查看: 8977|回復(fù): 13
從51上修改而來(lái),基于stm32f103,帶字庫(kù)LCD12864液晶的驅(qū)動(dòng)程序,串行和并行都有
ID:232078 發(fā)表于 2017-9-9 15:36 | 顯示全部樓層 |閱讀模式
從51單片機(jī)平臺(tái)上修改而來(lái)的帶字庫(kù)LCD12864液晶的驅(qū)動(dòng)程序,串行和并行都有,各個(gè)函數(shù)均帶有注釋。親測(cè)可用,使用時(shí)注意修改宏定義里對(duì)管腳的定義以及引腳初始化程序
  1. #include <stm32f10x.h>
  2. #include "12864.h"
  3. #include "delay.h"
  4. void LCD12864_Init(void)
  5. {
  6.         GPIO_InitTypeDef  GPIO_InitStructure;
  7.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
  8.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;
  9.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  10.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  11.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  12.
  13.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
  14.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
  15.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  16.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  17.         delay_init();
  18. /*--------------------LCD基本指令-----------------------*/
  19.     delay_ms(2);
  20.     Write_LCD_Command(0x30);  //30--基本指令動(dòng)作
  21.     delay_ms(2);
  22.     Write_LCD_Command(0x0c);  //光標(biāo)右移畫面不動(dòng)
  23.     delay_ms(2);
  24.     Write_LCD_Command(0x01);  //清屏
  25.     delay_ms(5);              //清屏?xí)r間較長(zhǎng)
  26.     Write_LCD_Command(0x06);  //顯示打開,光標(biāo)開,反白關(guān)
  27.     delay_ms(2);
  28.         Draw_Clear();                                        // 清屏
  29. }
  30. /*********************************************************
  31. 函數(shù)名:Send_Byte()
  32. 返回值:無(wú)
  33. 功  能:        寫數(shù)據(jù)到LCD
  34. *********************************************************/
  35. void Send_Byte(u8 zdata)
  36. {
  37.   u16 i;
  38.   for(i=0; i<8; i++)
  39.     {
  40.           if((zdata << i) & 0x80)
  41.                         SID_H;
  42.           else
  43.                         SID_L;
  44.           SCLK_H;
  45.                 SCLK_L;
  46.           }
  47.         }
  48. /*********************************************************
  49. 函數(shù)名:Receive_Byte()
  50. 返回值:temp1+temp2
  51. 功  能:        讀LCD數(shù)據(jù)
  52. *********************************************************/
  53. u8 Receive_Byte(void)
  54.         {
  55.            u8 i,temp1,temp2,value;
  56.            temp1=0;
  57.            temp2=0;
  58.            for(i=0;i<8;i++)
  59.               {
  60.                            temp1=temp1<<1;
  61.                            SCLK_L;
  62.                          SCLK_H;
  63.                            SCLK_L;
  64.                          if(PAout(7)==1)
  65.                            {
  66.                              temp1++;
  67.                                 }
  68.                   }
  69.            for(i=0;i<8;i++)
  70.               {
  71.                            temp2=temp2<<1;
  72.                            SCLK_L;
  73.                          SCLK_H;
  74.                            SCLK_L;
  75.                          if(PAout(7)==1)
  76.                            {
  77.                               temp2++;
  78.                            }
  79.                   }
  80.               temp1=0xf0&temp1;
  81.                   temp2=0x0f&temp2;
  82.                   value=temp1+temp2;
  83.        return   value ;
  84.         }
  85. /*********************************************************
  86. 函數(shù)名:Check_Busy()
  87. 返回值:無(wú)
  88. 功  能:        LCD忙檢查
  89. *********************************************************/
  90. void Check_Busy(void)
  91. {
  92.         do
  93.                 Send_Byte(0xfc);                  //11111,RW(1),RS(0),0
  94.         while(0x80&Receive_Byte());
  95. }
  96. /*********************************************************
  97. 函數(shù)名: Write_LCD_Command()
  98. 返回值:無(wú)
  99. 功  能:        寫命令到LCD
  100. *********************************************************/
  101. void Write_LCD_Command(u8 cmdcode)
  102. {
  103.    CS_H;
  104.    Check_Busy();
  105.    Send_Byte(0xf8);
  106.    Send_Byte(cmdcode & 0xf0);
  107.    Send_Byte((cmdcode << 4) & 0xf0);
  108.    delay_ms(2);
  109.    CS_L;
  110. }
  111. /*********************************************************
  112. 函數(shù)名: Write_LCD_Data()
  113. 返回值:無(wú)
  114. 功  能:        寫顯示內(nèi)容到LCD
  115. *********************************************************/
  116. void Write_LCD_Data(u8 Dispdata)
  117. {
  118.   CS_H;
  119.   Check_Busy();
  120.   Send_Byte(0xfa);          //11111,RW(0),RS(1),0
  121.   Send_Byte(Dispdata & 0xf0);
  122.   Send_Byte((Dispdata << 4) & 0xf0);
  123.   delay_ms(2);
  124.   CS_L;
  125. }
  126. /*********************************************************
  127. 函數(shù)名: Read_LCD_Data()
  128. 返回值:LCD收到的數(shù)據(jù)
  129. 功  能:        讀取LCD顯示內(nèi)容
  130. *********************************************************/
  131. u8 Read_Data(void)
  132.         {
  133.           Check_Busy();
  134.           Send_Byte(0xfe);    //11111,RW(1),RS(1),0 LCD->MCU
  135.           return  Receive_Byte();
  136.
