查看: 2507|回復: 2
74HC595擴展控制8位數(shù)碼管
ID:245375 發(fā)表于 2017-11-2 16:43 | 顯示全部樓層 |閱讀模式
#include<REG52.H>
#define ui unsigned int
#define uc unsigned char
uc code tube[] = {0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40,0x00};
uc code xx[] = {0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
sbit DAT = P3^4;
sbit rck = P3^5;
sbit sck = P3^6;
uc l,i,k=0;
void S_data(  uc chip_4 ,uc chip_3 )
        uc i;
        rck = 0;
        for(i=0;i<8;i++)
                sck = 0;//從低位到高位
                chip_4 <<= 1;
                DAT = CY;
                sck = 1;
        for(i=0;i<8;i++)
                sck = 0;//從低位到高位
                chip_3 <<= 1;
                DAT = CY;
                sck = 1;
        rck = 1;
void delay()
void display(void)
        uc j=0;
        if(l == 5)
                l = 0;
                S_data(xx[k],tube[j + k]);
                        delay();
                k++;
                if (k == 8)
                        k = 0;
void star(void)
        TMOD = 0X01;
        TH0 = (65536-45872)/256;
        TL0 = (65536-45872)%256;
        EA = 1;
        ET0 = 1;
        TR0 = 1;
void time() interrupt 1
        l++;
        star();
                display();
ID:358284 發(fā)表于 2018-6-27 11:30 | 顯示全部樓層
請問中間的cy是什么意思?
ID:245375 發(fā)表于 2018-9-10 14:42 | 顯示全部樓層
吉法師 發(fā)表于 2018-6-27 11:30
請問中間的cy是什么意思?
這是51的一個運算位,你可以理解為移出去的那一位就在CY里面
