有需要的童鞋請(qǐng)下載
SP3Muc_ccs5.3_test2MW
下載:
SP3Muc_ccs5.3_test2MW_20150707.rar
(361.38 KB, 下載次數(shù): 13)
2017-9-22 10:05 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
- * Copyright(c) Future Power Technology Co. Ltd. ALL RIGHTS RESERVED
- * Product : Main control board of 3MW modular switch power
- * File name : main.c
- * Purpose : Main function and interrupt function include cup timer0 and pwm1
- * underflow.
- * History:
- * Date Version Author Note
- * 2015-04-24 V1.0 Heaton Created.
- /*===========================Include header files===============================*/
- #include "GlobalVariableRefs.h"
- #include "GlobalVariableDefs.h"
- #include "Main.h"
- #include "FunctionCall.h"
- /*========================Prototype statements for functions====================*/
- interrupt void Epwm1_Int_isr(void);
- interrupt void Epwm1_Tz1_isr(void);
- void Task1ms(void);
- void Task2ms(void);
- void Task5ms(void);
- void Task10ms(void);
- void Task50ms(void);
- void InitXintf(void);
- void InitI2C(void);
- void ECANComm(void);
- /*================================Macro definition==============================*/
- //1/3
- #define INV_3 0.3333333
- //Run from RAM or FLASH selection with cmd file changed maunually /////////!!!!!!!!!!!
- #define FLASH_TYPE 1
- //Debug model///////////////!!!!!!!!!
- #define DEBUG_MODE 2 //0:Voltage and current closed loop 1:Current closed loop 2:Open loop
- /*===========================Global variables in this file======================*/
- int16 i161msCount = 0; //Counter of 1ms in main interrupt of 100us/10KHz
- int16 i163TmainCount = 0; //Counter of 3 times of main interrupt(71.4us/14KHz)
- int16 i163TmainFlag = 0; //Flag of 214.2us period
- float32 f32CurADSum = 0; //Current vaule sum from CPLD in 71.4us
- //Periodic task structure definition
- //Add periodic task array in function list
- //and responsible identification in ID list
- //Array definition in sub member:run flag, timer, period, fucntion
- static PRD_TSK PrdTskList[] =
- {0, 1, 1, Task1ms},
- {0, 1, 2, Task2ms},
- {0, 1, 5, Task5ms},
- {0, 1, 10, Task10ms},
- {0, 1, 50, Task50ms},
- //Add task array here...
- typedef enum PRDTSKID
- TASK_1ms,
- TASK_2ms,
- TASK_5ms,
- TASK_10ms,
- TASK_50ms,
- //Add task ID here...
- PRDTSK_MAX //Number of periodic tasks
- } PRD_TSK_ID;
- * Function: main
- * Purpose : Initialization and main loop
- * Input:
- * void
- * Output:
- * void
- * Calls:
- * System and peripheral initialization functions
- * Called by:
- * void
- void main(void)
- Uint16 i;
- //Initialize System Control:PLL, WatchDog, enable Peripheral Clocks
- InitSysCtrl();
- // Disable CPU interrupts
- DINT;
- //Initialize the PIE control registers to their default state.
- InitPieCtrl();
- //Disable CPU interrupts and clear all CPU interrupt flags:
- IER = 0x0000;
- IFR = 0x0000;
- //Initialize the PIE vector table with pointers to the shell ISR
- InitPieVectTable();
- //Interrupt configuration:
- EALLOW;
- //PieVectTable.TINT0 = &Cpu_Timer0_isr; //CPU timer0 interrupt
- PieVectTable.EPWM1_TZINT = &Epwm1_Tz1_isr; //EPWM1 tz1 interrupt
- PieVectTable.EPWM1_INT = &Epwm1_Int_isr; //EPWM1 int interrupt
- EDIS;
- //Device peripheral initializaiton
- InitXintf(); ///////!!!!!Initialize XINTF tbd...
- InitSci(); ///////!!!!!//Initialize the SCIA&SCIB tbd...
- InitECan(); //Initialize the ECANA&ECANB
- InitI2C(); //Initialize the I2C module
- InitPWM(PWM_PERIOD,PWM_DEADBAND); //Initialize the EPWM1 only for interrupt
- InitGpio(); //GPIO configure for other use///////////////!!!!!!!! tbd........