  137.         }
  138. /*********************************************************
  139. 函數(shù)名: LCD_Clear_Txt
  140. 返回值:無(wú)
  141. 功  能:        文本區(qū)清除
  142. *********************************************************/
  143. void LCD_Clear_TXT( void )
  144. {
  145.      u8 i;
  146.      Write_LCD_Command(0x30);      //8BitMCU,基本指令集合
  147.      Write_LCD_Command(0x80);      //AC歸起始位
  148.      for(i=0;i<64;i++)
  149.           {
  150.        Write_LCD_Data(0x20);
  151.           }
  152. }
  153. /*********************************************************
  154. 函數(shù)名: LCD_Clear_BMP
  155. 返回值:無(wú)
  156. 功  能:        圖片區(qū)清除
  157. *********************************************************/
  158. void LCD_Clear_BMP( void )
  159. {
  160.      u8 i,j;
  161.      Write_LCD_Command(0x34);      //8Bit擴(kuò)充指令集,即使是36H也要寫兩次
  162.      Write_LCD_Command(0x36);      //繪圖ON,基本指令集里面36H不能開繪圖
  163.      for(i=0;i<32;i++)            //12864實(shí)際為256x32
  164.      {
  165.            Write_LCD_Command(0x80|i);      //行位置
  166.            Write_LCD_Command(0x80);      //列位置
  167.            for(j=0;j<32;j++)            //256/8=32 byte
  168.                 Write_LCD_Data(0);
  169.      }
  170. }
  171. /*********************************************************
  172. 函數(shù)名: Display_LCD_Pos
  173. 返回值:無(wú)
  174. 功  能:設(shè)置顯示位置
  175. *********************************************************/
  176. void Display_LCD_Pos(u8 x,u8 y)
  177.         {
  178.            u8 pos;
  179.            switch(x)
  180.                {
  181.                              case 0: x=0x80;break;
  182.                           case 1: x=0x90;break;
  183.                              case 2: x=0x88;break;
  184.                           case 3: x=0x98;break;
  185.                    }
  186.            pos=x+y;
  187.            Write_LCD_Command(pos);
  188.     }
  189. /*********************************************************
  190. 函數(shù)名:Display_LCD_String()
  191. 返回值:無(wú)
  192. 功  能:顯示字符串
  193. *********************************************************/
  194. void Display_LCD_String(u8 *s)
  195. {
  196.     while(*s != '\0')
  197.     {
  198.         Write_LCD_Data(*s);
  199.         s++;
  200.         delay_ms(2);                                    //控制每一個(gè)字符之間顯示的時(shí)間 間隔
  201.     }
  202. }
  203. /*************************************************************
  204. * 函數(shù)名稱    :PutBMP
  205. **************************************************************/
  206. void PutBMP(const u8 *puts)
  207. {
  208.      u16 x=0;
  209.      u8 i,j;
  210.      Write_LCD_Command(0x34);      //8Bit擴(kuò)充指令集,即使是36H也要寫兩次
  211.      Write_LCD_Command(0x36);      //繪圖ON,基本指令集里面36H不能開繪圖
  212.      for(i=0;i<32;i++)            //12864實(shí)際為256x32
  213.      {
  214.            Write_LCD_Command(0x80|i);      //行位置
  215.            Write_LCD_Command(0x80);      //列位置
  216.            for(j=0;j<16;j++)      //256/8=32 byte
  217.            {            //列位置每行自動(dòng)增加
  218.                  Write_LCD_Data(puts[x]);
  219.                  x++;
  220.            }
  221.      }
  222.      for(i=0;i<32;i++)            //12864實(shí)際為256x32
  223.      {
  224.            Write_LCD_Command(0x80|i);      //行位置
  225.            Write_LCD_Command(0x88);      //列位置
  226.            for(j=0;j<16;j++)      //256/8=32 byte
  227.            {            //列位置每行自動(dòng)增加
  228.                  Write_LCD_Data(puts[x]);
  229.                  x++;
  230.            }
  231.      }
  232. }
  233. void PHO_Display(const u8 *s)
  234. {
  235.         u8 COUNT3 = 0X02,COUNT1,COUNT2,LCD_X = 0X80,LCD_Y;
  236.
