查看: 2667|回復(fù): 0
分享一段HMC5883L的代碼 但是不知道為何沒用
ID:241138 發(fā)表于 2017-10-20 00:02 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#define HMC5883_WriteAddress 0x1E //  i.e 0x3C >> 1
#define HMC5883_ModeRegisterAddress 0x02
#define HMC5883_ContinuousModeCommand 0x00
#define HMC5883_DataOutputXMSBAddress  0x03
#include <Wire.h>
int regb=0x01;
int regbdata=0x40;
int outputData[6];
void setup()
  //Initiate the Wire library and join the I2C bus as a master
    Serial.begin(9600);
    Wire.begin();
void loop() {
    int i,x,y,z;
    double angle;
    Wire.beginTransmission(HMC5883_WriteAddress);
    Wire.write(regb);
    Wire.write(regbdata);
    Wire.endTransmission();
    delay(1000);
    Wire.beginTransmission(HMC5883_WriteAddress); //Initiate a transmission with HMC5883 (Write address).
    Wire.write(HMC5883_ModeRegisterAddress);       //Place the Mode Register Address in send-buffer.
    Wire.write(HMC5883_ContinuousModeCommand);     //Place the command for Continuous operation Mode in send-buffer.
    Wire.endTransmission();                       //Send the send-buffer to HMC5883 and end the I2C transmission.
    delay(100);
    Wire.requestFrom(HMC5883_WriteAddress,6);      //Request 6 bytes of data from the address specified.
    delay(500);
    //Read the value of magnetic components X,Y and Z
    if(6 <= Wire.available()) // If the number of bytes available for reading be <=6.
        for(i=0;i<6;i++)
            outputData=Wire.read();  //Store the data in outputData buffer
    x=outputData[0] << 8 | outputData[1]; //Combine MSB and LSB of X Data output register
    z=outputData[2] << 8 | outputData[3]; //Combine MSB and LSB of Z Data output register
    y=outputData[4] << 8 | outputData[5]; //Combine MSB and LSB of Y Data output register
    angle= atan2((double)y,(double)x) * (180 / 3.14159265) + 180; // angle in degrees
  Refer the following application note for heading calculation.
  http://www.ssec.honeywell.com/magnetic/datasheets/lowcost.pdf
  atan2(y, x) is the angle in radians between the positive x-axis of a plane and the point
  given by the coordinates (x, y) on it.
  This sketch does not utilize the magnetic component Z as tilt compensation can not be done without an Accelerometer
  ----------------->y
  x
     N
NW  |  NE
W----------E
SW  |  SE
     S
    //Print the approximate direction
    Serial.print("You are heading ");
    if((angle < 22.5) || (angle > 337.5 ))
        Serial.print("South");
    if((angle > 22.5) && (angle < 67.5 ))
        Serial.print("South-West");
    if((angle > 67.5) && (angle < 112.5 ))
        Serial.print("West");
    if((angle > 112.5) && (angle < 157.5 ))
        Serial.print("North-West");
    if((angle > 157.5) && (angle < 202.5 ))
        Serial.print("North");
    if((angle > 202.5) && (angle < 247.5 ))
        Serial.print("NorthEast");
    if((angle > 247.5) && (angle < 292.5 ))
        Serial.print("East");
    if((angle > 292.5) && (angle < 337.5 ))
        Serial.print("SouthEast");
    Serial.print(": Angle between X-axis and the South direction ");
    if((0 < angle) && (angle < 180) )
        angle=angle;
        angle=360-angle;
    Serial.print(angle,2);
    Serial.println(" Deg");
    delay(100);
