查看: 17704|回復(fù): 9
4×4矩陣鍵盤的按鍵在lcd上顯示數(shù)字仿真及單片機代碼
ID:207443 發(fā)表于 2017-11-5 20:53 | 顯示全部樓層 |閱讀模式
全部資料51hei下載地址:
4×4矩陣鍵盤的按鍵在lcd上顯示數(shù)字.rar (91.96 KB, 下載次數(shù): 289)
單片機代碼:
#include <reg51.h>
#include <intrins.h>                        //包含_nop_( )空函數(shù)指令的頭文件
#define out P0
sbit RS=P2^0;                                         //位變量
sbit RW=P2^1;                                        //位變量
sbit E=P2^2;
void lcd_initial(void);                                                //位變量void lcd _initial(void);                                        //LCD初始化函數(shù)
void check_busy(void);                                 //檢查忙標(biāo)志函數(shù)
void write_command(uchar com);                         //寫命令函數(shù)
void write_data(uchar dat);                        //寫數(shù)據(jù)函數(shù)
void string(uchar ad ,uchar *s);
void delay(uint);                                //延時函數(shù)
unsigned char key_scan()
        unsigned char key_temp0,key_temp1;
        unsigned char key_num=0;
        P1=0x0f;
        key_temp0=P1;
        if(key_temp0!=0x0f)
                delay(5);
                key_temp0=P1;
                if(key_temp0!=0x0f)
                        P1=0xf0;
                        key_temp1=P1;
                        if(key_temp0==0x0e)
                                switch(key_temp1)
                                        case 0xe0: key_num=4;break;
                                        case 0xd0: key_num=3;break;
                                        case 0xb0: key_num=2;break;
                                        case 0x70: key_num=1;break;
                                        default:key_num=0;break;
                        else if(key_temp0==0x0d)
                                switch(key_temp1)
                                        case 0xe0: key_num=8;break;
                                        case 0xd0: key_num=7;break;
                                        case 0xb0: key_num=6;break;
                                        case 0x70: key_num=5;break;
                        else if(key_temp0==0x0b)
                                switch(key_temp1)
                                        case 0xe0: key_num=12;break;
                                        case 0xd0: key_num=11;break;
                                        case 0xb0: key_num=10;break;
                                        case 0x70: key_num=9;break;
                        else if(key_temp0==0x07)
                                switch(key_temp1)
                                        case 0xe0: key_num=16;break;
                                        case 0xd0: key_num=15;break;
                                        case 0xb0: key_num=14;break;
                                        case 0x70: key_num=13;break;
return key_num;
void main(void)                         //主函數(shù)
        unsigned char key_num;
        lcd_initial( );                        //調(diào)用對LCD初始化函數(shù)
   do
                        key_num=key_scan();
                        string(0x82,"Yu Wang wang");                //顯示的第1行字符串
                  switch(key_num)
                                case 1 :string(0xC8,"1");  break;
                                case 2 :string(0xC8,"2");  break;
                                case 3 :string(0xC8,"3");  break;
                                case 4 :string(0xC8,"4");  break;
                                case 5 :string(0xC8,"5");  break;
                                case 6 :string(0xC8,"6");  break;
                                case 7 :string(0xC8,"7");  break;
                                case 8 :string(0xC8,"8");  break;
                                case 9 :string(0xC8,"9");  break;
                                case 10:string(0xC8,"10"); break;
                                case 11:string(0xC8,"11"); break;
                                case 12:string(0xC8,"12"); break;
                                case 13:string(0xC8,"13"); break;
                                case 14:string(0xC8,"14"); break;
                                case 15:string(0xC8,"15"); break;
                                case 16:string(0xC8,"16"); break;
                        delay(100);                         //延時
                        write_command(0x01);                //寫入清屏命令
                        delay(1);                        //延時
         }while(1);
void delay(uint j)                        //1ms延時子程序
        uchar i=250;
        for(;j>0;j--)
                while(--i);
                i=249;
                while(--i);
                i=250;
void check_busy(void)                        //檢查忙標(biāo)志函數(shù)
        uchar dt;
        do
                dt=0xff;
                E=0;
                RS=0;
                RW=1;
E=1;
dt=out;
}while(dt&0x80);
E=0;
void write_command(uchar com)                 //寫命令函數(shù)
check_busy();
E=0;
RS=0;
RW=0;
out=com;
E=1;
_nop_( );
E=0;
delay(1);
void write_data(uchar dat)                                 //寫數(shù)據(jù)函數(shù)
        check_busy();
        E=0;
        RS=1;
        RW=0;
        out=dat;
        E=1;
        _nop_();
        E=0;
        delay(1);
void LCD_initial(void)                         //液晶顯示器初始化函數(shù)
write_command(0x38);        //寫入命令0x38:8位兩行顯示,5×7點陣字符
write_command(0x0C);        //寫入命令0x0C:開整體顯示,光標(biāo)關(guān),無黑塊
write_command(0x06);        //寫入命令0x06:光標(biāo)右移
write_command(0x01);                         //寫入命令0x01:清屏
delay(1);
void string(uchar ad,uchar *s)        //輸出顯示字符串的函數(shù)
write_command(ad);
while(*s>0)
write_data(*s++);                        //輸出字符串,且指針增1
delay(50);
admin + 50 共享資料的黑幣獎勵!
ID:316059 發(fā)表于 2018-4-25 11:38 | 顯示全部樓層
把string(0x82,"Yu Wang wang");     這行屏蔽了 效果就明顯了
ID:256783 發(fā)表于 2018-6-24 20:23 | 顯示全部樓層
根本沒有工程文件
ID:414868 發(fā)表于 2018-10-29 17:53 | 顯示全部樓層
有沒有數(shù)碼管的
ID:632906 發(fā)表于 2019-10-30 20:57 | 顯示全部樓層
代碼沒錯,原理圖也沒錯,為什么就是不顯示呢
ID:735660 發(fā)表于 2020-4-22 22:51 | 顯示全部樓層
非常好的代碼
ID:761855 發(fā)表于 2020-5-30 09:43 | 顯示全部樓層
程序下載了,proteus工程文件在那里啊
ID:382952 發(fā)表于 2020-6-6 09:48 | 顯示全部樓層
附件在哪
ID:939552 發(fā)表于 2021-6-17 19:37 | 顯示全部樓層
大家不能發(fā)個匯編語言的?我想要學(xué)習(xí)匯編語言
ID:989272 發(fā)表于 2021-12-8 09:57 | 顯示全部樓層
感謝大佬分析
