查看: 1507|回復(fù): 0
12864萬年歷程序
ID:233078 發(fā)表于 2017-9-14 11:56 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  參數(shù)  AT89S52MCS-51 12MHZ
//程序部分開始//
//頭文件
//#include <AT89X52.h>
#include <string.h>
#include<reg52.h>
//燈與揚聲器定義
sbit led_back =  P1^0;//
sbit led_b =  P2^3;//秒閃爍燈
sbit led_r =  P2^4;
sbit led_g1 = P2^5;//
sbit led_g2 = P2^5;
sbit led_g3 = P2^5;
sbit led_g4 = P2^5;
sbit beep   = P1^1;//
//溫度傳感器定義
sbit DQ = P1 ^ 6;//ds18B20
//鍵盤引腳定義
sbit KEY_1 = P3^0;  //左上
sbit KEY_2 = P3^1;  //左下
sbit KEY_3 = P3^2;  //右上
sbit KEY_4 = P3^3;  //右下
sbit KEY_I = P3^4;  //
//LCD接口定義
sbit RS = P2^0;//模式位為0輸入指令為1輸入數(shù)據(jù)
sbit RW = P2^1;//讀寫位為0讀為1寫
sbit E = P2^2;//使能位
#define Lcd_Bus P0 //數(shù)據(jù)總線
//定義DS1302時鐘接口
sbit clock_clk = P3 ^ 7;//ds1302_clk時鐘線
sbit clock_dat = P3 ^ 6;//ds1302_dat數(shù)據(jù)線
sbit clock_Rst = P3 ^ 5;//ds1302_Rst復(fù)位線
//定義累加器A中的各位
sbit a0   = ACC ^ 0;
sbit a1   = ACC ^ 1;
sbit a2   = ACC ^ 2;
sbit a3   = ACC ^ 3;
sbit a4   = ACC ^ 4;
sbit a5   = ACC ^ 5;
sbit a6   = ACC ^ 6;
sbit a7   = ACC ^ 7;
//定義全局變量
unsigned char yy,mo,dd,xq,hh,mm,ss;//定義時間映射全局變量專用寄存器
bit w = 0; //調(diào)時標志位
static unsigned char menu = 0;//定義靜態(tài)小時更新用數(shù)據(jù)變量
static unsigned char keys = 0;//定義靜態(tài)小時更新用數(shù)據(jù)變量
static unsigned char timecount = 0;//定義靜態(tài)軟件計數(shù)器變量
void DelayM(unsigned int a){//延時函數(shù) 1MS/次
  unsigned char i;
  while( --a != 0){
   for(i = 0; i < 125; i++);  //一個 ; 表示空語句,CPU空轉(zhuǎn)。
  }          //i 從0加到125CPU大概就耗時1毫秒
//LCD驅(qū)動
void chk_busy(){//檢查忙位底層
   RS=0;
   RW=1;
   E=1;
   Lcd_Bus=0xff;
   while((Lcd_Bus&0x80)==0x80);
   E=0;
void write_com(unsigned char cmdcode){//寫命令到LCD底層
chk_busy();
RS=0;
RW=0;
E=1;
Lcd_Bus=cmdcode;
E=0;
void write_data(unsigned char Dispdata){  //寫數(shù)據(jù)到LCD底層
chk_busy();
RS=1;
RW=0;
E=1;
Lcd_Bus=Dispdata;
E=0;
void lcm_init(){//初始化LCD屏被調(diào)用層
   write_com(0x30);       //選擇8bit數(shù)據(jù)流
   write_com(0x0c);       //開顯示(無游標、不反白)
   write_com(0x01);       //清除顯示并且設(shè)定地址指針為00H
void lcm_w_word(unsigned char *s){//向LCM發(fā)送一個字符串,長度64字符之內(nèi)。被調(diào)用層
while(*s>0){     //應(yīng)用lcm_w_word("您好");
     write_data(*s);
     s++;
void lcm_w_test(bit i,unsigned char word){//寫指令或數(shù)據(jù)被調(diào)用層
if(i == 0){
  write_com(word);//寫指令或數(shù)據(jù)0指令
