查看: 2519|回復(fù): 0
stm32 GPIO常用腳配置
ID:235123 發(fā)表于 2017-11-1 16:22 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
GPIO  常用配置( MCU:STM32F103C8T6                ,固件庫: 1.0 ):
AD:
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
   //AD  配置為模擬輸入
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
   GPIO_Init(GPIOC, &GPIO_InitStructure);
CAN :
   /* Configure CAN pin: RX */
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
   //接收腳配置為上拉輸入
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
   GPIO_Init(GPIOA, &GPIO_InitStructure);
   /* Configure CAN pin: TX */
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
   //發(fā)送腳配置為復(fù)用推拉輸出
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
EXTI:
   /* Configure PB.09 as input floating (EXTI Line 9) */
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
   //作為外部中斷時配置為浮空輸入
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOA             TING;
   GPIO_Init(GPIOB, &GPIO_InitStructure);
I2C :
   /* Configure I2C1 pins: SCL and SDA     ----------------------------------------*/
   GPIO_InitStructure.GPIO_Pin =       GPIO_Pin_6 | GPIO_Pin_7;
   //SCL 和SDA  都配置為復(fù)用開漏輸出
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
SPI:
   /* Configure SPI1 pins: SCK, MISO and MOSI ---------------------------------*/
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
   //配置為復(fù)用推拉輸出
USART:
  /* Configure USART2 RTS (PD.04) and USART2 Tx (PD.05) as alternate function push-pull */
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;
  //發(fā)送腳配置為推拉輸出
   GPIO_Init(GPIOD, &GPIO_InitStructure);
  /* Configure USART2 CTS (PD.03) and USART2 Rx (PD.06) as input floating */
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_6;
  //接收腳配置為浮空輸入
總結(jié):普通 IO        口作為輸入時配置為浮空輸入(  GPIO_Mode_IN_FLOA  TING  ),作為輸出如
果不需要從本口獲取數(shù)據(jù)時配置為推拉輸出(                         GPIO_Mode_Out_PP  ),需要讀取數(shù)據(jù)時配置
為開漏輸出( GPIO_Mode_Out_OD           )。
        王偉
