實物制作:http://www.torrancerestoration.com/bbs/dpj-97928-1.html
- /***采用四個74hc573,***/
- #include<reg52.h>
- sbit sao=P2^3; //573使能端前8位,行掃描
- sbit sao1=P2^2; //573使能端后8位,行掃描
- sbit su=P2^1; //573使能端前8位,列數(shù)據(jù)傳送
- sbit su1=P2^0; //573使能端后8位,列數(shù)據(jù)傳送
- unsigned char a,b,c;
- unsigned char code tbo[]={
- 0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,
- };//掃描數(shù)據(jù),根據(jù)連線更改
- unsigned char code tbo1[30][32]={
- {0xFE,0xFE,0x00,0xFE,0xFE,0x80,0x93,0x99,
- 0x90,0x9E,0x9E,0x80,0x9E,0x9E,0x9E,0x9F,
- 0x7F,0x7F,0x00,0x7F,0x7F,0x01,0xC9,0x99,
- 0x09,0x79,0x79,0x01,0x79,0x79,0x61,0xF3},/*"南",0*/
- {0xFC,0xFE,0x00,0xF9,0xF9,0xF3,0xE7,0xC0,
- 0xF9,0xF9,0xF9,0xF9,0xF3,0xF3,0xE7,0x8F,
- 0xFF,0x7F,0x00,0xFF,0xFF,0xCF,0xE7,0x03,
- 0x93,0x9F,0x9F,0x9F,0x99,0x99,0x99,0xC1},/*"充",1*/
- {0xFE,0x02,0xF2,0xF2,0xF2,0x82,0x9E,0x98,
- 0x9E,0x82,0xF2,0xF2,0xF2,0xF2,0x86,0xCE,
- 0x7F,0x73,0x73,0x67,0x4F,0x1F,0x7F,0x00,
- 0x1F,0x4F,0x4F,0x67,0x73,0x19,0x3C,0x7F},/*"張",2*/
- {0xFC,0xCE,0xE0,0xE1,0x38,0x99,0x98,0xE0,
- 0xE0,0xC8,0x08,0xC8,0xC9,0xC8,0xC9,0xF9,
- 0xFF,0x01,0x79,0x99,0x01,0x99,0x01,0x01,
- 0x01,0x01,0x01,0x01,0x09,0x01,0x99,0x91},/*"瀾",3*/
- {0xE7,0xE7,0xE7,0xE4,0x01,0xE7,0xE7,0xE0,
- 0xE3,0xC7,0x07,0xE7,0xE7,0xE7,0x86,0xC8,
- 0xCF,0xCF,0xCF,0x00,0xCF,0xCF,0xCF,0x01,
- 0x39,0x33,0x93,0x87,0xCF,0x87,0x33,0xF8},/*"技",4*/
- {0xF3,0xF0,0x93,0x93,0x93,0x92,0x92,0x92,
- 0x92,0x92,0x92,0xF2,0xE6,0xE7,0xCF,0x9F,
- 0xFF,0x00,0xCF,0xCF,0xCF,0x01,0x49,0x49,
- 0x49,0x49,0x49,0x41,0x43,0xCF,0xCF,0xCF},/*"師",5*/
- {0xCC,0xE6,0xE6,0xFF,0x80,0x9F,0x3F,0xE0,
- 0xFF,0xFE,0x00,0xFE,0xFE,0xFE,0xF8,0xFC,
- 0xF3,0x73,0x67,0xCF,0x00,0xFC,0xF9,0x0F,
- 0x9F,0x3F,0x00,0x7F,0x7F,0x7F,0x7F,0xFF},/*"學(xué)",6*/
- {0xFF,0x83,0x90,0x84,0x81,0x8E,0x87,0x93,
- 0x90,0x93,0x83,0x87,0x9E,0x9E,0x9C,0x99,
- 0x9F,0xCF,0x00,0xFC,0xF9,0x03,0xFF,0xFF,
- 0x00,0x27,0x27,0x27,0x64,0x64,0xF0,0xFF},/*"院",7*/
- {0xFE,0xFE,0xFC,0xF9,0xF3,0xE7,0xC0,0x1E,
- 0xFE,0xC0,0xFE,0xE6,0xF2,0xF2,0x00,0xFF,
- 0x7F,0x7F,0x3F,0x9F,0xCF,0xE7,0x03,0x78,
- 0x7F,0x03,0x7F,0x67,0x67,0x4F,0x00,0xFF},/*"金",8*/
- {0xF9,0xF9,0xF0,0xE7,0xCF,0x80,0x0E,0xCE,
