查看: 3678|回復(fù): 1
ST7565R_V1.9 12864控制芯片pdf資料
ID:232045 發(fā)表于 2017-9-9 11:35 | 顯示全部樓層 |閱讀模式
12864液晶屏的控制芯片資料
INTRODUCTION
ST7565R is a single-chip dot matrix LCD driver which incorporates LCD controller and common/segment drivers. ST7565R
can be connected directly to a microprocessor with 8-bit parallel interface or 4-line serial interface (SPI-4). Display data sent
from MPU is stored in the internal Display Data RAM (DDRAM) of 65x132 bits. The display data bits which are stored in
DDRAM are directly related to the pixels of LCD panel. ST7565R contains 132 segment-outputs, 64 common-outputs and 1
icon-common-output. With built-in oscillation circuit and  low power consumption power circuit, ST7565R generates LCD
driving  signal without  external  clock  or  power,  so  that  it  is  possible  to make  a  display  system with  the minimal  power
consumption.
完整的pdf格式文檔51黑下載地址(共53頁):
ST7565R_V1.9.pdf (604.73 KB, 下載次數(shù): 44)
ID:70035 發(fā)表于 2018-4-7 09:42 | 顯示全部樓層
正想找得資料。
