查看: 5464|回復(fù): 2
求大神賜教如何改變下面程序pwm的輸出頻率(最好給出詳細(xì)的思路步驟)
ID:235126 發(fā)表于 2017-10-14 17:34 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "reg51.h"
#define CYCLE   0x1000L     //定義PWM周期(最大值為32767)
#define DUTY    10L         //定義占空比為10%
#define PWMC        (*(unsigned int  volatile xdata *)0xfff0)
#define PWMCH       (*(unsigned char volatile xdata *)0xfff0)
#define PWMCL       (*(unsigned char volatile xdata *)0xfff1)
#define PWMCKS      (*(unsigned char volatile xdata *)0xfff2)
#define PWM2T1      (*(unsigned int  volatile xdata *)0xff00)
#define PWM2T1H     (*(unsigned char volatile xdata *)0xff00)
#define PWM2T1L     (*(unsigned char volatile xdata *)0xff01)
#define PWM2T2      (*(unsigned int  volatile xdata *)0xff02)
#define PWM2T2H     (*(unsigned char volatile xdata *)0xff02)
#define PWM2T2L     (*(unsigned char volatile xdata *)0xff03)
#define PWM2CR      (*(unsigned char volatile xdata *)0xff04)
#define PWM3T1      (*(unsigned int  volatile xdata *)0xff10)
#define PWM3T1H     (*(unsigned char volatile xdata *)0xff10)
#define PWM3T1L     (*(unsigned char volatile xdata *)0xff11)
#define PWM3T2      (*(unsigned int  volatile xdata *)0xff12)
#define PWM3T2H     (*(unsigned char volatile xdata *)0xff12)
#define PWM3T2L     (*(unsigned char volatile xdata *)0xff13)
#define PWM3CR      (*(unsigned char volatile xdata *)0xff14)
#define PWM4T1      (*(unsigned int  volatile xdata *)0xff20)
#define PWM4T1H     (*(unsigned char volatile xdata *)0xff20)
#define PWM4T1L     (*(unsigned char volatile xdata *)0xff21)
#define PWM4T2      (*(unsigned int  volatile xdata *)0xff22)
#define PWM4T2H     (*(unsigned char volatile xdata *)0xff22)
#define PWM4T2L     (*(unsigned char volatile xdata *)0xff23)
#define PWM4CR      (*(unsigned char volatile xdata *)0xff24)
#define PWM5T1      (*(unsigned int  volatile xdata *)0xff30)
#define PWM5T1H     (*(unsigned char volatile xdata *)0xff30)
#define PWM5T1L     (*(unsigned char volatile xdata *)0xff31)
#define PWM5T2      (*(unsigned int  volatile xdata *)0xff32)
#define PWM5T2H     (*(unsigned char volatile xdata *)0xff32)
#define PWM5T2L     (*(unsigned char volatile xdata *)0xff33)
#define PWM5CR      (*(unsigned char volatile xdata *)0xff34)
#define PWM6T1      (*(unsigned int  volatile xdata *)0xff40)
#define PWM6T1H     (*(unsigned char volatile xdata *)0xff40)
#define PWM6T1L     (*(unsigned char volatile xdata *)0xff41)
#define PWM6T2      (*(unsigned int  volatile xdata *)0xff42)
#define PWM6T2H     (*(unsigned char volatile xdata *)0xff42)
#define PWM6T2L     (*(unsigned char volatile xdata *)0xff43)
#define PWM6CR      (*(unsigned char volatile xdata *)0xff44)
#define PWM7T1      (*(unsigned int  volatile xdata *)0xff50)
#define PWM7T1H     (*(unsigned char volatile xdata *)0xff50)
#define PWM7T1L     (*(unsigned char volatile xdata *)0xff51)
#define PWM7T2      (*(unsigned int  volatile xdata *)0xff52)
#define PWM7T2H     (*(unsigned char volatile xdata *)0xff52)
#define PWM7T2L     (*(unsigned char volatile xdata *)0xff53)
#define PWM7CR      (*(unsigned char volatile xdata *)0xff54)
sfr PIN_SW2 =   0xba;
sfr P0M1    =   0x93;
sfr P0M0    =   0x94;
sfr P1M1    =   0x91;
sfr P1M0    =   0x92;
sfr P2M1    =   0x95;
sfr P2M0    =   0x96;
sfr P3M1    =   0xb1;
sfr P3M0    =   0xb2;
sfr P4M1    =   0xb3;
sfr P4M0    =   0xb4;
sfr P5M1    =   0xC9;
sfr P5M0    =   0xCA;
sfr P6M1    =   0xCB;
sfr P6M0    =   0xCC;
sfr P7M1    =   0xE1;
sfr P7M0    =   0xE2;
sfr PWMCFG  =   0xf1;
sfr PWMCR   =   0xf5;
sfr PWMIF   =   0xf6;
sfr PWMFDCR =   0xf7;
    P0M0 = 0x00;
    P0M1 = 0x00;
    P1M0 = 0x00;
    P1M1 = 0x00;
    P2M0 = 0x00;
    P2M1 = 0x00;
    P3M0 = 0x00;
    P3M1 = 0x00;
    P4M0 = 0x00;
    P4M1 = 0x00;
    P5M0 = 0x00;
    P5M1 = 0x00;
    P6M0 = 0x00;
    P6M1 = 0x00;
    P7M0 = 0x00;
    P7M1 = 0x00;
    PIN_SW2 |= 0x80;                //使能訪問XSFR
    PWMCFG = 0x00;                  //配置PWM的輸出初始電平為低電平
    PWMCKS = 0x00;                  //選擇PWM的時鐘為Fosc/(0+1)
    PWMC = CYCLE;                   //設(shè)置PWM周期
    PWM2T1 = 0x0000;                //設(shè)置PWM2第1次反轉(zhuǎn)的PWM計數(shù)
    PWM2T2 = CYCLE * DUTY / 100;    //設(shè)置PWM2第2次反轉(zhuǎn)的PWM計數(shù)
                                    //占空比為(PWM2T2-PWM2T1)/PWMC
    PWM2CR = 0x00;                  //選擇PWM2輸出到P3.7,不使能PWM2中斷
    PWMCR = 0x01;                   //使能PWM信號輸出
    PWMCR |= 0x80;                  //使能PWM模塊
    PIN_SW2 &= ~0x80;
    while (1);
ID:111634 發(fā)表于 2017-10-15 21:14 | 只看該作者
本帖最后由 zl2168 于 2017-10-15 21:17 編輯
介紹你一個參考案例
直流電機(jī)正反轉(zhuǎn)及PWM調(diào)速
Proteus仿真一下,確認(rèn)有效。
實例100 直流電機(jī)正反轉(zhuǎn)及調(diào)速.rar (44.12 KB, 下載次數(shù): 33)
以上摘自張志良編著《80C51單片機(jī)仿真設(shè)計實例教程——基于Keil CProteus》清華大學(xué)出版社ISBN 978-7-302-41682-1內(nèi)有常用的單片機(jī)應(yīng)用100案例,用于仿真實驗操作,電路與程序真實可靠可信可行。書中電路和程序設(shè)計有詳細(xì)說明,程序語句條條有注解。仿真電路和Hex文件能在清華出版社網(wǎng)站免費(fèi)下載,程序源代碼只能到書上看了。到圖書館借,或到新華書店翻閱,或到網(wǎng)上書店打折購買。
ID:235126 發(fā)表于 2017-10-16 20:12 | 只看該作者
zl2168 發(fā)表于 2017-10-15 21:14
介紹你一個參考案例
先Proteus仿真一下,確認(rèn)有效。
多謝答主解答
