned int Color)
        unsigned int i,j,k=0;
        char color1=Color>>8;
        char color2=Color;
        LCD_SetPos(x0,x1,y0,y1);
        LCD2_CS=0;
        LCD2_RS=1;
//        for (i=y0;i<=y1;i++)
//           for (j=x0;j<=x1;j++)
//               Write_Data_U16(Color);
        k=(y1-y0+1)*(x1-x0+1);
        for (i=0;i<=k;i+=32)
    LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
           LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
         LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
           LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
        LCD2_RW=0;
    DataPort=color1;
    LCD2_RW=1;
        LCD2_RW=0;
        DataPort=Color;
        LCD2_RW=1;
                LCD2_CS=1;
void Delay_ms(u16 time)
        u16 i=0;
        while(time--)
                i=12000;
                while(i--);
