查看: 5876|回復(fù): 2
51單片機(jī)之控制紅外傳感器
ID:243524 發(fā)表于 2017-10-27 20:31 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#include<intrins.h>
#include<stdio.h>
#define led P2
sbit buzz=P1^5;
sbit lsa=P2^2;
sbit lsb=P2^3;
sbit lsc=P2^4;
sbit key1=P3^2;
sbit key2=P3^3;
sbit led1=P2^1;
uchar code tab_duan[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f/*,0x77,0x7c,0x39,0x5e,0x79,0x71*/};
uchar  display[8];
uint i,t0,t1,t2;//time
int count1,count2,flag_led;//infrared
void display_();
void display_pros();
void infrared_control();
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void timer_init()
TMOD=0x11;
TH0=0x3c;//(65536-50000)/256;
TL0=0xb0;//(65536-50000)%256;
ET0=1;
TR0=1;
void ex_init()
EX0=1;
IT0=1;
EX1=1;
IT1=1;
void init()
EA=1;
led=0xff;
timer_init();
ex_init();
init();
   infrared_control();
//   display_pros();
//   display_();
if(flag_led>0)
   led=0x00;
if(flag_led<=0)
   led=0xff;
void int0() interrupt 0
   count1++;
   flag_led++;
   if(count1==60)
     count1=0;
   buzz=~buzz;
   delay(1);
void int1() interrupt 2
   count1--;
   flag_led--;
   buzz=~buzz;
   delay(1);
void timer0() interrupt 1
i++;
if(i==20)
   i=0;
   t0++;
   if(t0==60)
     t0=0;
     t1++;
     if(t1==60)
       t1=0;
       t2++;
       if(t2==24)
         t2=0;
void display_()
uchar j;
for(j=0;j<8;j++)
switch(j)
case 0:
      lsc=0;lsb=0;lsa=0;break;
//  P0=tab_duan[count1%10];
  case 1:
    lsc=0;lsb=0;lsa=1;break;
//  P0=tab_duan[count1/10];
  case 2:
    lsc=0;lsb=1;lsa=0; break;
//  P0=tab_duan[t0%10];
  case 3:
    lsc=0;lsb=1;lsa=1;break;
//  P0=tab_duan[t0/10];
  case 4:
    lsc=1;lsb=0;lsa=0;break;
//  P0=tab_duan[t1%10];
  case 5:
    lsc=1;lsb=0;lsa=1;break;
//  P0=tab_duan[t1/10];
  case 6:
    lsc=1;lsb=1;lsa=0;break;
//  P0=tab_duan[t2%10];
  case 7:
    lsc=1;lsb=1;lsa=1;break;
///  P0=tab_duan[t2/10];
   P0=display[j];
   delay(1);
   P0=0x00;
void display_pros()
display[0]=tab_duan[count1%10];
display[1]=tab_duan[count1/10];
display[2]=tab_duan[t0%10];
display[3]=tab_duan[t0/10];
display[4]=tab_duan[t1%10];
display[5]=tab_duan[t1/10];
display[6]=tab_duan[t2%10];
display[7]=tab_duan[t2%10];
ID:392319 發(fā)表于 2018-9-1 14:39 | 顯示全部樓層
你好樓主,請問這個(gè)程序具體是什么流程
ID:701637 發(fā)表于 2020-5-6 22:00 | 顯示全部樓層
我的管腳都不是接外部中斷的。。。
