用AT89C52芯片作為主控芯片實現(xiàn)計時/定時的功能,使用單片機內置的定時器以中斷的方式產生以秒為單位的時間信號,產生的時間數(shù)據通過計算分成四位在數(shù)碼管上以逐位掃描的方式顯示出來,由于掃描速度足夠快,因此看上去四位數(shù)字是同時顯示的,另外還用了七個io口對應七個功能按鍵,按下去時可以拉低引腳電平,通過檢測電平變化來判斷按鍵是否被按下,七個按鍵可以實現(xiàn)時間的調整以及計時暫停繼續(xù)清零等功能。
2017-11-4 16:17 上傳
2017-11-4 16:17 上傳
- #include<reg52.h>
- sbit w1 = P3 ^ 6;
- sbit w2 = P1 ^ 5;
- sbit w3 = P1 ^ 4;
- sbit w4 = P1 ^ 3;
- sbit a = P3 ^ 5;
- sbit b = P1 ^ 2;
- sbit c = P1 ^ 7;
- sbit d = P3 ^ 2;
- sbit e = P3 ^ 3;
- sbit f = P3 ^ 4;
- sbit g = P1 ^ 6;
- sbit h = P3 ^ 1;
- sbit set = P2 ^ 5;
- sbit stop = P2 ^ 7;
- sbit clear = P2 ^ 6;
- sbit up = P2 ^ 2;
- sbit down = P2 ^ 1;
- sbit right = P2 ^ 3;
- sbit left = P2 ^ 0;
- sbit led = P3 ^ 7; //各io口設置
- bit settime = 0; //是否進入時間設定模式的判斷變量
- bit pause = 0; //是否暫停的標志變量
- int time = 3599; //時間數(shù)據,初始值為59:59
- unsigned char num; //定時器中斷次數(shù)記錄變量
- unsigned char bj1 = 0, bj2 = 0, bj3 = 1,bj4=0; //標記變量
- void xianshi( int i ) { //數(shù)碼管位選函數(shù),顯示0~9
- switch ( i ) {
- case 0:
- a = b = c = d = e = f = g = h = 0;
- a = b = c = e = d = f = 1;
- break;
- case 1:
- b = c = 1;
- break;
- case 2:
- a = b = g = e = d = 1;
- break;
- case 3:
- a = b = g = c = d = 1;
- break;
- case 4:
- f = g = b = c = 1;
- break;
- case 5:
- a = f = g = c = d = 1;
- break;
- case 6:
- a = f = e = g = c = d = 1;
- break;
- case 7:
- a = b = c = 1;
- break;
- case 8:
- a = b = c = d = e = f = g = 1;
- break;
- case 9:
- a = b = c = d = g = f = 1;
- break;
- void delay( int i ) //延時函數(shù)大概延時ims
- int j;
- for ( i; i >= 0; i-- ) {
- for ( j = 110; j >= 0; j-- );
- void zijiang( void ) //數(shù)碼管自檢函數(shù)
- int i;
- w1 = w2 = w3 = w4 = 0;
- a = b = c = d = e = f = g = h = 1;
- delay( 800 );
- for ( i = 0; i <= 9; i++ ) {
- xianshi( i );
- delay( 500 );
- w1 = w2 = w3 = w4 = 1;
- bj3 = 0;
- void display( int i ) //數(shù)碼管時間顯示函數(shù)
- int w, x, y, z;
- w = ( ( i / 60 ) / 10 );
- x = ( ( i / 60 ) % 10 );
- y = ( ( i % 60 ) / 10 );
- z = ( ( i % 60 ) % 10 );
- w1 = 0;
- xianshi( w );
- delay( 5 );
- w1 = 1;
- w2 = 0;
- xianshi( z );
- delay( 5 );
- w2 = 1;
- w3 = 0;
- xianshi( x );
- delay( 5 );
- w3 = 1;
- w4 = 0;
- xianshi( y );
- delay( 5 );
- w4 = 1;
- void setdisplay( int i,int j ) //設置時間時數(shù)碼管時間顯示函數(shù),帶有閃爍功能
- int w, x, y, z;
- w1 = 0;
- if(j==1)
- bj4++;
- if(bj4>=50)
- w1=1;
- if(bj4>=100)
- bj4=0;
- xianshi( w );
- delay( 5 );
- w1 = 1;
- w2 = 0;
- if(j==4)
- bj4++;
