#include<reg52.h>
sbit rs=P1^0; //數(shù)據(jù)與命令選擇控制引腳
sbit rw=P1^1; //讀與寫選擇控制引腳
sbit en=P1^2; //使能擇控制引腳
sbit bf=P0^7; //忙標志位
sbit P32=P3^2;
unsigned char i=0,timecount=0,displayOK=0,rate=0,aa=0;
unsigned int time[6]={0};
/************ 延時函數(shù) *****************/
void delay(uint z)
while(z--);
/************ 忙檢測函數(shù) *****************/
void jiance()
P0=0xff;
rs=0;rw=1;en=1;
while(bf); //如果BF==1表示液晶在忙
en=0;
/************ 寫命令函數(shù) *****************/
void write_com(uchar com)
jiance();
P0=com;
rs=0;rw=0;en=1;
delay(2);
en=0;
/************ 寫數(shù)據(jù)函數(shù) *****************/
void write_dat(uchar dat)
jiance();
P0=dat;
rs=1;rw=0;en=1;
delay(2);
en=0;
/************ 1602液晶初始化函數(shù) *****************/
void init_lcd()
write_com(0x38); // 設置16*2顯示,5*7點陣,8位數(shù)據(jù)接口
write_com(0x0c); // 開顯示,不顯示光標
write_com(0x06); // 地址加1,當寫入數(shù)據(jù)的時候光標右移
write_com(0x01); //清屏
/* 在指定位置寫字符 */
void LCD_write_char(unsigned char x,unsigned char y,unsigned char Data)
if (y == 0)
write_com(0x80 + x);
write_com(0xC0 + x);
write_dat(Data);
void DelayMs(unsigned int z)
unsigned int x;
for(;z>0;z--)
for(x=110;x>0;x--);
P32=1;
init_lcd();//lcd初始化
TCON=0x01;//設置外部中斷0
EX0=1;
TMOD=0x01;//定時器0初始化
TH0=(65536-50000)/256;//實測每50ms中斷的定時值
TL0=(65536-50000)%256;
ET0=1;//開定時器中斷
//顯示基本文字
LCD_write_char(3,0,'H');
LCD_write_char(4,0,'e');
LCD_write_char(5,0,'a');
LCD_write_char(6,0,'r');
LCD_write_char(7,0,'t');
LCD_write_char(8,0,' ');
LCD_write_char(9,0,'R');
LCD_write_char(10,0,'a');
LCD_write_char(11,0,'t');
LCD_write_char(12,0,'e');
LCD_write_char(8,1,'/');
LCD_write_char(9,1,'m');
LCD_write_char(10,1,'i');
LCD_write_char(11,1,'n');
TR0=0;//定時器停止
EA=1;//開總中斷
if(displayOK==1)
rate=60000/(time[1]/5+time[2]/5+time[3]/5+time[4]/5+time[5]/5);
LCD_write_char(5,1,rate/100+48);
LCD_write_char(6,1,(rate%100)/10+48);
LCD_write_char(7,1,rate%10+48);
DelayMs(300);
void ex0() interrupt 0
EX0=0;//暫時關外部中斷
if(timecount<8) //當連續(xù)兩次檢測時間間隔小于8*50ms=400ms不處理
TR0=1;//開定時器
time[i]=timecount*50+TH0*0.256+TL0/1000;//算出間隔時間
TL0=(65536-50000)%256;//重新設置定時器
timecount=0;//50ms計數(shù)清零
i++;
if(i==6)//記錄到超過等于6次時間
i=1;//計數(shù)從1開始
displayOK=1; //測得5次開始顯示
EX0=1;
void et0() interrupt 1
timecount++;//每50ms一次計數(shù)
if(timecount>25) //當超過25*50ms=1.25s沒有檢測到信號停止顯示
i=0;//數(shù)據(jù)個數(shù)清零
displayOK=0;//顯示關
TR0=0;//定時器關