}else{
  write_data(word);//寫指令或數(shù)據(jù)1數(shù)據(jù)
void lcm_clr(void){//清屏函數(shù)
lcm_w_test(0,0x01);
//公歷節(jié)日數(shù)據(jù)庫表
void days (void) {   //公歷節(jié)日數(shù)據(jù)庫
  lcm_w_test(0,0x80);//在屏幕第一行
  lcm_w_word("[Dis]      [Set]");//顯示菜單操作注釋
  lcm_w_test(0,0x98);//在屏幕第四行
  if ( mo == 0x01 && dd == 0x01 ){ lcm_w_word("Happy New Year!!"); }//1月
  if ( mo == 0x02 && dd == 0x02 ){ lcm_w_word("  世界濕地日    "); }//2月
  if ( mo == 0x02 && dd == 0x13 ){ lcm_w_word("  明天情人節(jié)了  "); }
  if ( mo == 0x02 && dd == 0x14 ){ lcm_w_word("  今天是情人節(jié)  "); }
  if ( mo == 0x03 && dd == 0x01 ){ lcm_w_word("  國際海豹日    "); }//3月
  if ( mo == 0x03 && dd == 0x03 ){ lcm_w_word("  全國愛耳日    "); }
  if ( mo == 0x03 && dd == 0x08 ){ lcm_w_word("   3.8婦女節(jié)    "); }
  if ( mo == 0x03 && dd == 0x12 ){ lcm_w_word("    植樹節(jié)      "); }
  if ( mo == 0x03 && dd == 0x14 ){ lcm_w_word("  國際警察日    "); }
  if ( mo == 0x03 && dd == 0x15 ){ lcm_w_word("  消費者權(quán)益日  "); }
  if ( mo == 0x03 && dd == 0x17 ){ lcm_w_word("  國際航海日    "); }
  if ( mo == 0x03 && dd == 0x21 ){ lcm_w_word("  世界森林日    "); }
  if ( mo == 0x03 && dd == 0x22 ){ lcm_w_word("    世界水日    "); }
  if ( mo == 0x03 && dd == 0x23 ){ lcm_w_word("  世界氣象日    "); }
  if ( mo == 0x03 && dd == 0x24 ){ lcm_w_word("世界防治結(jié)核病日"); }
  if ( mo == 0x04 && dd == 0x01 ){ lcm_w_word("愚人節(jié)  小心上當"); }//4
  if ( mo == 0x04 && dd == 0x07 ){ lcm_w_word("  世界衛(wèi)生日    "); }
  if ( mo == 0x04 && dd == 0x08 ){ lcm_w_word("    復(fù)活節(jié)      "); }
  if ( mo == 0x04 && dd == 0x13 ){ lcm_w_word("  黑色星期五    "); }
  if ( mo == 0x05 && dd == 0x01 ){ lcm_w_word("  勞動節(jié)  放假  "); }//5
  if ( mo == 0x05 && dd == 0x04 ){ lcm_w_word("    青年節(jié)      "); }
  if ( mo == 0x05 && dd == 0x08 ){ lcm_w_word("  世界紅十字日  "); }
  if ( mo == 0x05 && dd == 0x12 ){ lcm_w_word("  國際護士節(jié)    "); }
  if ( mo == 0x05 && dd == 0x05 ){ lcm_w_word("近日注意母親節(jié)  "); }
  if ( mo == 0x05 && dd == 0x15 ){ lcm_w_word("  國際家庭日    "); }
  if ( mo == 0x05 && dd == 0x31 ){ lcm_w_word("  世界無煙日    "); }
  if ( mo == 0x06 && dd == 0x01 ){ lcm_w_word("  國際兒童節(jié)    "); }//6
  if ( mo == 0x06 && dd == 0x05 ){ lcm_w_word("  世界環(huán)境日    "); }
  if ( mo == 0x06 && dd == 0x26 ){ lcm_w_word("  國際禁毒日    "); }
