查看: 2183|回復(fù): 3
使LCD顯示時(shí)鐘,但是就出來這個(gè)圖像,程序也不知道錯(cuò)在哪,求大神解決
ID:237529 發(fā)表于 2017-10-25 11:21 | 顯示全部樓層 |閱讀模式
#include<reg51.h>
#include<intrins.h>
#define out P3
sbit RS=P2^0;
sbit RW=P2^1;
sbit E=P2^2;
uchar date[]="   H.I.T.CHINA  ",
      time[]=" TIME  23:59:55 ";
uchar int_time,second,minute,hour;
uchar second=55,minute=59,hour=23;
void lcd_initial(void);
void check_busy(void);
void write_command(uchar com);
void write_data(uchar dat);
void write_sfm(uchar,uchar);
void delay(uint);
void clock_init(void);
void clock_write(uint,uint,uint);
void delay(uint j)
  uchar i=250;
  for(;j>0;j--)
    while(--i);
        i=249;
        while(--i);
        i=250;
  uchar dt;
  do
    dt=0xff;
        E=0;
        RS=0;
        RW=1;
        E=1;
        dt=out;
  while(dt&0x80);
  E=0;
  check_busy();
  E=0;
  RS=0;
  RW=0;
  out=com;
  E=1;
  _nop_();
  E=0;
  delay(1);
  check_busy();
  E=0;
  RS=1;
  RW=0;
  out=dat;
  E=1;
  _nop_();
  E=0;
  delay(1);
  write_command(0x38);
  write_command(0x0c);
  write_command(0x06);
  write_command(0x01);
  delay(1);
void write_sfm(uchar ad,uchar s)
  write_command(ad);
  write_data (s);
  delay(100);
  write_command(++ad);
  write_data(s/10);
  delay(100);
void clock_init()
  uchar i,j;
  write_command(0x80);
  for(i=0;i<16;i++)
    write_data(date[i]);
  write_command(0x80+0x40);
  for(j=0;j<16;j++)
    write_data(time[j]);
void clock_write(uint s,uint m,uint h)
  write_sfm(0xc7,h);
  write_sfm(0xca,m);
  write_sfm(0xcd,s);
void T0_interserve(void)   interrupt 1  using 1
  int_time++;
  if(int_time==20)
    int_time=0;
        second++;
  if(second==60)
    second=0;
        minute++;
  if(minute==60)
        minute=0;
    hour++;
  if(hour==24)
    hour=0;
  TH0=(65536-46083)/256;
  TL0=(65536-46083)%256;
  lcd_initial();
  clock_init();
  TMOD=0x01;
  EA=1;
  ET0=1;
  TH0=(65536-46483)/256;
  TL0=(65536-46483)/256;
  TR0=1;
  int_time=0;
  second=55;
  minute=59;
  hour=23;
    clock_write(second,minute,hour);
ID:57570 發(fā)表于 2017-10-25 13:54 來自觸屏版 | 顯示全部樓層
多看看別人的程序。
ID:219796 發(fā)表于 2017-10-26 00:20 來自觸屏版 | 顯示全部樓層
你告訴我有啥錯(cuò)?
ID:82765 發(fā)表于 2017-10-26 05:43 | 顯示全部樓層
提示: 作者被禁止或刪除 內(nèi)容自動(dòng)屏蔽
