查看: 1714|回復(fù): 0
基于5單片機(jī)的秒表程序
ID:232181 發(fā)表于 2017-9-10 09:30 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
sbit dula=P2^6;
sbit wela=P2^7;
sbit led1=P1^0;
uchar num1,hao,miao,fen,shi,A,K,C,D,E,F;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
uchar code table1[]={
0xbf,0x86,0xdb,0xcf,
0xe6,0xed,0xfd,0x87,
0xff,0xef,0xf7,0xfc,
0xb9,0xde,0xf9,0xf1};
void delayms(uint z)
uint i, j;
for(i=z;i>0;i--)
    for(j=110;j>0;j--);
void display(uchar A,uchar K,uchar C,uchar D,uchar E,uchar F)
         dula=1;
         P0=table[A];
         dula=0;
         P0=0xff;
         wela=1;
         P0=0xfe;
         wela=0;
         delayms(1);
         dula=1;
         P0=table1[K];
         dula=0;
         P0=0xff;
         wela=1;
         P0=0xfd;
         wela=0;
         delayms(1);
         dula=1;
         P0=table[C];
         dula=0;
         P0=0xff;
         wela=1;
         P0=0xfb;
         wela=0;
         delayms(1);
         dula=1;
         P0=table1[D];
         dula=0;
         P0=0xff;
         wela=1;
         P0=0xf7;
         wela=0;
         delayms(1);
         dula=1;
         P0=table[E];
         dula=0;
         P0=0xff;
         wela=1;
         P0=0xef;
         wela=0;
         delayms(1);
         dula=1;
         P0=table[F];
         dula=0;
         P0=0xff;
         wela=1;
         P0=0xdf;
         wela=0;
         delayms(1);
void TO_time() interrupt 1
     TH0=(65536-45872)/256;
         TL0=(65536-45872)%256;
         num1++;
         if(num1==20)
                num1=0;
                led1=led1;
void T1_time() interrupt 3
     TH1=(65536-45872)/256;
         TL1=(65536-45872)%256;
             hao++;
                 if(hao==20)
                        hao=0;
                        miao++;
                        if(miao==60)
                          miao=0;
                          fen++;
             if(fen==60)
                           fen=0;
                           shi++;
                          if(shi==24)
                             shi=0;
        A=shi%10;
        K=shi/10;
        C=fen/10;
        D=fen%10;
        E=miao/10;
        F=miao%10;
         TMOD=0X11;
         EA=1;
         ET0=1;
         TR0=1;
         TR1=1;
         ET1=1;
                    display(A,K,C,D,E,F);