  if ( mo == 0x06 && dd == 0x06 ){ lcm_w_word("  全國愛眼日    "); }
  if ( mo == 0x06 && dd == 0x13 ){ lcm_w_word("近日注意父親節(jié)  "); }
  if ( mo == 0x06 && dd == 0x15 ){ lcm_w_word("近日注意父親節(jié)  "); }
  if ( mo == 0x07 && dd == 0x01 ){ lcm_w_word("香港回歸記念日  "); }//7
  if ( mo == 0x07 && dd == 0x07 ){ lcm_w_word("抗日戰(zhàn)爭記念日  "); }
  if ( mo == 0x07 && dd == 0x11 ){ lcm_w_word("  世界人口日    "); }
  if ( mo == 0x08 && dd == 0x01 ){ lcm_w_word("  八一建軍節(jié)    "); }//8
  if ( mo == 0x08 && dd == 0x08 ){ lcm_w_word("  中國男子節(jié)    "); }
  if ( mo == 0x08 && dd == 0x15 ){ lcm_w_word("抗戰(zhàn)勝利記念日  "); }
  if ( mo == 0x09 && dd == 0x10 ){ lcm_w_word("  中國教師節(jié)    "); }//9
  if ( mo == 0x09 && dd == 0x18 ){ lcm_w_word("九·一八事變記念"); }
  if ( mo == 0x09 && dd == 0x20 ){ lcm_w_word("  國際愛牙日    "); }
  if ( mo == 0x09 && dd == 0x27 ){ lcm_w_word("  世界旅游日    "); }
  if ( mo == 0x10 && dd == 0x01 ){ lcm_w_word("  中國國慶節(jié)    "); }//10
  if ( mo == 0x10 && dd == 0x04 ){ lcm_w_word("  世界動物日    "); }
  if ( mo == 0x10 && dd == 0x24 ){ lcm_w_word("    聯(lián)合國日    "); }
  if ( mo == 0x10 && dd == 0x12 ){ lcm_w_word("明天國際教師節(jié)  "); }
  if ( mo == 0x10 && dd == 0x13 ){ lcm_w_word("  國際教師節(jié)    "); }
  if ( mo == 0x11 && dd == 0x10 ){ lcm_w_word("  世界青年節(jié)    "); }//11
  if ( mo == 0x11 && dd == 0x17 ){ lcm_w_word("  世界學(xué)生節(jié)    "); }
  if ( mo == 0x12 && dd == 0x01 ){ lcm_w_word("  世界艾滋病日  "); }//12
  if ( mo == 0x12 && dd == 0x23 ){ lcm_w_word("  明晚平安夜    "); }
  if ( mo == 0x12 && dd == 0x24 ){ lcm_w_word("  今晚平安夜    "); }
  if ( mo == 0x12 && dd == 0x25 ){ lcm_w_word("    圣誕快樂    "); }
  if ( mo == 0x12 && dd == 0x31 ){ lcm_w_word("    明日新年    "); }
  else{//非節(jié)日時顯示時晨信息
   if ( hh >= 0x04 && hh <  0x06 ){ lcm_w_word("★★__▲▲__凌晨"); }
   if ( hh >= 0x06 && hh <  0x08 ){ lcm_w_word("☆○__▲△__早晨"); }
   if ( hh >= 0x08 && hh <  0x12 ){ lcm_w_word("__●__▲▲__上午"); }
   if ( hh == 0x12)               { lcm_w_word("____▲●▲__中午"); }
   if ( hh >= 0x13 && hh <  0x18 ){ lcm_w_word("__▲▲__●__下午"); }
   if ( hh >= 0x18 && hh <  0x22 ){ lcm_w_word("△▲__●☆__晚上"); }
   if ( hh >= 0x22 && hh <= 0x23 ){ lcm_w_word("△▲__★☆__夜里"); }
   if ( hh >= 0x00 && hh <  0x04 ){ lcm_w_word("__★▲▲★__深夜"); }
//DS18B20溫度傳感器驅(qū)動顯示0至60度
