查看: 2479|回復: 1
按鍵加減控制數(shù)碼管程序按鍵為啥沒反應,大神們看看
回帖獎勵 10 黑幣 回復本帖可獲得 1 黑幣獎勵! 每人限 1 次(中獎概率 50%)
ID:241873 發(fā)表于 2017-11-7 16:24 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#define        dataport        P0
#define        uchar        unsigned        char
#define        uint        unsigned        int
uchar        code        duanma[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar        code        weima[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
uchar        tempdata[8];
sbit        key1=P3^3;
sbit        key2=P3^4;
sbit        latch1=P2^2;
sbit        latch2=P2^3;
void        delayus2x(uchar        t);
void        delayms(uchar        t);
void        display(uchar        firstbit,uchar        num);
void        main(void)
        uchar        num=0;
        key1=1;
        key2=1;
                if(!key1)
                        delayms(10);
                if(!key1)
                        while(!key1);
                                if(num<9)
                                        num++;
        if(!key2)
                delayms(10);
        if(!key2)
                while(!key2);
                        if(num>0)
                                num--;
        tempdata[0]=duanma[num%10];
        display(0,1);
while(--t);
while(t--)
     delayus2x(245);
         delayus2x(245);
        uchar        i;
        for(i=0;i<num;i++)
                dataport=0;
                latch1=1;
                latch1=0;
                dataport=weima[firstbit+i];
                latch2=1;
                latch2=0;
                dataport=tempdata[i];
                latch1=1;
                latch1=0;
                delayms(2);
ID:244971 發(fā)表于 2017-11-7 20:16 | 顯示全部樓層
這樣好多了?
