秒表的程序和編程思路,分享給大家共同學習
2017-9-27 22:05 上傳
2017-9-27 19:45 上傳
2017-9-27 19:45 上傳
2017-9-27 19:45 上傳
單片機源程序如下:
- #include<reg52.h>
- typedef unsigned char u8;
- typedef unsigned int u16;
- /********端口定義*********/
- #define DATA P0
- sbit seg_sel = P1^4;
- sbit bit_sel = P1^5;
- sbit start = P3^2;
- sbit store = P3^3;
- sbit diskey = P3^4;
- sbit reset = P3^5;
- sbit led = P1^0;
- /********變量定義*********/
- u16 tem_ms;
- u8 n_ten_ms,n_sec,n_min;
- u8 run_flag;//當run_flag為1,代表開始計數(shù)
- u8 temp_buf[5][3];
- u8 arr_pt;
- u8 code seg_tab[]={
- 0xc0,0xf9,0xa4,0xb0,
- 0x99,0x92,0x82,0xf8,
- 0x80,0x90,0x88,0x83,
- 0xc6,0xa1,0x86,0x8e
- u8 code bit_tab[]={
- 0x10,0x20,0x40,0x80,
- 0x01,0x02,0x04,0x08
- void delay(unsigned int y)
- unsigned int x,z;
- for(x=y; x>0; x--)
- for(z=110; z>0; z--);
- void display_led(u8 which_bit, u8 which_number)
- bit_sel = 1;//Q[7..0]=D[7..0]
- DATA = bit_tab[which_bit];
- bit_sel = 0;//BIT[7..0]=0x80
- seg_sel = 1;//Q[7..0]=D[7..0]
- DATA = seg_tab[which_number];
- seg_sel = 0;
- void display(u8 which_bit, u8 which_number)
- u8 x,y;
- x = which_number/10;//分離十位
- y = which_number%10;//分離個位
- if (which_bit == 1)
- display_led(1, x);
- delay(2);
- display_led(0, y);
- delay(2);
- if (which_bit == 2)
- display_led(4, x);
- delay(2);
- display_led(3, y);
- delay(2);
- if (which_bit == 3)
- display_led(7, x);
- delay(2);
- display_led(6, y);
- delay(2);
- void reflash (void)
- display(1, n_ten_ms);
- display(2, n_sec);
- display(3, n_min);
- void main (void)
- TMOD = 0x01;//設(shè)置定時/計數(shù)器T0
- TH0 = (65535-10000) / 256;
- TL0 = (65535-10000) % 256;
- EA = 1;//開放總中斷
- ET0 = 1;//開放定時器0的溢出中斷
- //TR0 = 1;
- while (1)
復制代碼
Keil.rar
(19.68 KB, 下載次數(shù): 18)
2017-9-27 19:44 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
Proteus.rar
(31.51 KB, 下載次數(shù): 15)
2017-9-27 19:44 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