void Delay(int num){//延時函數(shù)
while(num--) ;
void Init_DS18B20(void){//初始化ds1820
unsigned char x=0;
DQ = 1;    //DQ復(fù)位
Delay(8);  //稍做延時
DQ = 0;    //單片機將DQ拉低
Delay(80); //精確延時 大于 480us
DQ = 1;    //拉高總線
Delay(14);
x=DQ;      //稍做延時后 如果x=0則初始化成功 x=1則初始化失敗
Delay(20);
unsigned char ReadOneChar(void){//讀一個字節(jié)
unsigned char i=0;
unsigned char dat = 0;
for (i=8;i>0;i--){
  DQ = 0; // 給脈沖信號
  dat>>=1;
  DQ = 1; // 給脈沖信號
  if(DQ)
  dat|=0x80;
  Delay(4);
return(dat);
void WriteOneChar(unsigned char dat){//寫一個字節(jié)
unsigned char i=0;
for (i=8; i>0; i--){
  DQ = 0;
  DQ = dat&0x01;
  Delay(5);
  DQ = 1;
  dat>>=1;
unsigned int ReadTemperature(void){//讀取溫度
unsigned char a=0;
unsigned char b=0;
unsigned int t=0;
float tt=0;
Init_DS18B20();
WriteOneChar(0xCC); // 跳過讀序號列號的操作
WriteOneChar(0x44); // 啟動溫度轉(zhuǎn)換
Init_DS18B20();
WriteOneChar(0xCC); //跳過讀序號列號的操作
WriteOneChar(0xBE); //讀取溫度寄存器
a=ReadOneChar();  //讀低8位
b=ReadOneChar(); //讀高8位
t=b;
t<<=8;
t=t|a;
tt=t*0.0625;
t= tt*10+0.5; //放大10倍輸出并四舍五入
return(t);
//聲明當各函數(shù)的排列適當時可不用聲明
void lcm_w_ss(void);
void lcm_w_mm(void);
void lcm_w_hh(void);
void lcm_w_dd(void);
void lcm_w_mo(void);
void lcm_w_yy(void);
void lcm_w_xq(void);
unsigned char clock_in(void);
void clock_out(unsigned char dd);
void Init_1302(void);
unsigned char read_clock(unsigned char ord);
void read_clockS(void);
void Set_time(unsigned char sel);
void write_clock(unsigned char ord, unsigned char dd);
void updata (void);
//DS1302時鐘芯片驅(qū)動程序
//常用時鐘數(shù)據(jù)讀取
void read_clockS(void){
ss = read_clock(0x81);//讀取秒數(shù)據(jù)
mm = read_clock(0x83);//讀取分鐘數(shù)據(jù)
hh = read_clock(0x85);//小時
dd = read_clock(0x87);//日
mo = read_clock(0x89);//月
xq = read_clock(0x8b);//星期
yy = read_clock(0x8d);//年
//調(diào)時用加1程序
void Set_time(unsigned char sel){ //根據(jù)選擇調(diào)整的相應(yīng)項目加1并寫入DS1302
  signed char address,item;
  signed char max,mini;
  lcm_w_test(0,0x9a);
  lcm_w_word("調(diào)整");
//if(sel==6)  {lcm_w_word("秒鐘");address=0x80; max=0;mini=0;}     //秒7
  if(sel==5)  {lcm_w_word("分鐘");address=0x82; max=59;mini=0;}    //分鐘6
  if(sel==4)  {lcm_w_word("小時");address=0x84; max=23;mini=0;}    //小時5
  if(sel==3)  {lcm_w_word("星期");address=0x8a; max=7;mini=1;}    //星期4
  if(sel==2)  {lcm_w_word("日期");address=0x86; max=31;mini=1;}    //日3