  237.         for (;COUNT3 != 0;COUNT3 --)
  238.         {
  239.                 LCD_Y = 0X80;
  240.                 COUNT2 = 0X20;
  241.                 for(;COUNT2 != 0;COUNT2 --)
  242.                 {
  243.                         //COUNT1 = 0X10;//全屏
  244.                         COUNT1 = 0X08;//半屏
  245.                         Write_LCD_Command(0x34);
  246.                         Write_LCD_Command(LCD_Y);
  247.                         Write_LCD_Command(LCD_X);
  248.                         Write_LCD_Command(0x30);
  249.                         for (;COUNT1 != 0;COUNT1 --)
  250.                         {
  251.                                 Write_LCD_Data(*s ++);
  252.                         }
  253.                         LCD_Y += 1;
  254.                 }
  255.                 LCD_X = 0X88;
  256.         }
  257.         Write_LCD_Command(0x36);
  258.         Write_LCD_Command(0x30);
  259. }
  260. /*-------------------------------------------------
  261. LCD顯示緩存
  262. --------------------------------------------------*/
  263. u16 LCD12864_Buffer[64][16] = {0};
  264. const u8 m_ch4x5[][6] =
  265. {
  266.         {0x06,0x09,0x09,0x09,0x06,5},                // 0,字符寬度5點(diǎn)陣
  267.         {0x02,0x06,0x02,0x02,0x07,5},                // 1
  268.         {0x06,0x09,0x02,0x04,0x0F,5},                // 2
  269.         {0x06,0x09,0x02,0x09,0x06,5},                // 3
  270.         {0x02,0x06,0x0A,0x0F,0x02,5},                // 4
  271.         {0x0E,0x08,0x0E,0x01,0x0E,5},                // 5
  272.         {0x06,0x08,0x0E,0x09,0x06,5},                // 6
  273.         {0x0F,0x01,0x02,0x04,0x04,5},                // 7
  274.         {0x06,0x09,0x06,0x09,0x06,5},                // 8
  275.         {0x06,0x09,0x07,0x01,0x06,5},                // 9
  276.         {0x00,0x00,0x00,0x00,0x01,2},                // .
  277.         {0x00,0x01,0x00,0x01,0x00,2},                // :
  278.         {0x00,0x00,0x00,0x00,0x00,5},                 // 空格
  279. };
  280. /*------------------------------------------------------------------------------
  281. 功能:畫點(diǎn)
  282. 參數(shù):
  283.         x:橫坐標(biāo)
  284.         y:縱坐標(biāo)
  285.         color:顏色,0不顯示,1顯示
  286. ------------------------------------------------------------------------------*/
  287. const u16 DrawDotsTable[] = {0x8000, 0x4000, 0x2000, 0x1000, 0x0800, 0x0400, 0x0200, 0x0100, 0x0080, 0x0040, 0x0020, 0x0010, 0x0008, 0x0004, 0x0002, 0x0001};
  288. void Draw_Dots(u8 x, u8 y, u8 color)
  289. {
  290.         u8 i0, y0;
  291.         u16 value;
  292.         // 獲得坐標(biāo)
  293.         if ( y >= 32 )
  294.         {
  295.                 y0 = y-32;
  296.                 i0 = x/16+8;
  297.         }
  298.         else
  299.         {
  300.                 y0 = y;
  301.                 i0 = x/16;
  302.         }
  303.         value = DrawDotsTable[x%16];
  304.         if (color == 0)
  305.         {
  306.                 LCD12864_Buffer[y0][i0] &= ~value;
  307.         }
  308.         else
  309.         {
  310.                 LCD12864_Buffer[y0][i0] |= value;
  311.         }
  312. }
  313. /*------------------------------------------------------------------------------
