查看: 4392|回復: 0
分享我做的用74HC595驅(qū)動的16X16點陣
ID:242127 發(fā)表于 2017-10-26 22:12 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
程序如下
#include <reg52.h>
uchar code table1 []=//取模方法,陰碼,逆向,逐列式,
{        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
        0x00,0x00,0x70,0x38,0x88,0x20,0x08,0x21,0x08,0x21,0x08,0x22,0x38,0x1C,0x00,0x00,/*"S",0*/
  0x00,0x00,0xF8,0x19,0x88,0x20,0x88,0x20,0x88,0x20,0x08,0x11,0x08,0x0E,0x00,0x00,/*"5",1*/
0x00,0x00,0x00,0x00,0x10,0x20,0x10,0x20,0xF8,0x3F,0x00,0x20,0x00,0x20,0x00,0x00,/*"1",2*/
0x00,0x00,0x70,0x1C,0x88,0x22,0x08,0x21,0x08,0x21,0x88,0x22,0x70,0x1C,0x00,0x00,/*"8",3*/
0x00,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0xFC,0x3F,
0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0x00,0x20,0x00,0x00,/*"?",4*/
0x00,0x01,0x80,0x00,0x60,0x00,0xF8,0xFF,0x07,0x00,0x40,0x00,0x30,0x00,0x0F,0x00,
0xF8,0xFF,0x88,0x08,0x88,0x08,0x88,0x08,0x88,0x08,0x08,0x08,0x08,0x00,0x00,0x00,/*"?",5*/
#include <reg52.h>
uchar code table2[]=
        0xfe,0xff,
        0xfd,0xff,
        0xfb,0xff,
        0xf7,0xff,
        0xef,0xff,
        0xdf,0xff,
        0xbf,0xff,
        0x7f,0xff,
        0xff,0xfe,
        0xff,0xfd,
        0xff,0xfb,
        0xff,0xf7,
        0xff,0xef,
        0xff,0xdf,
        0xff,0xbf,
        0xff,0x7f,
sbit a=P2^2;
sbit b=P2^3;
sbit c=P2^4;
sbit d=P2^5;
sbit jia_key=P3^4;
sbit jian_key=P3^5;
uchar m=15;
void delay(uint z)
        uint  x,y;
        for(x=z;x>0;x--)
        for(y=110;y>0;y--);
void delay1(uint z)
        uint  x,y;
        for(x=z;x>0;x--)
        for(y=12;y>0;y--);
void key()
        if(jia_key==0)     //按鍵檢測處理函數(shù)
                delay(5);        //消斗
                if(jia_key==0)  //按鍵速度加一
                        m++;
                        if(jia_key==10)
                                m==25;
                        while(jia_key==0);
        if(jian_key==0)
                delay(5);
                if(jian_key==0)
                        m--;
                        if(jian_key==9)
                                m=6;
                        while(jian_key==0);
        uint k;
        uint i,j,n;
                for(k=0; k<=190; k++)// 平移的行函數(shù) ,多一個字K加15,
                        for(j=m; j>0; j--)//平移的速度
                        for(i=k,n=0;i<k+16; i++,n++)//顯示一個16X16的圖像
                                //陽極
                                P1=0x00;
                                a=1;
                                P1=table1 [2*i];
                                a=0;
                                P1=0x00;
                                b=1;
                                P1=table1 [2*i+1];
                                b=0;
                                //陰極
                                P1=0xff;
                                c=1;
                                P1=table2 [2*n];
                                c=0;
                                P1=0xff;
                                d=1;
                                P1=table2 [2*n+1];
                                d=0;
                                delay1(5);
                                c=1;
                                P1=0xff;
                                c=0;
                                d=1;
                                P1=0xff;
                                d=0;
                     key();
     if(k>190)
        delay(50);
admin + 50 共享資料的黑幣獎勵!