  if(sel==1)  {lcm_w_word("月份");address=0x88; max=12;mini=1;}    //月2
  if(sel==0)  {lcm_w_word("年份");address=0x8c; max=99; mini=0;}    //年1
  //讀取1302某地址上的數(shù)值轉(zhuǎn)換成10進制賦給item
  item=((read_clock(address+1))/16)*10 + (read_clock(address+1))%16;
  if(KEY_2 == 0){
   item++;//數(shù)加 1
  if(KEY_4 == 0){
   item--;//數(shù)減 1
  if(item>max) item=mini;//查看數(shù)值有效范圍
  if(item<mini) item=max;
write_clock(0x8e,0x00);//允許寫操作
  write_clock(address,(item/10)*16+item%10);//轉(zhuǎn)換成16進制寫入1302
  write_clock(0x8e,0x80);//寫保護禁止寫操作
  updata (); //刷新數(shù)據(jù)
  lcm_w_mm();//刷新 分
//設(shè)置1302的初始時間自動初始化
void Init_1302(void){//-設(shè)置1302的初始時間2007年1月1日00時00分00秒星期一
unsigned char f;
if(read_clock(0xc1) != 0xaa){
  write_clock(0x8c,0x07);//年
  write_clock(0x8a,0x01);//星期
  write_clock(0x88,0x01);//月
  write_clock(0x86,0x01);//日
  write_clock(0x84,0x00);//小時
  write_clock(0x82,0x00);//分鐘
  write_clock(0x80,0x00);//秒
  write_clock(0x90,0xa5);//充電
  write_clock(0xc0,0xaa);//寫入初始化標志RAM第00個RAM位置
  for(f=0;f<60;f=f+2)
  {//清除鬧鐘RAM位為0
  write_clock(0xc2+f,0x00);
  write_clock(0x8e,0x80);//禁止寫操作
//DS1302寫數(shù)據(jù)底層協(xié)議
void write_clock(unsigned char ord, unsigned char dd){
clock_clk=0;
clock_Rst=0;
clock_Rst=1;
clock_out(ord);
clock_out(dd);
clock_Rst=0;
clock_clk=1;
//1302驅(qū)動程序底層協(xié)議
void clock_out(unsigned char dd){
ACC=dd;
clock_dat=a0; clock_clk=1; clock_clk=0;
clock_dat=a1; clock_clk=1; clock_clk=0;
clock_dat=a2; clock_clk=1; clock_clk=0;
clock_dat=a3; clock_clk=1; clock_clk=0;
clock_dat=a4; clock_clk=1; clock_clk=0;
clock_dat=a5; clock_clk=1; clock_clk=0;
clock_dat=a6; clock_clk=1; clock_clk=0;
clock_dat=a7; clock_clk=1; clock_clk=0;
//DS1302寫入字節(jié)底層協(xié)議
unsigned char clock_in(void){
clock_dat=1;
a0=clock_dat;
clock_clk=1; clock_clk=0; a1=clock_dat;
clock_clk=1; clock_clk=0; a2=clock_dat;
clock_clk=1; clock_clk=0; a3=clock_dat;
clock_clk=1; clock_clk=0; a4=clock_dat;
clock_clk=1; clock_clk=0; a5=clock_dat;
clock_clk=1; clock_clk=0; a6=clock_dat;
clock_clk=1; clock_clk=0; a7=clock_dat;
return(ACC);
//DS1302讀數(shù)據(jù)底層協(xié)議
unsigned char read_clock(unsigned char ord){
unsigned char dd=0;
clock_clk=0;
clock_Rst=0;
clock_Rst=1;
clock_out(ord);
dd=clock_in();
clock_Rst=0;
clock_clk=1;