  314. 功能:刷新顯示
  315. ------------------------------------------------------------------------------*/
  316. void Draw_Update(void)
  317. {
  318.         u8 x, y;
  319.         for (y=0; y<64; y++)
  320.         {
  321.                 Write_LCD_Command(0x80|y);
  322.                 Write_LCD_Command(0x80);
  323.                 for (x=0; x<16; x++)
  324.                 {
  325.                         Write_LCD_Data(LCD12864_Buffer[y][x]>>8);
  326.                         Write_LCD_Data(LCD12864_Buffer[y][x]);
  327.                 }
  328.         }
  329. }
  330. /*------------------------------------------------------------------------------
  331. 功能:顯示清屏
  332. ------------------------------------------------------------------------------*/
  333. void Draw_Clear(void)
  334. {
  335.         u8 x, y;
  336.         for (y=0; y<64; y++)
  337.         {
  338.                 for (x=0; x<16; x++)
  339.                 {
  340.                         LCD12864_Buffer[y][x] = 0;
  341.                 }
  342.         }
  343. }
  344. /*------------------------------------------------------------------------------
  345. 功能:顯示4*5字符
  346. 參數(shù):
  347.         x:寫出橫坐標(biāo)
  348.         y:寫出縱坐標(biāo)
  349.         value:字符
  350. ------------------------------------------------------------------------------*/
  351. void Draw_Char4x5(u8 x, u8 y, u8 value)
  352. {
  353.         u8 i, j, p, z, a;
  354.
  355.         a = m_ch4x5[value][5];
  356.         for (i=0; i<5; i++)
  357.         {
  358.                 p = 0x10>>(5-a);
  359.                 for (j=0; j<a; j ++)
  360.                 {
  361.                         z = m_ch4x5[value][i];
  362.                         if ( z & p )
  363.                         {
  364.                                 Draw_Dots(j+x, i+y, 1);
  365.                         }
  366.                         p >>= 1;
  367.                 }
  368.         }
  369. }
  370. /*--------------------------------------------------------
  371. 功能:顯示一行4*5字符
  372. 參數(shù):
  373.         x:寫出橫坐標(biāo)
  374.         y:寫出縱坐標(biāo)
  375.         value:字符串
  376.         len:長(zhǎng)度
  377. ---------------------------------------------------------*/
  378. ……………………
  379. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
12864.rar (6.83 KB, 下載次數(shù): 368)
參與人數(shù) 1黑幣 +5 收起 理由
19931124 + 5 很給力!
ID:335078 發(fā)表于 2018-6-4 22:15 | 顯示全部樓層
這程序?qū)懙糜悬c(diǎn)奇怪,注釋不太完整
ID:123956 發(fā)表于 2018-6-5 16:46 | 顯示全部樓層
感謝分享
ID:267330 發(fā)表于 2018-6-17 17:10 | 顯示全部樓層
下載看看
ID:73168 發(fā)表于 2018-7-14 08:58 | 顯示全部樓層
來(lái)看看
ID:375092 發(fā)表于 2018-9-13 20:41 | 顯示全部樓層
就是請(qǐng)問(wèn)一下,你的那個(gè)PAout(7)這是什么管腳哦,是它等于1的作用是什么,還要就是我在寫串行的時(shí)候,我去掉忙函數(shù)之后沒(méi)什么影響,但是stm32在寫并行的時(shí)候沒(méi)寫忙函數(shù)出現(xiàn)了一些問(wèn)題
參與人數(shù) 1黑幣 +20 收起 理由
ID:203214 發(fā)表于 2019-4-23 20:03 | 顯示全部樓層
下來(lái)試試,好用回來(lái)追評(píng)
ID:477134 發(fā)表于 2019-7-20 20:41 | 顯示全部樓層
感覺(jué)挺怪的
ID:479945 發(fā)表于 2019-7-21 12:39 | 顯示全部樓層
感謝分享!
ID:86901 發(fā)表于 2019-12-31 12:00 | 顯示全部樓層
謝謝!。!參考一下!
ID:58110 發(fā)表于 2020-2-6 10:23 | 顯示全部樓層
學(xué)習(xí)分享。!
ID:142383 發(fā)表于 2020-2-19 21:23 | 顯示全部樓層
謝謝分享,學(xué)習(xí)學(xué)習(xí)!
ID:834436 發(fā)表于 2021-7-11 19:14 | 顯示全部樓層
怎么沒(méi)看到主函數(shù)
