查看: 10737|回復(fù): 15
VB開(kāi)發(fā)的串口與三菱FX PLC通訊源碼
ID:232819 發(fā)表于 2017-9-13 10:17 | 顯示全部樓層 |閱讀模式
vb源程序如下:
  1. Private Sub fraComm2_MouseMove(Button As Integer, Shift As Integer, X As Single, Y As Single)
  2.         lblTopic = "設(shè)置連接PLC的通信端口以及PLC的站號(hào)(應(yīng)與D8121相同)"
  3. End Sub
  4. Private Sub Frame1_MouseMove(Button As Integer, Shift As Integer, X As Single, Y As Single)
  5.         lblTopic = "實(shí)時(shí)監(jiān)控/設(shè)置PLC的XYMTCD設(shè)備值"
  6. End Sub
  7. Private Sub OptionD_MouseMove(Button As Integer, Shift As Integer, X As Single, Y As Single)
  8.         lblTopic = "數(shù)據(jù)以十進(jìn)制方式返回或設(shè)置"
  9. End Sub
  10. Private Sub OptionH_MouseMove(Button As Integer, Shift As Integer, X As Single, Y As Single)
  11.         lblTopic = "數(shù)據(jù)以十六進(jìn)制方式返回或設(shè)置"
  12. End Sub
  13. Private Sub SETRST_MouseMove(Button As Integer, Shift As Integer, X As Single, Y As Single)
  14.         lblTopic = "對(duì)位元件(X,Y,M,T,C)線圈置位與復(fù)位"
  15. End Sub
  16. Private Sub Text1_KeyDown(KeyCode As Integer, Shift As Integer)
  17.     SETRST.Enabled = False
  18.     start = False
  19.     fraComm1.Visible = True
  20.     fraComm2.Visible = True
  21. End Sub
  22. Private Sub Text1_KeyPress(KeyAscii As Integer)
  23.     char = Chr(KeyAscii)
  24.     setaddr = Text1.Text
  25.     If Len(setaddr) > 1 Then: setad = Right(setaddr, Len(setaddr) - 1)
  26.     KeyAscii = Asc(UCase(char)) '轉(zhuǎn)換為大寫(xiě)
  27.
  28.     If KeyAscii = 13 Then '按回車(chē)鍵
  29.         Device = Left(setaddr, 1)
  30.         Text1.SelStart = 0
  31.         Text1.SelLength = Len(setaddr)
  32.         Text2.Enabled = True
  33.         If (Device = "X" Or Device = "Y" And Oct(Val("&o" + setad)) = setad And Val(setad) < 178) Or (Device = "M" And CStr(Val(setad)) = setad And (Val(setad) < 1536 Or Val(setad) > 7999 And Val(setad) < 8256)) Then
  34.             DevAdd = Right(("0000" + setad), 4)
  35.             DevDat = cboStation.Text + "FFBR0" + Device + DevAdd + "01"
  36.             DevType = "XYM"
  37.             Text2.Enabled = False
  38.             SETRST.Enabled = True
  39.             start = True
  40.         End If
  41.         If Device = "D" And CStr(Val(setad)) = setad And (Val(setad) < 1000 Or Val(setad) > 7999 And Val(setad) < 8256) Then
  42.             DevAdd = Right(("0000" + setad), 4)
  43.             If Check1.Value = 0 Then
  44.                 DevDat = cboStation.Text + "FFWR0" + Device + DevAdd + "01" '使用WR命令讀16bit數(shù)據(jù)
  45.                 DevType = "D"
  46.             Else
  47.                 DevDat = cboStation.Text + "FFWR0" + Device + DevAdd + "02" '使用WR命令讀32bit數(shù)據(jù)
  48.                 DevType = "2D"
  49.             End If
  50.             SETRST.Enabled = False
  51.             start = True
  52.         End If
  53.         If Device = "T" And CStr(Val(setad)) = setad And Val(setad) < 256 Then
  54.             DevAdd = Right(("000" + setad), 3)
