#include<reg51.h>
sbit DQ=P3^7;//ds18b20與單片機(jī)連接口
sbit RS=P3^0;
sbit RW=P3^1;
sbit EN=P3^2;
unsigned char code str1[]={"temperature: "};
unsigned char code str2[]={" "};
uchar data disdata[5];
uint tvalue;//溫度值
uchar tflag;//溫度正負(fù)標(biāo)志
/*************************lcd1602程序**************************/
void delay1ms(unsigned int ms)//延時(shí)1毫秒(不夠精確的)
{unsigned int i,j;
for(i=0;i<ms;i++)
for(j=0;j<100;j++);
void wr_com(unsigned char com)//寫指令//
{ delay1ms(1);
RS=0;
RW=0;
EN=0;
P2=com;
delay1ms(1);
EN=1;
delay1ms(1);
EN=0;
void wr_dat(unsigned char dat)//寫數(shù)據(jù)//
{ delay1ms(1);;
RS=1;
RW=0;
EN=0;
P2=dat;
delay1ms(1);
EN=1;
delay1ms(1);
EN=0;
void lcd_init()//初始化設(shè)置//
{delay1ms(15);
wr_com(0x38);delay1ms(5);
wr_com(0x08);delay1ms(5);
wr_com(0x01);delay1ms(5);
wr_com(0x06);delay1ms(5);
wr_com(0x0c);delay1ms(5);
void display(unsigned char *p)//顯示//
while(*p!='\0')
wr_dat(*p);
p++;
delay1ms(1);
init_play()//初始化顯示
{ lcd_init();
wr_com(0x80);
display(str1);
wr_com(0xc0);
display(str2);
/******************************ds1820程序***************************************/
void delay_18B20(unsigned int i)//延時(shí)1微秒
while(i--);
void ds1820rst()/*ds1820復(fù)位*/
{ unsigned char x=0;
DQ = 1; //DQ復(fù)位
delay_18B20(4); //延時(shí)
DQ = 0; //DQ拉低
delay_18B20(100); //精確延時(shí)大于480us
DQ = 1; //拉高
delay_18B20(40);
uchar ds1820rd()/*讀數(shù)據(jù)*/
{ unsigned char i=0;
unsigned char dat = 0;
for (i=8;i>0;i--)
{ DQ = 0; //給脈沖信號(hào)
dat>>=1;
DQ = 1; //給脈沖信號(hào)
if(DQ)
dat|=0x80;
delay_18B20(10);
return(dat);
void ds1820wr(uchar wdata)/*寫數(shù)據(jù)*/
{unsigned char i=0;
for (i=8; i>0; i--)
{ DQ = 0;
DQ = wdata&0x01;
delay_18B20(10);
DQ = 1;
wdata>>=1;
read_temp()/*讀取溫度值并轉(zhuǎn)換*/
{uchar a,b;
ds1820rst();
ds1820wr(0xcc);//*跳過讀序列號(hào)*/
ds1820wr(0x44);//*啟動(dòng)溫度轉(zhuǎn)換*/
ds1820rst();
ds1820wr(0xbe);//*讀取溫度*/
a=ds1820rd();
b=ds1820rd();
tvalue=b;
tvalue<<=8;
tvalue=tvalue|a;
if(tvalue<0x0fff)
tflag=0;
{tvalue=~tvalue+1;
tflag=1;
tvalue=tvalue*(0.625);//溫度值擴(kuò)大10倍,精確到1位小數(shù)
return(tvalue);
void ds1820disp()//溫度值顯示
{ uchar flagdat;
disdata[0]=tvalue/1000+0x30;//百位數(shù)
disdata[1]=tvalue%1000/100+0x30;//十位數(shù)
disdata[2]=tvalue%100/10+0x30;//個(gè)位數(shù)
disdata[3]=tvalue%10+0x30;//小數(shù)位
if(tflag==0)
flagdat=0x20;//正溫度不顯示符號(hào)
flagdat=0x2d;//負(fù)溫度顯示負(fù)號(hào):-
if(disdata[0]==0x30)
{disdata[0]=0x20;//如果百位為0,不顯示
if(disdata[1]==0x30)
{disdata[1]=0x20;//如果百位為0,十位為0也不顯示
wr_com(0xc0);
wr_dat(flagdat);//顯示符號(hào)位
wr_com(0xc1);
wr_dat(disdata[0]);//顯示百位
wr_com(0xc2);
wr_dat(disdata[1]);//顯示十位
wr_com(0xc3);
wr_dat(disdata[2]);//顯示個(gè)位
wr_com(0xc4);
wr_dat(0x2e);//顯示小數(shù)點(diǎn)
wr_com(0xc5);
wr_dat(disdata[3]);//顯示小數(shù)位
/********************主程序***********************************/
{ init_play();//初始化顯示
{read_temp();//讀取溫度
ds1820disp();//顯示
ds18b20.rar
2017-10-31 10:28 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
44.22 KB, 下載次數(shù): 85, 下載積分: 黑幣 -5
