查看: 4080|回復(fù): 0
矩陣鍵盤+數(shù)碼管上輸入刪除任意數(shù)字+EEPROM
ID:242950 發(fā)表于 2017-11-1 16:29 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
1. 利用矩陣鍵盤在數(shù)碼管上輸入刪除任意任意數(shù)字
2. 將數(shù)字存儲到EEPROM芯片中,并且能夠讀出來
部分程序:
  1. #include<reg52.h> //包含頭文件,一般情況不需要改動,頭文件包含特殊功能寄存器的定義
  2. #include "i2c.h"
  3. #define DataPort P0 //定義數(shù)據(jù)端口 程序中遇到DataPort 則用P0 替換
  4. #define KeyPort P3
  5. sbit LATCH1=P2^5;//定義鎖存使能端口 段鎖存
  6. sbit LATCH2=P2^6;//                 位鎖存
  7. ///sbit wp=p2^0 sbit scl=p2^1 sbit wp=vcc/gnd
  8. unsigned char code dofly_DuanMa[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
  9.                               0,0,0,0,0,0,0,0,0};// 顯示段碼值0~F
  10. unsigned char code dofly_WeiMa[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//分別對應(yīng)相應(yīng)的數(shù)碼管點亮,即位碼
  11. unsigned char TempData[19]; //存儲顯示值的全局變量
  12. void DelayUs2x(unsigned char t);//us級延時函數(shù)聲明
  13. void DelayMs(unsigned char t); //ms級延時
  14. void Display(unsigned char FirstBit,unsigned char Num);//數(shù)碼管顯示函數(shù)
  15. unsigned char KeyScan(void);//鍵盤掃描
  16. unsigned char KeyPro(void);
  17. void Init_Timer0(void);//定時器初始化
  18. unsigned char num1,j;
  19. /*------------------------------------------------
  20.                     主函數(shù)
  21. ------------------------------------------------*/
  22. void main (void)
  23. {
  24. unsigned char  num,num1,i=0;
  25.
  26. Init_Timer0();
  27.
  28. IRcvStr(0xae,80,&TempData,18);
  29. while (1)         //主循環(huán)
  30.   {
  31. num=KeyPro();
  32. //   if(num==11)
  33. //   b++;
  34. //   if(num==12)
  35. //   {
  36. //
  37. //  TempData[b-1]=0;
  38. //  ISendStr(0xae,80,TempData,10);
  39. //  DelayMs(1);
  40. //
  41. //  b=0;
  42. //   }
  43. if(num!=0xff)
  44.    {        num1=num;
  45.       j=num1-8 ;
  46.       DelayMs(10);
  47.        if(num>=0&&num<9)
  48.       {   DelayMs(10);
  49.
  50.   TempData[i]=dofly_DuanMa[num];
  51.
  52.     i++;
  53.     Display(0,8);
  54.     ISendStr(0xae,80,&TempData,18);
  55.    DelayMs(1);
  56.     if(i==8)
  57.     i=0;
  58.
  59. }
  60.
  61.     if(num>=9)
  62.      {  DelayMs(10);
  63.    TempData[j]=dofly_DuanMa[num];
  64. ISendStr(0xae,80,&TempData,18);
  65.     DelayMs(10);
  66.    Display(0,8);
  67.           }
  68.
  69.              } }}
  70. /*------------------------------------------------
  71. uS延時函數(shù),含有輸入?yún)?shù) unsigned char t,無返回值
  72. unsigned char 是定義無符號字符變量,其值的范圍是
  73. 0~255 這里使用晶振12M,精確延時請使用匯編,大致延時
  74. 長度如下 T=tx2+5 uS
  75. ------------------------------------------------*/
  76. void DelayUs2x(unsigned char t)
  77. {
  78. while(--t);
  79. }
  80. /*------------------------------------------------
  81. mS延時函數(shù),含有輸入?yún)?shù) unsigned char t,無返回值
  82. unsigned char 是定義無符號字符變量,其值的范圍是
  83. 0~255 這里使用晶振12M,精確延時請使用匯編
  84. ------------------------------------------------*/
  85. void DelayMs(unsigned char t)
  86. {
  87.