return(dd);
void Beep(void){//BELL-揚聲器--整點報時
unsigned char a;//定義變量用于發(fā)聲的長度設(shè)置
for(a=60;a>0;a--){//第一個聲音的長度
  beep = ~beep;//取反揚聲器驅(qū)動口以產(chǎn)生音頻
Delay(100);//音調(diào)設(shè)置延時
for(a=100;a>0;a--){//同上
  beep = ~beep;
  Delay(80);//
  beep = ~beep;
  Delay(30);//
beep = 1;//音樂結(jié)束后揚聲器拉高關(guān)閉
void Beep_set(void){//BELL -揚聲器--確定設(shè)置
for(a=50;a>0;a--){//第一個聲音的長度
  beep = ~beep;
  Delay(50);//
for(a=50;a>0;a--){//同上
  beep = ~beep;
  Delay(100);//
void Beep_key(void){//-揚聲器--按鍵音
for(a=100;a>0;a--){//聲音的長度
  beep = ~beep;
  Delay(50);//音調(diào)設(shè)置延時
//向LCM中填寫 年 數(shù)據(jù)
void lcm_w_yy(void){
//if(read_clock(0x8d) != yy){
  lcm_w_test(0,0x83);
  lcm_w_word("20");
  lcm_w_test(0,0x84);
  lcm_w_test(1,(yy/16)+0x30);
  lcm_w_test(1,yy%16+0x30);
//向LCM中填寫 月 數(shù)據(jù)
void lcm_w_mo(void){
//if(read_clock(0x89) != mo){
  lcm_w_test(0,0x90);
   if(mo/16 != 0){lcm_w_test(1,(mo/16)+0x30);} //十位消隱
   else{lcm_w_test(1,0x20);}//同上
  lcm_w_test(1,mo%16+0x30);
  lcm_w_test(0,0x91);
  lcm_w_word("月");
//星期處理并送入LCM的指定區(qū)域
void lcm_w_xq(void){
unsigned char sel;
//if(read_clock(0x8b) != xq){
sel = (read_clock(0x8b))%16; //字節(jié)低4位的BCD碼放入sel
lcm_w_test(0,0x97);//寫入指定區(qū)域97H 第二行第8個字
if(sel==7)  {lcm_w_word("日");}    //
   if(sel==6)  {lcm_w_word("六");}    //
   if(sel==5)  {lcm_w_word("五");}    //
   if(sel==4)  {lcm_w_word("四");}    //
   if(sel==3)  {lcm_w_test(1,0xc8);lcm_w_test(1,0xfd);} //此指令等于lcm_w_word("三"); 因為“三”的內(nèi)碼失效。
   if(sel==2)  {lcm_w_word("二");}    //
   if(sel==1)  {lcm_w_word("一");}    //星期一
lcm_w_test(0,0x95);
lcm_w_word("星期");
//向LCM中填寫 日 數(shù)據(jù)
void lcm_w_dd(void){
// if(read_clock(0x87) != dd){
  lcm_w_test(0,0x92);
   if(dd/16 != 0){lcm_w_test(1,(dd/16)+0x30);} //十位消隱
  lcm_w_test(1,dd%16+0x30);
  lcm_w_test(0,0x93);
  lcm_w_word("日  ");
//向LCM中填寫 小時 數(shù)據(jù)
void lcm_w_hh(void){
if(read_clock(0x85) != hh){
   if (hh > 0x07 && hh < 0x22 && w == 0){
    Beep();//整點報時音
  lcm_w_test(0,0x88);
  lcm_w_test(1,(hh/16)+0x30);
  lcm_w_test(1,hh%16+0x30);
//向LCM中填寫 分鐘 數(shù)據(jù)
void lcm_w_mm(void)
if(read_clock(0x83) != mm){
  if(w == 0)
   days();//節(jié)日顯示
lcm_w_test(0,0x89);
lcm_w_test(1,0x3a);   //":"
lcm_w_test(1,(mm/16)+0x30);
lcm_w_test(1,mm%16+0x30);
lcm_w_test(1,0x2e);  //"."
