就是數(shù)碼管從0開始加+1 到7的時候流水燈走一遍 然后繼續(xù)+1,為什么我寫的程序進(jìn)入不了流水燈!請大神幫忙修改
#include<reg52.h>
unsigned char miao=0;
unsigned char i=0;
unsigned char jishi[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
code LED[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f} ;
typedef unsigned int u16;
#define led P2
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
void time0init()
//設(shè)置INT0
TCON=1;
IT0=1;//跳變沿出發(fā)方式(下降沿)
EX0=1;//打開INT0的中斷允許。
EA=1;//打開總中斷
void delay(u16 i)
while(i--);
if(miao==7)
{ time0init();
LSA=0;LSB=0;LSC=0;P0=jishi[miao%10];
delay(1000);
LSA=1;LSB=0;LSC=0;P0=jishi[miao/10];
delay(1000);
i++;
if(i==60)
miao+=1;
i=0;
void Time0() interrupt 0
static u16 i1;
static u16 i2;
delay(500);
/*TH0=0XFC;//給定時器賦初值,定時1ms
TL0=0X18;*/
i2++;
for(i1=0;i1<8;i1++)
if(i2==1000)
led=LED[i1];
delay(50000);
