查看: 3217|回復(fù): 0
lcd.begin(16, 2);
ID:242208 發(fā)表于 2017-10-23 20:20 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
//DFRobot.com
//Compatible with the Arduino IDE 1.0
//Library version:1.1
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27,16,2);  // set the LCD address to 0x3F for a 16 chars and 2 line display
void setup(){
  lcd.init();                      // initialize the lcd
  lcd.backlight();
  lcd.begin(16, 2);
  lcd.home();
   lcd.setCursor(2, 0);
  lcd.print("Hello world...");
  lcd.setCursor(2, 1);
  lcd.print("dfrobot.com");
int backlightState = LOW;
long previousMillis = 0;
long interval = 1000;
void loop()
  unsigned long currentMillis = millis();
  if(currentMillis - previousMillis > interval)
    previousMillis = currentMillis;
    if (backlightState == LOW)
      backlightState = HIGH;
    if(backlightState == HIGH)  lcd.backlight();
    else lcd.noBacklight();