- 0xC0,0xCE,0xCE,0xC0,0xFF,0xFF,0x00,0xFF,
- 0xFF,0xFF,0x0F,0xCF,0x9F,0x03,0x73,0x73,
- 0x03,0x73,0x73,0x03,0xFF,0xFF,0x00,0xFF},/*"魚",9*/
- {0xE7,0xE7,0xE7,0xE7,0x81,0x80,0x80,0x81,
- 0x80,0x81,0x81,0x81,0x89,0xFF,0xFF,0xFF,
- 0xCF,0xCF,0x87,0x87,0x33,0x49,0xE4,0xE7,
- 0x01,0xF9,0xF3,0x33,0x87,0xCF,0xE7,0xE7},/*"嶺",10*/
- {0xE7,0xE7,0xE7,0xE6,0x01,0xE7,0xC6,0xC0,
- 0x81,0x87,0x27,0xE7,0xE7,0xE7,0xE7,0xE4,
- 0x9F,0xCF,0xCF,0x00,0xFF,0x33,0x79,0xFC,
- 0x33,0x33,0x87,0x87,0xCF,0x87,0x33,0x78},/*"校",11*/
- {0xFF,0x80,0x9F,0x9F,0x99,0x9C,0x9E,0x9F,
- 0x9E,0x9C,0x99,0x93,0x9F,0x9F,0x80,0xFF,
- 0xFF,0x01,0xFF,0xE7,0xE7,0xCF,0x1F,0x3F,
- 0x1F,0xCF,0xE7,0xE7,0xFF,0xFF,0x00,0xFF},/*"區(qū)",12*/
- {0xFF,0xFF,0xFF,0xF3,0xC3,0xF3,0xF3,0xF3,
- 0xF3,0xF3,0xF3,0xF3,0xF3,0xC0,0xFF,0xFF,/*"1",13*/
- 0xFF,0xFF,0xFF,0x80,0x9F,0x9F,0x9F,0x83,
- 0x99,0xFC,0xFC,0x9C,0x99,0xC3,0xFF,0xFF},/*"5",14*/
- {0xE7,0xE4,0xCF,0xCF,0x93,0x03,0xE7,0xCF,
- 0x9E,0x02,0x9E,0xFE,0xE0,0x0C,0x99,0xFE,
- 0xFF,0x01,0x39,0x33,0x33,0x27,0x21,0x39,
- 0x19,0x19,0x43,0x43,0xE7,0xC3,0x99,0x3C},/*"級",15*/
- {0xFE,0xFE,0xFE,0xC0,0xCE,0xCE,0xCE,0xC0,
- 0xCE,0xCE,0xCE,0xC0,0xCE,0xFE,0xFE,0xFF,
- 0x7F,0x7F,0x7F,0x03,0x73,0x73,0x73,0x03,
- 0x73,0x73,0x73,0x03,0x70,0x7C,0x7C,0x00},/*"電",16*/
- {0xFF,0x80,0xFF,0xFF,0xFF,0xFE,0xFE,0x00,
- 0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xF8,0xFC,
- 0xFF,0x03,0xE7,0xCF,0x9F,0x3F,0x7F,0x00,
- 0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0xFF},/*"子",17*/
- {0xFE,0xFE,0xFE,0xC0,0xFC,0xFC,0x00,0xF9,
- 0xF3,0xF0,0xFF,0xFF,0xF8,0xFE,0xFF,0xFF,
- 0x7F,0x7F,0x7F,0x03,0xFF,0xFF,0x00,0xFF,
- 0xFF,0x07,0xE7,0xCF,0x9F,0x3F,0x9F,0xCF},/*"專",18*/
- {0xF9,0xF9,0xF9,0xF9,0x99,0xC9,0xC9,0xE1,
- 0xE1,0xE1,0xF9,0xF9,0xF9,0xF9,0x00,0xFF,
- 0x9F,0x9F,0x9F,0x9F,0x99,0x99,0x93,0x93,
- 0x87,0x8F,0x9F,0x9F,0x9F,0x9F,0x00,0xFF},/*"業(yè)",19*/
- {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xC7,0xC7,0xFF,0xC7,0xC7,0xFF,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},/*":",20*/
- {0xF3,0xF3,0x00,0xF3,0x9F,0xC8,0xCF,0x38,
- 0x99,0x80,0xE1,0x08,0xC9,0xC9,0xC9,0xF9,
- 0xCF,0xCF,0x00,0xC3,0x99,0x00,0x9F,0x01,