- ////////////!!!!!!!!!!!!!!1
- #if FLASH_TYPE
- //Copy all FLASH sections that need to run from RAM
- MemCopy(&RamfuncsLoadStart, &RamfuncsLoadEnd, &RamfuncsRunStart); //////!!!!!!!!!for debug
- //Initialize the FLASH
- InitFlash(); //////!!!!!!!!!for debug
- #endif
- /////////////!!!!!!!!!!!111111
- //Algorithm initial
- ParaInitTrans(); //User defined parameters, variables and structures initialization
- //Enable interrupt:
- IER |= (M_INT2 | M_INT3);
- PieCtrlRegs.PIEIER2.bit.INTx1 = 1;// Enable epwm1 tz int in the PIE: Group 2 interrupt 1
- PieCtrlRegs.PIEIER3.bit.INTx1 = 1;// Enable epwm1 int in the PIE: Group 3 interrupt 1
- // Enable global Interrupts and higher priority real-time debug events:
- EINT; // Enable Global interrupt INTM
- ERTM; // Enable Global realtime interrupt DBGM
- //EepTskInit(); ///////!!!!!Initialization must be after global interrupt is enabled
- //Main loop
- while(1)
- for(i = 0; i < PRDTSK_MAX; i++)
- if(PrdTskList[i].u16RunFlag == 1)
- PrdTskList[i].TaskHook(); //Run the function
- PrdTskList[i].u16RunFlag = 0; //Clear the flag for next running loop
- /*================================function end================================*/
- * Function: Epwm1_Int1_isr
- * Purpose : Main period interrupt of 71.4us/14KHz,
- * module period
- * current read from CPLD 71.4us
- * current PI regulation 71.4*3=214.2us
- * ECAN 71.4*3=214.2us
- * Input:
- * AD_UDCOUT
- * Output:
- * pi_cur.f32Out
- * PrdTskList[i].u16RunFlag
- * Calls:
- * void
- * Called by:
- * void
- Uint16 i, u16PwmCmp, u16PwmCmpBoost;
- float32 f32BuckDutyTmp, f32BoostDutyTmp, f32Tmp;
- //Count for 3*71.4=214.2us
- i163TmainCount++;
- if(i163TmainCount >= 3)
- i163TmainCount = 0;
- i163TmainFlag = 1;
- //AD convertion
- ADMeasure();
- //214us module
- if(i163TmainFlag == 1)
- //Average value calculation
- f32UdcOut = f32UdcOutSum * INV_3;
- f32IL[0] = f32ILSum[0] * INV_3;
- f32IL[1] = f32ILSum[1] * INV_3;
- f32IL[2] = f32ILSum[2] * INV_3;
- //f32CurADSum = (f32IL[0] + f32IL[1] + f32IL[2]);
- f32UdcOutSum = 0;
- f32ILSum[0] = 0;
- f32ILSum[1] = 0;
- f32ILSum[2] = 0;
- #if(DEBUG_MODE == 0) //Two closed loop
- f32Debug1 += 0.2;
- if(f32Debug1 >= f32UdcInRef)
- f32Debug1 = f32UdcInRef;
- //Voltage PI regulation
- pi_vol.f32Ref = f32Debug1 * INV_VOL_BASE;
- pi_vol.f32Fdb = f32UdcOut * INV_VOL_BASE;
- //Current PI regulation
- pi_cur1.f32Ref = pi_vol.f32Out;
- //////////////!!!!!!!!!!!!1for debug
- //pi_cur1.f32Ref = u16EcanCurRef * INV_CUR_BASE;
- pi_cur1.f32Fdb = f32IL[0] * INV_CUR_BASE;
- pi_cur2.f32Ref = u16EcanCurRef * INV_CUR_BASE;
- pi_cur2.f32Fdb = f32IL[1] * INV_CUR_BASE;
- pi_cur3.f32Ref = u16EcanCurRef * INV_CUR_BASE;
- pi_cur3.f32Fdb = f32IL[2] * INV_CUR_BASE;
- if(MSW.bit.RUNNING)
- pi_vol.calc(&pi_vol);
- pi_cur1.calc(&pi_cur1);
- pi_cur2.calc(&pi_cur2);
- pi_cur3.calc(&pi_cur3);
- else
- pi_vol.f32Ui = 0;
- pi_vol.f32Out = 0;
- pi_cur1.f32Ui = 0;
- pi_cur1.f32Out = 0;
- pi_cur2.f32Ui = 0;
- pi_cur2.f32Out = 0;
- pi_cur3.f32Ui = 0;
- pi_cur3.f32Out = 0;
- f32Debug1 = 0;
- f32Debug2 = 0;
- #endif
- #if(DEBUG_MODE == 1) //Current closed loop
- f32Debug1 += 0.2;
- if(f32Debug1 >= 5)
- f32Debug1 = 5;
- //////////////////////!!!!!!!!!!for debug
- //pi_cur1.f32Ref = f32Debug1 * INV_CUR_BASE;
- pi_cur1.f32Ref = u16EcanCurRef * INV_CUR_BASE;
- else
- pi_vol.f32Ui = 0;
- f32Debug1 = 0;
- f32Debug2 = 0;
- #endif
- #if(DEBUG_MODE == 2) //Open loop
- f32Tmp = (float32)u16EcanCurRef / 150;/////////////for debug
- f32Debug1 += 2e-5;
- if(f32Debug1 >= f32Tmp)
- f32Debug1 = f32Tmp;
- /*if(f32Debug1 >= 0.8)
- f32Debug1 = 0.8;
- else
- pi_vol.f32Ui = 0;
