查看: 1679|回復(fù): 0
單片機音樂程序
ID:247870 發(fā)表于 2017-11-9 20:37 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg51.h>
sbit   speaker=P2^0;   //接音頻放大電路,
//sbit speaker=P3^2;
sbit    sw=P3^0;          //電后位后,sw合上后就開始放音樂,燈開始閃動,sw斷開,音樂停 止,             燈也同時停止閃動
unsigned char timer0h,timer0l,time,led=1,j=0;
unsigned char   flagd=0;
//世上只有媽媽好數(shù)據(jù)表
code unsigned char sszymmh[]={6,2,3,5,2,1,3,2,2,5,2,2,1,3,2,6,2,1,5,2,1,
6,2,4,3,2,2,5,2,1,6,2,1,5,2,2,3,2,2,1,2,1,6,1,1,5,2,1,3,2,1,2,2,4,2,2,3,
3,2,1, 5,2,2,5,2,1,6,2,1,3,2,2, 2,2,2,1,2,4, 5,2,3, 3,2,1,2,2,1,1,2,1,6,
1,1,1,2,1,5,1,6, 0,0,0
// 音階頻率表 高八位
code unsigned char FREQH[]={
0xF2,0xF3,0xF5,0xF5,0xF6,0xF7,0xF8,
0xF9,0xF9,0xFA,0xFA,0xFB,0xFB,0xFC,0xFC, //1,2,3,4,5,6,7,8,i
0xFC,0xFD,0xFD,0xFD,0xFD,0xFE,
0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFF,
// 音階頻率表 低八位
code unsigned char FREQL[]={
0x42,0xC1,0x17,0xB6,0xD0,0xD1,0xB6,
0x21,0xE1,0x8C,0xD8,0x68,0xE9,0x5B,0x8F, //1,2,3,4,5,6,7,8,i
0xEE,0x44, 0x6B,0xB4,0xF4,0x2D,
0x47,0x77,0xA2,0xB6,0xDA,0xFA,0x16,
void delay(unsigned char t)
unsigned char t1;
unsigned long t2;
for(t1=0;t1<t;t1++)
   for(t2=0;t2<8000;t2++)
TR0=0;
void t0int() interrupt 1
TR0=0;
speaker=!speaker;
TH0=timer0h;
TL0=timer0l;
TR0=1;
void song()
TH0=timer0h;
TL0=timer0l;
TR0=1;
delay(time);
void main(void)
unsigned char k,i;
TMOD=1; //置CT0定時工作方式1
EA=1;ET0=1;//IE=0x82 //CPU開中斷,CT0開中斷
   i=0;
   time=1;
   sw=1;
   while(time)
    if(sw)
     P1=0;i=0;continue;
    if(j==8)
     //led=1;
     j=0;flagd=~flagd;
     if(flagd)
      led=0x80;
      led=1;
     P1=~led;
     if(flagd)
      led=led>>1;
      led=led<<1;
     j++;
    k=sszymmh[i]+7*sszymmh[i+1]-1;
    timer0h=FREQH[k];
    timer0l=FREQL[k];
    time=sszymmh[i+2];
    i=i+3;
    song();