  55.             DevDatTC = cboStation.Text + "FFBR0" + Device + "S" + DevAdd + "01" 'T的線圈狀態(tài)
  56.             DevDat = cboStation.Text + "FFWR0" + Device + "N" + DevAdd + "01" 'T的數(shù)據(jù)值
  57.             DevType = "D"
  58.             SETRST.Enabled = True
  59.             start = True
  60.         End If
  61.         If Device = "C" And CStr(Val(setad)) = setad And Val(setad) < 256 Then
  62.             DevAdd = Right(("000" + setad), 3)
  63.             DevDatTC = cboStation.Text + "FFBR0" + Device + "S" + DevAdd + "01" 'C的線圈狀態(tài)
  64.             If Val(setad) > 199 Then
  65.                 DevDat = cboStation.Text + "FFWR0" + Device + "N" + DevAdd + "01" 'C200以上的數(shù)據(jù)值
  66.                 DevType = "2D"
  67.             Else
  68.                 DevDat = cboStation.Text + "FFWR0" + Device + "N" + DevAdd + "01" 'C200以下的數(shù)據(jù)值
  69.                 DevType = "D"
  70.             End If
  71.             SETRST.Enabled = True
  72.             start = True
  73.         End If
  74.         fraComm1.Visible = False
  75.         fraComm2.Visible = False
  76.     Else
  77.         start = False
  78.         fraComm1.Visible = True
  79.         fraComm2.Visible = True
  80.     End If
  81. End Sub
  82.
  83. Private Sub Text1_MouseMove(Button As Integer, Shift As Integer, X As Single, Y As Single)
  84.         lblTopic = "輸入要監(jiān)控或設(shè)置的地址回車(chē)確定,如D0,T10,Y7等"
  85. End Sub
  86. Private Sub Text2_KeyDown(KeyCode As Integer, Shift As Integer)
  87.         If KeyCode <> 13 Then
  88.             start = False
  89.         End If
  90. End Sub
  91. Private Sub Text2_KeyPress(KeyAscii As Integer)
  92.     char = Chr(KeyAscii)
  93.     KeyAscii = Asc(UCase(char))
  94.     If Device = "D" And CStr(Val(setad)) = setad And Val(setad) < 1000 Then
  95.         start = False
  96.     End If
  97.     If (Device = "T" Or Device = "C") And CStr(Val(setad)) = setad And Val(setad) < 256 Then
  98.         start = False
  99.     End If
  100.     If KeyAscii = 13 Then
  101.       If Val(DevAdd) > 7999 Then
  102.          If MsgBox("改變系統(tǒng)參數(shù)可能對(duì)系統(tǒng)造成破壞,是否寫(xiě)入?", vbOKCancel + vbCritical) = vbCancel Then Exit Sub
  103.       ElseIf MsgBox("改變當(dāng)前值可能對(duì)運(yùn)行造成危險(xiǎn),是否寫(xiě)入?", vbOKCancel + vbExclamation) = vbCancel Then Exit Sub
  104.       End If
  105.             If Device = "D" And Check1.Value = 0 Then
  106.                 DevAdd = Right(("0000" + setad), 4)
  107.             ElseIf Device = "D" And Check1.Value = 1 Then
  108.                 DevAdd = Right(("0000" + setad), 4)
  109.             Else
  110.                 DevAdd = Right(("000" + setad), 3)
  111.             End If
  112.             If OptionD.Value Then '十進(jìn)制方式
  113.                 If Device = "C" And Val(setad) > 199 Then 'C200以上寫(xiě)入
  114.                     If Val(Text2.Text) > 2847483647# Then: GoTo this
  115.                     DevDat1 = cboStation.Text + "FFWW0" + Device + "N" + DevAdd + "01" + Right("00000000" + Hex(Val(Text2.Text)), 8)