//刷新數(shù)據(jù)
void updata (void){
  lcm_w_mm();//刷新 分
  lcm_w_hh();//刷新 小時
  lcm_w_dd();//刷新 日
lcm_w_xq();//更新星期值
  lcm_w_mo();//刷新 月
  lcm_w_yy();//刷新 年
//向LCM中填寫 秒 數(shù)據(jù)
void lcm_w_ss(void){
unsigned int i=0;
unsigned char a=0,b=0,c=0;
if(read_clock(0x81) != ss){ //判斷是否需要更新
  ss = read_clock(0x81); //更新數(shù)據(jù)
  lcm_w_test(0,0x8b);  //秒值在LCM上的寫入位置
  lcm_w_test(1,(ss/16)+0x30); //寫十位
  lcm_w_test(1,ss%16+0x30); //寫個位
  lcm_w_word("  ");
  led_b = ~led_b;    //LED閃爍
  lcm_w_test(0,0x8d);  //溫度在LCM上的寫入位置
  i=ReadTemperature();//讀溫度并送顯
  a=i/100;
  lcm_w_test(1,a+0x30); //顯示溫度十位
  b=i/10-a*10;
  lcm_w_test(1,b+0x30); //個位
  c=i-a*100-b*10;
  lcm_w_test(1,c+0x30); //小位1位
  lcm_w_word("℃"); //度C
void welcome(void){
lcm_w_word("   0123456789  ABCDEFG                  ");//
//----------|-------1-------|-------3-------|-------2-------|-------4-------|-----//標尺
//---主程序---//
main() {
unsigned char e=0;
KEY_I = 0;KEY_1 = 1;KEY_2 = 1;KEY_3 = 1;KEY_4 = 1;//初始鍵盤
yy=0xff;mo=0xff;dd=0xff;xq=0xff;hh=0xff;mm=0xff;ss=0xff; //各數(shù)據(jù)刷新
Beep();
led_back = 0;
Init_1302();
lcm_init();//初始化液晶顯示器
lcm_clr();//清屏
welcome();//顯示歡迎信息
DelayM(3000); //顯示等留3秒
while(1){//主循環(huán)
  if (w == 0){   //正常走時
  lcm_w_ss();//刷新 秒
  else {  //啟動調(diào)時
  if (KEY_3 == 0) // 設(shè)置時間
         DelayM(20);    //去抖
   led_g3 = 0;led_r = 1;
   if(KEY_3 == 0 && w == 1)  //當是調(diào)時狀態(tài) 本鍵用于調(diào)整下一項
    Beep_key();//按鍵音
    e++;
    if (e >= 6 ){e = 0;}
    Set_time(e);//調(diào)整
   if(KEY_3 == 0 && w == 0)  //當是正常狀態(tài)時就進入調(diào)時狀態(tài)
    Beep_set();//確定按鍵音
    led_b = 1;//
    lcm_clr();//清屏
    w=1;   //進入調(diào)時
    lcm_w_test(0,0x9e);
    lcm_w_word(" [-]");
lcm_w_test(0,0x80);
    lcm_w_word("[Esc]");
    lcm_w_test(0,0x85);
    lcm_w_word("[Next]");
    lcm_w_test(0,0x98);
    lcm_w_word("[+]");
         while(KEY_3 == 0);//等待鍵松開
   led_g3 = 1; led_r = 0;//紅燈亮表示調(diào)時
if (KEY_1 == 0) // 當在調(diào)時狀態(tài)時就退出調(diào)時
         DelayM(20);
   led_g1 = 0;led_r = 1;
         if(KEY_1 == 0 && w == 1){
    Beep_set();//確定按鍵音
    w = 0;   //退出調(diào)時
    e = 0;  //“下一項”計數(shù)器清0
   if(KEY_1 == 0 && w == 0){
    lcm_clr();//清屏
    lcm_w_test(0,0x80);
    welcome();//顯示歡迎信息
    while(KEY_1 == 0);//等待鍵松開
    lcm_clr();//清屏
    lcm_w_mm();//刷新 分
   led_g1 = 1;
  if (KEY_2 == 0 && w == 1) // 加減調(diào)整{
         DelayM(20);
   led_g2 = 0;led_r = 1;
         if(KEY_2 == 0 && w == 1){
    Beep_key();//按鍵音
         while(KEY_2 == 0);//等待鍵松開
   led_g2 = 1; led_r = 0;
  if (KEY_4 == 0 && w == 1){ // 加減調(diào)整
         DelayM(20);
   led_g4 = 0;led_r = 1;
         if(KEY_4 == 0 && w == 1){
    Beep_key();//按鍵音
         while(KEY_4 == 0);
   led_g4 = 1; led_r = 0;
