查看: 3581|回復(fù): 0
TM1804程序問題
ID:171584 發(fā)表于 2017-10-27 19:26 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
#include<reg51.h>
#include<intrins.h>
#define uint  unsigned int
#define nop() _nop_()
#define Red 1
#define Green 2
#define Blue 3
#define White 4
#define High 1
#define Low 0
sbit DIO=P1^0;
bdata uchar a;
sbit a7=a^7;
sbit LED=P2^2;
uchar show[3],color=1,temp=0xff;
void delay_ms(int z)
int x,y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void write(uchar date)
uchar i;
for(i=0;i<8;i++)
      if(date&0x80)
                  DIO=1;
                  nop();   nop();        nop();                nop();
                  DIO=0;
                  DIO=1;
                  nop();nop();nop();nop();
                  nop();
                  DIO=0;
        date<<=1;
void display()
     uchar i,j;
             for(j=0;j<1;j++)
                 for(i=0;i<3;i++)
                    write(show[i]);
void load()
        uchar i;
                for(i=0;i<1;i++)
                        if(color==Red)
                        show[i*3+0]=temp;
                        show[i*3+1]=0x00;
                        show[i*3+2]=0x00;
                        if(color==Green)
                        show[i*3+0]=0x00;
                        show[i*3+1]=temp;
                        show[i*3+2]=0x00;
                        if(color==Blue)
                        show[i*3+0]=0x00;
                        show[i*3+1]=0x00;
                        show[i*3+2]=temp;
                        if(color==White)
                        show[i*3+0]=temp;
                        show[i*3+1]=temp;
                        show[i*3+2]=temp;
void show_3()
    for(color=1;color<5;color++)
            for(temp=0;temp<255;temp++)
                     load();
                         display();
                         delay_ms(50);
                for(temp=255;temp>0;temp--)
                    load();
                        display();
                        delay_ms(50);
void show_1()
     uchar i;
         for(i=0;i<2;i++)
         write(0xff);
         write(0x00);
         write(0xaa);
     write(0xff);
         write(0x00);
         write(0xaa);
         write(0xff);
         write(0x00);
         write(0xaa);
         write(0xff);
         write(0xff);
         write(0xff);
    uchar i,j;
        for(j=0;j<4;j++)
           for(i=0;i<3;i++)
        write(0xff);
        delay_ms(50);
         show_3();
         LED=!LED;
有誰能給講解下這個(gè)程序嗎?
理解起來有點(diǎn)混亂