  116.                 ElseIf Device = "D" And Check1.Value = 1 Then '雙字節(jié)D寫(xiě)入
  117.                     If Val(Text2.Text) > 2847483647# Then: GoTo this
  118.                     DevDat1 = Right("00000000" + Hex(Val(Text2.Text)), 8)
  119.                     DevDat1 = Right(DevDat1, 4) + Left(DevDat1, 4)
  120.                     DevDat1 = cboStation.Text + "FFWW0" + Device + DevAdd + "02" + DevDat1
  121.                 Else
  122.                     If Val(Text2.Text) > 32767 Then: GoTo this
  123.                     If Device = "D" Then '單字節(jié)D寫(xiě)入
  124.                         DevDat1 = cboStation.Text + "FFWW0" + Device + DevAdd + "01" + Right("0000" + Hex(Val(Text2.Text)), 4)
  125.                     Else 'C200以下寫(xiě)入
  126.                         DevDat1 = cboStation.Text + "FFWW0" + Device + "N" + DevAdd + "01" + Right("0000" + Hex(Val(Text2.Text)), 4)
  127.                     End If
  128.                 End If
  129.             Else '十六進(jìn)制方式
  130.                 If Device = "C" And Val(setad) > 199 Then 'C200以上寫(xiě)入
  131.                     If Val("&H" + Text2.Text) > 2847483647# Then: GoTo this
  132.                     DevDat1 = cboStation.Text + "FFWW0" + Device + "N" + DevAdd + "01" + Right("00000000" + Text2.Text, 8)
  133.                 ElseIf Device = "D" And Check1.Value = 1 Then '雙字節(jié)D寫(xiě)入
  134.                     If Val("&H" + Text2.Text) > 2847483647# Then: GoTo this
  135.                     DevDat1 = Right("00000000" + Text2.Text, 8)
  136.                     DevDat1 = Right(DevDat1, 4) + Left(DevDat1, 4)
  137.                     DevDat1 = cboStation.Text + "FFWW0" + Device + DevAdd + "02" + DevDat1
  138.                 Else
  139.                     If Val("&H" + Text2.Text) > 32767 Then: GoTo this
  140.                     If Device = "D" Then '單字節(jié)D寫(xiě)入
  141.                         DevDat1 = cboStation.Text + "FFWW0" + Device + DevAdd + "01" + Right("0000" + Text2.Text, 4)
  142. ……………………
  143. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
VB開(kāi)發(fā)的串口與三菱FX PLC通訊源碼.rar (19.54 KB, 下載次數(shù): 140)
ID:272098 發(fā)表于 2018-1-5 19:48 | 顯示全部樓層
感謝樓主分享
ID:33634 發(fā)表于 2018-5-24 21:10 | 顯示全部樓層
謝謝分享。
ID:219903 發(fā)表于 2018-6-20 14:37 | 顯示全部樓層
謝謝分享,無(wú)遠(yuǎn)程連接是怎么回事?
ID:361620 發(fā)表于 2018-7-24 18:17 | 顯示全部樓層
感謝樓主分享
ID:386518 發(fā)表于 2018-8-15 13:40 | 顯示全部樓層
樓主高人
ID:395920 發(fā)表于 2018-9-10 10:50 | 顯示全部樓層
支持,支持分享
ID:138443 發(fā)表于 2018-10-18 23:45 | 顯示全部樓層
太好了,謝謝了
ID:373838 發(fā)表于 2018-10-20 08:42 | 顯示全部樓層
太好了,謝謝了。!
ID:23309 發(fā)表于 2019-10-29 19:12 | 顯示全部樓層
感謝樓主分享
ID:646618 發(fā)表于 2019-11-21 16:32 | 顯示全部樓層
感謝樓主分享  試試看
ID:715003 發(fā)表于 2020-4-11 21:53 | 顯示全部樓層
下載了不是你說(shuō)的這個(gè)呢??
有原件嗎發(fā)給我好嗎?
ID:750448 發(fā)表于 2020-5-13 03:43 | 顯示全部樓層
謝謝分享~剛好可以用來(lái)最近在研究的
ID:750209 發(fā)表于 2020-6-27 17:11 | 顯示全部樓層
感謝樓主分享
ID:47634 發(fā)表于 2020-7-6 06:56 | 顯示全部樓層
很好很好,感謝樓主的好資料,下載學(xué)習(xí)了
ID:963949 發(fā)表于 2021-9-4 08:47 | 顯示全部樓層
已下載,多謝樓主分享1~
