#include<avr/io.h>
#include<avr/delay.h>
#include"NRF24L01.h"
//#define Open_TX
#define Open_RX
typedef unsigned char uint8; /* defined for unsigned 8-bits integer variable 無符號8位整型變量 */
typedef signed char int8; /* defined for signed 8-bits integer variable 有符號8位整型變量 */
typedef unsigned short uint16; /* defined for unsigned 16-bits integer variable 無符號16位整型變量 */
typedef signed short int16; /* defined for signed 16-bits integer variable 有符號16位整型變量 */
typedef unsigned int uint32; /* defined for unsigned 32-bits integer variable 無符號32位整型變量 */
typedef signed int int32; /* defined for signed 32-bits integer variable 有符號32位整型變量 */
typedef float fp32; /* single precision floating point variable (32bits) 單精度浮點數(shù)(32位長度) */
typedef double fp64; /* double precision floating point variable (64bits) 雙精度浮點數(shù)(64位長度) */
extern uint8_t RX_BUF[];
extern uint8_t TX_BUF[];
void motorrun();
uint8 HandleKey();
uint8 KEY_Release;
uint32 i,MS1;
#define KEY1_Press ((keys & 0x03) == 3)
#define KEY1_Pressed ((keys & 0x03) == 2)
#define KEY1_Release ((keys & 0x03) == 1)
#define KEY1_Released ((keys & 0x03) == 0)
int main(void)
//nRF24L01_Config();
//usartInit();
uint8 keys = 0;
nRF24L01_Initial();
#ifdef Open_TX
keys=HandleKey();
if(KEY1_Release)
TX_BUF[0]=0x55;
NRF24L01_Send();
if(TX_BUF[0]==0x55)
for(i=1;i<100;i++)
PORTB &=~ (1<<PB0);//LED
_delay_ms(1000);
PORTB |= (1<<PB0);//LED
_delay_ms(1000);
//printf("\r\nSend data:0x%x\r\n",TX_BUF[0]);
_delay_ms(5000);
#else
PORTD &=~(1<<PD2);
NRF24L01_Receive();
_delay_ms(2000);
if(RX_BUF[0]==0X55)
motorrun();
while(1);
#endif
uint8 HandleKey(void)
static uint8 key1laststa = 1,pressure = 0;
uint8 ret = 0;
DDRB &= ~(1 << PB1);
if(PINB & (1 << PB1)) //KEY1
ret = (ret & ~(0x03 << 0)) | (0x00 << 0);
if(key1laststa == 0) //release
ret = (ret & ~(0x03 << 0)) | (0x01 << 0);
key1laststa = 1;
ret = (ret & ~(0x03 << 0)) | (0x02 << 0);
if(key1laststa == 1) //press
ret = (ret & ~(0x03 << 0)) | (0x03 << 0);
key1laststa = 0;
return ret;
void motorrun()
PORTD |=(1<<PD2);
PORTD &=~ (1<<PD3);
PORTD &=~ (1<<PD4);//EN1
PORTD &=~ (1<<PD5);//EN2
PORTC &=~(1<<PC1);//DIR
for(i=0;i<4000;i++)
PORTC |= (1 << PC0);
_delay_ms(20);
PORTC &=~ (1 << PC0);
_delay_ms(20);