- f32Debug1 = 0;
- f32Debug2 = 0;
- pi_cur1.f32Out = f32Debug1;
- #endif
- //PWM cmpr update
- if(pi_cur1.f32Out > DUTY_BOOST_START)
- if(pi_cur1.f32Out > 1)
- f32BuckDutyTmp = 1;
- else
- f32BuckDutyTmp = pi_cur1.f32Out;
- f32BoostDutyTmp = pi_cur1.f32Out - DUTY_BOOST_START;
- else
- f32BoostDutyTmp = 0;
- u16PwmCmp = (Uint16)(f32BuckDutyTmp * PWM_PERIOD);
- u16PwmCmpBoost = (Uint16)(f32BoostDutyTmp * PWM_PERIOD);
- EPwm1Regs.CMPA.half.CMPA = u16PwmCmp; //Buck1
- EPwm4Regs.CMPA.half.CMPA = u16PwmCmpBoost; //Boost1
- u16BuckDuty = (Uint16)(f32BuckDutyTmp * 100);
- u16BoostDuty = (Uint16)(f32BoostDutyTmp * 100);
- //ECAN communication
- ECANComm();
- //DA convertion for debug
- DAConverter();
- i163TmainFlag = 0 ; //Clear flag for next loop
- } //214us end
- //EPwm4Regs.AQCTLA.all = 0x002A;
- //AQCTL assignment
- EPwm1Regs.AQCTLA.all = AQCTL_RUN_STATE;
- ///////////////!!!!!!!!!!!!for debug
- //EPwm4Regs.AQCTLA.all = AQCTL_RUN_STATE;
- EPwm4Regs.AQCTLA.all = AQCTL_RUN_STATE;
- else
- EPwm4Regs.AQCTLA.all = AQCTL_STOP_STATE;
- else
- EPwm1Regs.AQCTLA.all= AQCTL_STOP_STATE;
- EPwm2Regs.AQCTLA.all= AQCTL_STOP_STATE;
- EPwm3Regs.AQCTLA.all= AQCTL_STOP_STATE;
- EPwm4Regs.AQCTLA.all= AQCTL_STOP_STATE;
- EPwm5Regs.AQCTLA.all= AQCTL_STOP_STATE;
- EPwm6Regs.AQCTLA.all= AQCTL_STOP_STATE;
- //1ms counter
- i161msCount++;
- if(i161msCount>=14)
- i161msCount=0;
- //Periodic task process
- PrdTskList[i].i16Timer--;
- if(PrdTskList[i].i16Timer <= 0)
- PrdTskList[i].u16RunFlag = 1; //Enbable function run
- PrdTskList[i].i16Timer = PrdTskList[i].u16Period_ms;
- } //1ms count end
- // Clear INT flag for this timer
- EPwm1Regs.ETCLR.bit.INT = 1;
- // Acknowledge this interrupt to receive more interrupts from group 3
- PieCtrlRegs.PIEACK.all |= PIEACK_GROUP3;
- * Function: Task1ms
- * Purpose : Periodic task fucntion of 1ms
- * Input:
- * void
- * Output:
- * void
- * Calls:
- * CtrLogic()
- * Monitor()
- * Called by:
- * main()
- Uint16 u16OutCurTmp;
- //Fault and alarm
- Monitor();
- //Control logic, this function must be after Monitor()
- CtrLogic();
- //Filter
- //Output current filter
- /////////////!!!!!!!!!!!!!!need to modify
- u16OutCurTmp = (Uint16)(CUR_BASE * pi_cur1.f32Fdb);
- R_u16FltCurOut += (Uint16)((u16OutCurTmp - R_u16FltCurOut) * OUT_CUR_FLT_CON);
- * Function: Task2ms
- * Purpose : Periodic task fucntion of 2ms
- * Input:
- * void
- * Output:
- * void
- * Calls:
- * CtrCmdSrc()
- * Called by:
- * main()
- //Contrl source
- CtrCmdSrc();
- * Function: Task5ms
- * Purpose : Periodic task fucntion of 5ms
- * Input:
- * void
- * Output:
- * void
- * Calls:
- * void
- * Called by:
- * main()
- //DO process
- //DOFunc();
- //I2CEEFunc();
- * Function: Task10ms
- * Purpose : Periodic task fucntion of 10ms
- * Input:
- * void
- * Output:
- * void
- * Calls:
- * void
- * Called by:
- * main()
- //DO process
- //DOFunc();
- //I2CEEFunc();
- /////////////!!!!!!!!!!!!485 for debug
- RS485IntHost();
- * Function: Task50ms
- * Purpose : Periodic task fucntion of 50ms
- * Input:
- * void
- * Output:
- * void
- * Calls:
- * ParaInputTrans()
- * ParaListTrans()
- * Called by:
- * main()
- //Parameter input transformation
- ParaInputTrans();
- //Parameter display transformation
- ParaListTrans();
- * Function: Epwm1_Tz1_isr
- * Purpose : EPWM1 tz1 interrupt when IPM sends a fualt output signal
- * Input:
- * void
- * Output:
- * void
- * Calls:
- * void
- * Called by:
- * void
- EPwm1Regs.TZCLR.bit.OST = 1;
- EPwm1Regs.TZCLR.bit.INT = 1;
- // Acknowledge this interrupt to receive more interrupts from group 2
- PieCtrlRegs.PIEACK.all |= PIEACK_GROUP2;
- * End of file.
