- 求大神解答為什么1602顯示不出gy-30的亮度值,,,,望大神不要介意問(wèn)題簡(jiǎn)單
- // BH1750FVI IIC????
- // ?????STC89C51
- // ??:11.0592M
- // ??:LCD1602
- // ???? Keil uVision2
- // ??????24c04????
- // ??:2011?4?20?
- #include <REG51.H>
- #include <math.h> //Keil library
- #include <stdio.h> //Keil library
- #include <INTRINS.H>
- #define uchar unsigned char
- #define uint unsigned int
- #define DataPort P0 //LCD1602????
- sbit SCL=P1^0; //IIC??????
- sbit SDA=P1^1; //IIC??????
- sbit LCM_RS=P2^0; //LCD1602????
- sbit LCM_RW=P2^1; //LCD1602????
- sbit LCM_EN=P2^2; //LCD1602????
- #define SlaveAddress 0x46 //?????IIC???????,??ALT ADDRESS????????
- //ALT ADDRESS????????0xA6,???????0x3A
- typedef unsigned char BYTE;
- typedef unsigned short WORD;
- BYTE BUF[8]; //???????
- uchar ge,shi,bai,qian,wan; //????
- int dis_data; //??
- void delay_nms(unsigned int k);
- void InitLcd();
- void Init_BH1750(void);
- void WriteDataLCM(uchar dataW);
- void WriteCommandLCM(uchar CMD,uchar Attribc);
- void DisplayOneChar(uchar X,uchar Y,uchar DData);
- void conversion(uint temp_data);
- void Single_Write_BH1750(uchar REG_Address); //??????
- uchar Single_Read_BH1750(uchar REG_Address); //???????????
- void Multiple_Read_BH1750(); //????????????
- void Delay5us();
- void Delay5ms();
- void BH1750_Start(); //????
- void BH1750_Stop(); //????
- void BH1750_SendACK(bit ack); //??ACK
- bit BH1750_RecvACK(); //?ack
- void BH1750_SendByte(BYTE dat); //IIC?????
- BYTE BH1750_RecvByte(); //IIC?????
- void conversion(uint temp_data) // ????? ?,?,?,?,?
- wan=temp_data/10000+0x30 ;
- temp_data=temp_data%10000; //????
- qian=temp_data/1000+0x30 ;
- temp_data=temp_data%1000; //????
- bai=temp_data/100+0x30 ;
- temp_data=temp_data%100; //????
- shi=temp_data/10+0x30 ;
- temp_data=temp_data%10; //????
- ge=temp_data+0x30;
- unsigned int i,j;
- for(i=0;i<k;i++)
- for(j=0;j<121;j++)
- void WaitForEnable(void)
- DataPort=0xff;
- LCM_RS=0;LCM_RW=1;_nop_();
- LCM_EN=1;_nop_();_nop_();
- while(DataPort&0x80);
- LCM_EN=0;
- if(Attribc)WaitForEnable();
- LCM_RS=0;LCM_RW=0;_nop_();
- DataPort=CMD;_nop_();
- LCM_EN=1;_nop_();_nop_();LCM_EN=0;
- WaitForEnable();
- LCM_RS=1;LCM_RW=0;_nop_();
- DataPort=dataW;_nop_();
- void InitLcd()
- WriteCommandLCM(0x38,1);
- WriteCommandLCM(0x08,1);
- WriteCommandLCM(0x01,1);
- WriteCommandLCM(0x06,1);
- WriteCommandLCM(0x0c,1);
- Y&=1;
- X&=15;
- if(Y)X|=0x40;
- X|=0x80;
- WriteCommandLCM(X,0);
- WriteDataLCM(DData);
- ??5??(STC90C52RC@12M)
- ???1T?MCU?,????????
- void Delay5us()
- _nop_();_nop_();_nop_();_nop_();
- void Delay5ms()
- WORD n = 560;
- while (n--);
- SDA = 1; //?????
- SCL = 1; //?????
- Delay5us(); //??
- SDA = 0; //?????
- Delay5us(); //??
- SCL = 0; //?????
- SDA = 0; //?????
- SCL = 1; //?????
- Delay5us(); //??
- SDA = 1; //?????
- Delay5us(); //??
- ????:ack (0:ACK 1:NAK)
- SDA = ack; //?????
- SCL = 1; //?????
- Delay5us(); //??
- SCL = 0; //?????
- Delay5us(); //??
- SCL = 1; //?????
- Delay5us(); //??
- CY = SDA; //?????
- SCL = 0; //?????
- Delay5us(); //??
- return CY;
- ?IIC??????????
- BYTE i;
- for (i=0; i<8; i++) //8????
- dat <<= 1; //????????
- SDA = CY; //????
- SCL = 1; //?????
- Delay5us(); //??
- SCL = 0; //?????
- Delay5us(); //??
- BH1750_RecvACK();
- ?IIC??????????
- BYTE i;
- BYTE dat = 0;
- SDA = 1; //??????,??????,
- dat <<= 1;
- SCL = 1; //?????
- Delay5us(); //??
- dat |= SDA; //???
- SCL = 0; //?????
- Delay5us(); //??
- return dat;
- BH1750_Start(); //????
- BH1750_SendByte(SlaveAddress); //??????+???
- BH1750_SendByte(REG_Address); //???????,?????pdf22?
- // BH1750_SendByte(REG_data); //???????,?????pdf22?
- BH1750_Stop(); //??????
- { uchar REG_data;
- BH1750_SendByte(REG_Address); //????????,?0??
- BH1750_SendByte(SlaveAddress+1); //??????+???
- REG_data=BH1750_RecvByte(); //???????
- BH1750_SendACK(1);
- return REG_data;
- //????BH1750????
- void Multiple_read_BH1750(void)
- { uchar i;
- for (i=0; i<3; i++) //????6?????,???BUF
- BUF[i] = BH1750_RecvByte(); //BUF[0]??0x32??????
- if (i == 3)
- BH1750_SendACK(1); //?????????NOACK
- else
- BH1750_SendACK(0); //??ACK
- Delay5ms();
- //???BH1750,???????pdf????****
- void Init_BH1750()
- Single_Write_BH1750(0x01);
- void main()
- float temp;
- delay_nms(200); //??200ms
- InitLcd(); //???LCD
- Init_BH1750(); //???BH1750
- while(1) //??
- Single_Write_BH1750(0x01); // power on
- Single_Write_BH1750(0x10); // H- resolution mode
- delay_nms(180); //??180ms
- Multiple_Read_BH1750(); //??????,???BUF?
- dis_data=BUF[0];
- dis_data=(dis_data<<8)+BUF[1];//????
- temp=(float)dis_data/1.2;
- conversion(temp); //???????
- DisplayOneChar(0,0,'L');
- DisplayOneChar(1,0,'i');
- DisplayOneChar(2,0,'g');
- DisplayOneChar(3,0,'h');
- DisplayOneChar(4,0,'t');
- DisplayOneChar(5,0,':');
- DisplayOneChar(7,0,wan); //????
- DisplayOneChar(8,0,qian);
- DisplayOneChar(9,0,bai);
- DisplayOneChar(10,0,shi);
- DisplayOneChar(11,0,ge);
- DisplayOneChar(13,0,'l'); ////?????
- DisplayOneChar(14,0,'x');
復(fù)制代碼 |
