#include <reg52.h>
sbit lcdrs = P3^5;//液晶引腳定義
sbit led_cs = P3^6;
sbit lcden = P3^4;
sbit dx = P2^7;//數(shù)碼管引腳定義
sbit wx = P2^6;
sbit key1 = P3^0;
sbit key2 = P3^1;
sbit key3 = P3^2;
sbit keyE = P3^3;
uchar num,key1num,count,hour,min,sec;
uchar code cg_1602[]= { 0x08,0x0f,0x12,0x0f,0x0a,0x1f,0x02,0x02,
0x0f,0x09,0x0f,0x09,0x0f,0x09,0x11,0x00,
0x0f,0x09,0x09,0x0f,0x09,0x09,0x0f,0x00
};//"年月日"
/*延時函數(shù)*/
void delay(uint xms) {
uint i,j;
for(i=xms; i>0; i--)
for(j=114; j>0; j--);
/*1602液晶*/
void write_com(uchar com) { //寫命令
lcdrs=0;
lcden=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_data(uchar date) { //寫數(shù)據(jù)
lcdrs=1;
lcden=0;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_by_xy(uchar x,uchar y) { //坐標定位
uchar address;
if(y==0)
address=0x80+x;//y=0,寫第一行
address=0xc0+x;//y=1,寫第二行
write_com(address);
void write_char(uchar x,uchar y,uchar date) { //坐標定位顯示
write_by_xy(x,y);//先定位
write_data(date);//后寫數(shù)
void write_string(uchar x,uchar y,uchar *s) { //寫字符串
write_by_xy(x,y);//設定顯示位置
while(*s) { //write character
P0=*s;
write_data(*s);
s++;
void write_sfm(uchar add,uchar date) { //寫時分秒函數(shù)
uchar hour,ge;
hour=date/10;//分解一個2位數(shù)的十位和個位
ge=date%10;
write_com(0x80+0x40+add);//設置顯示位置
write_data(0x30+hour);//送去液晶顯示十位
write_data(0x30+ge); //送去液晶顯示個位
void write_cg() { //寫入固定漢字和符號
write_com(0x40); //設定CGRAM地址
for(num=0; num<24; num++) { //將自定義字型碼寫入CGRAM中
write_data(cg_1602[num]);
write_com(0x84);//年
write_data(0);
write_com(0x87);//月
write_data(1);
write_com(0x8a);//日
write_data(2);
write_string(2,1,":");
write_string(5,1,":");
write_string(9,1,"Liguixin");
void init_1602() { //初始化
dx=0;
wx=0;
led_cs=0;
hour=18;
min=00;
sec=00;
key1num=0;
count=0;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_string(0,0,"2017");
write_string(5,0,"11");
write_string(8,0,"1");
write_sfm(0,hour);
write_sfm(3,min);
write_sfm(6,sec);
write_cg();
TMOD=0x01;//設置定時器0工作模式1
TH0=(65536-50000)/256;//定時器裝初值
TL0=(65536-50000)%256;
EA=1; //開總中斷
ET0=1; //開定時器0中斷
TR0=1; //啟動定時器0
/*鍵盤掃描函數(shù)*/
void keyscan() { //按鍵掃描函數(shù)
keyE =0;
if(key1==0) {
delay(5);
if(key1==0) { //確認功能鍵被按下
key1num++;//功能鍵按下次數(shù)記錄
while(!key1);//釋放確認
if(key1num==1) { //第一次被按下時
TR0=0; //關閉定時器
write_com(0x80+0x40+7);//光標定位到秒位置
write_com(0x0f); //光標開始閃爍
if(key1num==2) { //第二次按下光標閃爍定位到分鐘位置
write_com(0x80+0x40+4);
if(key1num==3) { //第三次按下光標閃爍定位到小時位置
write_com(0x80+0x40+1);
if(key1num==4) { //第四次按下
key1num=0;//記錄按鍵數(shù)清零
write_com(0x0c);//取消光標閃爍
TR0=1; //啟動定時器使時鐘開始走
if(key1num!=0) { //只有功能鍵被按下后,增加和減小鍵才有效
if(key2==0) {
delay(5);
if(key2==0) { //增加鍵確認被按下
while(!key2);//按鍵釋放
if(key1num==1) { //若功能鍵第一次按下
sec++; //則調整秒加1
if(sec==60)//若滿60后將清零
sec=0;
write_sfm(6,sec);//每調節(jié)一次送液晶顯示一下
write_com(0x80+0x40+7);//顯示位置重新回到調節(jié)處
if(key1num==2) { //若功能鍵第二次按下
min++;//則調整分鐘加1
if(min==60)//若滿60后將清零
min=0;
write_sfm(3,min);//每調節(jié)一次送液晶顯示一下
write_com(0x80+0x40+4);//顯示位置重新回到調節(jié)處
if(key1num==3) { //若功能鍵第三次按下
hour++;//則調整小時加1
if(hour==24)//若滿24后將清零
hour=0;
write_sfm(0,hour);;//每調節(jié)一次送液晶顯示一下
write_com(0x80+0x40+1);//顯示位置重新回到調節(jié)處
if(key3==0) {
delay(5);
if(key3==0) { //確認減小鍵被按下
while(!key3);//按鍵釋放
sec--;//則調整秒減1
if(sec==-1)//若減到負數(shù)則將其重新設置為59
sec=59;
min--;//則調整分鐘減1
if(min==-1)//若減到負數(shù)則將其重新設置為59
min=59;
if(key1num==3) { //若功能鍵第二次按下
hour--;//則調整小時減1
if(hour==-1)//若減到負數(shù)則將其重新設置為23
hour=23;
write_sfm(0,hour);//每調節(jié)一次送液晶顯示一下
/*主函數(shù)*/
void main() {
dx=0;
wx=0;
led_cs=0;
init_1602();
while(1) {
keyscan();
/*中斷函數(shù)*/
void timer0() interrupt 1 { //定時器0中斷服務程序
TH0=(65536-50000)/256;//再次裝定時器初值
count++; //中斷次數(shù)累加
if(count==20) { //20次50毫秒為1秒
count=0;
sec++;
if(sec==60) { //秒加到60則進位分鐘
sec=0;//同時秒數(shù)清零
min++;
if(min==60) { //分鐘加到60則進位小時
min=0;//同時分鐘數(shù)清零
hour++;
if(hour==24) { //小時加到24則小時清零
hour=0;
write_sfm(0,hour);//小時若變化則重新寫入
write_sfm(3,min);//分鐘若變化則重新寫入
write_sfm(6,sec);//秒若變化則重新寫入