- 0x99,0x01,0x99,0x01,0x99,0x99,0x81,0xF3},/*"蒲",21*/
- {0xF3,0xF3,0x00,0xF3,0xFF,0xFF,0xC0,0xCF,
- 0xCF,0xCF,0xCF,0xCF,0xCF,0x9F,0x9E,0x38,
- 0xCF,0xCF,0x00,0xCF,0x27,0x33,0x01,0x3F,
- 0x33,0x33,0x87,0x87,0xC9,0x81,0x31,0xF9},/*"茂",22*/
- {0xFC,0xFE,0xC0,0xCF,0xCF,0xC0,0xCF,0xCF,
- 0xC0,0xCC,0xCE,0xCF,0xCF,0xC9,0xC3,0xC7,
- 0xFF,0x7F,0x07,0xE7,0xE7,0x07,0xE7,0xE7,
- 0x07,0xF3,0x67,0x0F,0x9F,0xCF,0xE3,0xF8},/*"良",23*/
- {0xFF,0xFF,0xFF,0xC3,0x99,0x3C,0x3C,0x3C,
- 0x3C,0x3C,0x3C,0x04,0x91,0xC3,0xF8,0xFF,/*"Q",24*/
- 0xFF,0xFF,0xFF,0xC3,0x99,0x3C,0x3C,0x3C,
- 0x3C,0x3C,0x3C,0x04,0x91,0xC3,0xF8,0xFF},/*"Q",25*/
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},/*":",26*/
- 0xF3,0xF3,0xF3,0xF3,0xF3,0xC0,0xFF,0xFF,/*"1",27*/
- 0x99,0xFC,0xFC,0x9C,0x99,0xC3,0xFF,0xFF},/*"5",28*/
- {0xFF,0xFF,0xFF,0xF9,0xF1,0xF1,0xE1,0xC9,
- 0xC9,0x99,0x80,0xF9,0xF9,0xE0,0xFF,0xFF,/*"4",29*/
- 0xFF,0xFF,0xFF,0xE3,0xC9,0x9C,0x9C,0x9C,
- 0x9C,0x9C,0x9C,0x9C,0xC9,0xE3,0xFF,0xFF},/*"0",30*/
- {0xFF,0xFF,0xFF,0xC1,0x9C,0x9C,0x9C,0xC9,
- 0xE3,0xC9,0x9C,0x9C,0x9C,0xC1,0xFF,0xFF,/*"8",31*/
- 0xFF,0xFF,0xFF,0xC1,0x9C,0x9C,0x9C,0xFC,
- 0xF9,0xF3,0xE7,0xCF,0x9C,0x80,0xFF,0xFF},/*"2",32*/
- {0xFF,0xFF,0xFF,0x80,0x9C,0xF9,0xF9,0xF3,
- 0xF3,0xE7,0xE7,0xE7,0xE7,0xE7,0xFF,0xFF,/*"7",33*/
- 0xFF,0xFF,0xFF,0x80,0x9C,0xF9,0xF9,0xF3,
- 0xF3,0xE7,0xE7,0xE7,0xE7,0xE7,0xFF,0xFF},/*"7",34*/
- {0xFF,0xFF,0xFF,0xE3,0xC9,0x9C,0x9C,0x9C,
- 0x9C,0x9C,0x9C,0x9C,0xC9,0xE3,0xFF,0xFF,/*"0",35*/
- 0xFF,0xFF,0xFF,0xFF,0x8F,0x8F,0xFF,0xFF},/*".",36*/
- /****上面就是列數(shù)據(jù),數(shù)據(jù)可以用取模軟件生成****/
- void main()
- TMOD=0x01;
- TH0=(65536-50000)/256;
- TL0=(65536-50000)%256;
- TR0=1;
- /****這是時間設(shè)定****/
- while(1)
- if(TF0==1)//判斷定時設(shè)定是否溢出,
- TF0=0; //溢出就清零。
- c++;
- if(c==16)//溢出16次為一秒,數(shù)據(jù)之間間隔。
- c=0;
- b++; //這是數(shù)組個數(shù),滿30就重頭開始。
- if(b==30)
- b=0;
- /*下面中每一次數(shù)據(jù)傳輸后都有個清屏,也就是消隱,數(shù)據(jù)32個中前16個是
- 每個字的前一半,同理后16個*/
- for(a=0;a<8;a++) //前8位掃描;
- sao=1;
- P3=tbo[a];
- su=1;
- P1=tbo1[b][a];
- P1=0xff;
- su=0;
- su1=1;
16x16顯示(單片機(jī)).zip
(3.61 KB, 下載次數(shù): 46)
2017-11-8 16:04 上傳
點擊文件名下載附件
c文件與hex,c文件中有講解 下載積分: 黑幣 -5