- if(bj4>=50)
- w2=1;
- if(bj4>=100)
- bj4=0;
- xianshi( z );
- delay( 5 );
- w2 = 1;
- w3 = 0;
- if(j==2)
- bj4++;
- if(bj4>=50)
- w3=1;
- if(bj4>=100)
- bj4=0;
- xianshi( x );
- delay( 5 );
- w3 = 1;
- w4 = 0;
- if(j==3)
- bj4++;
- if(bj4>=50)
- w4=1;
- if(bj4>=100)
- bj4=0;
- xianshi( y );
- delay( 5 );
- w4 = 1;
- void T0_time()interrupt 1 //中斷產生時間信號
- TH0 = 59;
- TL0 = 114; //重裝初值
- num++;
- void main()
- int j = 1;
- TH0 = 59;
- TL0 = 146; //定時器設置及裝填初值
- EA = 1;
- ET0 = 1;
- led=0;
- while ( 1 )
- if ( bj3 == 1 )
- zijiang(); //自檢函數(shù),只運行一次
- while(bj2==1)
- if ( set == 0 ) //設置函數(shù),按下設置鍵進入函數(shù)
- delay( 10 );
- if ( set == 0 )
- while(!set); //按鍵防抖,并且防止按一次重復多次
- settime = 1;
- if ( settime == 1 )
- setdisplay( time,j );
- if ( right == 0 ) //時間設置右移
- delay( 10 );
- if ( right == 0 )
- while ( !right );
- j++;
- if ( j == 5 )
- j = 1;
- if ( left == 0 ) //時間設置左移
- delay( 10 );
- if ( left == 0 )
- while ( !left );
- j--;
- if ( j == 0 )
- j = 4;
- if ( up == 0 ) //時間加
- delay( 10 );
- if ( up == 0 )
- while ( !up );
- switch ( j )
- case 1:
- time = time + 600;
- if ( ( time / 600 ) > 5 )
- time = time - 3600;
- break;
- case 2:
- time = time + 60;
- if ( ( ( time / 60 ) % 10 ) == 0 )
- time = time - 600;
- break;
- case 3:
- time = time + 10;
- if ( ( ( time % 60 ) / 10 ) > 5 )
- time = time - 60;
- break;
- case 4:
- time++;
- if ( ( ( time % 60 ) / 10 ) == 0 )
- time = time - 10;
- break;
- if ( down == 0 ) //時間減
- delay( 10 );
- if ( down == 0 )
- while ( !down );
- switch ( j )
- case 1:
- if ( time / 600 == 0 )
- time = time + 3600;
- break;
- case 2:
- time = time - 60;
- break;
- case 3:
- time = time + 60;
- time = time - 10;
- break;
- case 4:
- if ( ( ( time % 60 ) % 10 ) == 0 )
- time = time + 10;
- time--;
- break;
- if ( stop == 0 ) //開始按鈕,按下開始計時
- delay( 10 );
- if ( stop == 0 )
- while ( !stop );
- bj2 = 0;
- if ( clear == 0 ) //清零按鈕,按下時間清零
- delay( 10 );
- if ( clear == 0 )
- while ( !clear );
- time = 0;
- while ( bj2 == 0 ) //計時部分從59:59開始倒計時
- TR0 = 1;
- display( time );
- if ( num >= 160 )
- num = 0;
- time--;
- if(time==0) //判斷即使是否結束
- led=1;
- TR0=0;
- if ( set == 0 ) //設置按鈕,按下進入設置模式
- delay(10);
- if ( set == 0 )
- while ( !set );
- bj2 = 1;
- TR0 = 0;
- if ( stop == 0 ) //暫停/開始按鈕,按下暫;蛘唛_始計時
- delay( 10 );
- if ( stop == 0 )
- { while(!stop);
- bj2=1-bj2;
- if ( bj2 == 0 )
- TR0 = 1;
- else
- TR0 = 0;
復制代碼