  88. while(t--)
  89. {
  90.      //大致延時1mS
  91.      DelayUs2x(245);
  92.   DelayUs2x(245);
  93. }
  94. }
  95. /*------------------------------------------------
  96. 顯示函數(shù),用于動態(tài)掃描數(shù)碼管
  97. 輸入?yún)?shù) FirstBit 表示需要顯示的第一位,如賦值2表示從第三個數(shù)碼管開始顯示
  98. 如輸入0表示從第一個顯示。
  99. Num表示需要顯示的位數(shù),如需要顯示99兩位數(shù)值則該值輸入2
  100. ------------------------------------------------*/
  101. void Display(unsigned char FirstBit,unsigned char Num)
  102. {
  103.       static unsigned char i=0;
  104. //    if(num1==9)
  105. //    {
  106. //
  107. //
  108. //       DataPort=dofly_WeiMa[j+FirstBit]; //取位碼
  109. //       LATCH2=1;     //位鎖存
  110. //       LATCH2=0;
  111. //
  112. //       DataPort=0; //取顯示數(shù)據(jù),段碼
  113. //       LATCH1=1;     //段鎖存
  114. //       LATCH1=0;
  115. //
  116. //     }
  117. //     else
  118.     {
  119.     DataPort=0;   //清空數(shù)據(jù),防止有交替重影
  120.        LATCH1=1;     //段鎖存
  121.        LATCH1=0;
  122.        DataPort=dofly_WeiMa[i+FirstBit]; //取位碼
  123.        LATCH2=1;     //位鎖存
  124.        LATCH2=0;
  125.        DataPort=TempData[i]; //取顯示數(shù)據(jù),段碼
  126.        LATCH1=1;     //段鎖存
  127.        LATCH1=0;
  128.
  129.     i++;
  130.        if(i==Num)
  131.        i=0;   }
  132. }
  133. /*------------------------------------------------
  134.                     定時器初始化子程序
  135. ------------------------------------------------*/
  136. void Init_Timer0(void)
  137. {
  138. TMOD |= 0x01;   //使用模式1,16位定時器,使用"|"符號可以在使用多個定時器時不受影響
  139. //TH0=0x00;       //給定初值
  140. //TL0=0x00;
  141. EA=1;            //總中斷打開
  142. ET0=1;           //定時器中斷打開
  143. TR0=1;           //定時器開關(guān)打開
  144. }
  145. /*------------------------------------------------
  146.                  定時器中斷子程序
  147. ------------------------------------------------*/
  148. void Timer0_isr(void) interrupt 1
  149. {
  150. TH0=(65536-2000)/256;    //重新賦值 2ms
  151. TL0=(65536-2000)%256;
  152. Display(0,8);       // 調(diào)用數(shù)碼管掃描
  153. }
  154. /*------------------------------------------------
  155.           按鍵掃描函數(shù),返回掃描鍵值
  156. ------------------------------------------------*/
  157. unsigned char KeyScan(void)  //鍵盤掃描函數(shù),使用行列反轉(zhuǎn)掃描法
  158. {
  159. unsigned char cord_h,cord_l;//行列值中間變量
  160. KeyPort=0x0f;            //行線輸出全為0
  161. cord_h=KeyPort&0x0f;     //讀入列線值
  162. if(cord_h!=0x0f)    //先檢測有無按鍵按下
  163. {
  164.   DelayMs(10);        //去抖
  165.   if((KeyPort&0x0f)!=0x0f)
  166.   {
  167.     cord_h=KeyPort&0x0f;  //讀入列線值
  168.     KeyPort=cord_h|0xf0;  //輸出當(dāng)前列線值
  169.     cord_l=KeyPort&0xf0;  //讀入行線值
  170.     while((KeyPort&0xf0)!=0xf0);//等待松開并輸出
  171.     return(cord_h+cord_l);//鍵盤最后組合碼值
  172.    }
  173.   }return(0xff);     //返回該值
  174. }
  175. /*------------------------------------------------
  176.               按鍵值處理函數(shù),返回掃鍵值
  177. ------------------------------------------------*/
  178. unsigned char KeyPro(void)
  179. {
  180. switch(KeyScan())
  181. {
  182.   case 0x7e:return 0;break;//0 按下相應(yīng)的鍵顯示相對應(yīng)的碼值
  183.   case 0x7d:return 1;break;//1
  184.   case 0x7b:return 2;break;//2
  185.   case 0x77:return 3;break;//3
  186.   case 0xbe:return 4;break;//4
  187.   case 0xbd:return 5;break;//5
  188.   case 0xbb:return 6;break;//6
  189.   case 0xb7:return 7;break;//7
  190.   case 0xde:return 8;break;//8
  191.   case 0xdd:return 9;break;//9
  192.   case 0xdb:return 10;break;//a
  193.   case 0xd7:return 11;break;//b
  194.   case 0xee:return 12;break;//c
  195.   case 0xed:return 13;break;//d
  196.   case 0xeb:return 14;break;//e
  197.   case 0xe7:return 15;break;//f
  198.   default:return 0xff;break;
  199. }
  200. }
r任意刪除數(shù)碼管,開關(guān)記憶.rar
41.04 KB, 下載次數(shù): 12, 下載積分: 黑幣 -5
admin + 50 共享資料的黑幣獎勵!
