查看: 4828|回復(fù): 0
基于51單片機(jī)的智能電風(fēng)扇設(shè)計(jì)
ID:247089 發(fā)表于 2017-11-10 14:19 | 顯示全部樓層 |閱讀模式
以前寫過的一個(gè)東西 有三檔調(diào)節(jié) 可以報(bào)警
#include <reg52.H>
#include <intrins.H>
#include <math.H>
sbit led1 = P1^2;
sbit OUTPUT = P3^2;                         //電機(jī)驅(qū)動(dòng)位1
sbit OUTPUT_0 = P3^3;            //電機(jī)驅(qū)動(dòng)位2
sbit RS = P1^1;                       //LCD命令及指令聲明
sbit LCDEN = P1^0;                            //LCD信號(hào)使能端聲明
sbit set_warn_temp = P1^4;            //設(shè)置報(bào)警溫度
sbit KEY_F_UP = P1^5;      //頻率上調(diào)按鈕;
sbit KEY_F_DOWN = P1^6;     //頻率下調(diào)按鈕;
sbit KEY_F_auto = P1^7;   //智能與手動(dòng)轉(zhuǎn)換調(diào)速位
int feq,flag_c = 1,flag_auto = 1;      //頻率初值相關(guān)位、檔位標(biāo)志位、智能與手動(dòng)轉(zhuǎn)換調(diào)速位轉(zhuǎn)換標(biāo)志位
uint temp_2,warn_temp = 28;                           //提取溫度
void delayMs(uint a)         //毫秒延時(shí)函數(shù)
   uint i, j;
   for(i = a; i > 0; i--)
       for(j = 100; j > 0; j--);
void t_init()               //定時(shí)器初始化
   TMOD=0x01;    //定時(shí)器0和定時(shí)器1都工作在方式1,16位計(jì)數(shù)器;
   TH0 = 1000/256;
   TL0 = 1000%256;
   ET0 = 1;
   EA = 1;
   TR0 = 1;
void key_scan()                          //按鍵掃描
  if(set_warn_temp == 0)     //頻率上調(diào)鍵按下;
          delayMs(5);
          if(set_warn_temp == 0)                             //增大檔位
                  warn_temp++;
                     while(set_warn_temp == 0);
  if(KEY_F_UP == 0)     //頻率上調(diào)鍵按下;
          delayMs(5);
          if(KEY_F_UP == 0)                      //增大檔位
                  flag_c++;
                     if(flag_c > 3)
                     flag_c = 3;
                     while(KEY_F_UP == 0);
  else if(KEY_F_DOWN == 0)   //減小檔位
          delayMs(5);
          if(KEY_F_DOWN == 0)
               flag_c--;
                   if(flag_c < 0)
                   flag_c = 0;
                   while(KEY_F_DOWN == 0);
          else if(KEY_F_auto == 0)   //智能與手動(dòng)轉(zhuǎn)換;
                delayMs(5);
                if(KEY_F_auto == 0)
                    flag_auto = ~flag_auto;
                            while(KEY_F_auto == 0);
void flag_auto_change()  //檔位隨溫度智能轉(zhuǎn)換
if(flag_auto == 1)
         if(temp_2< 25)
        flag_c = 0;
   else if((temp_2>=27) && (temp_2<=29))
        flag_c=1;
         elseif((temp_2 >= 30) && (temp_2 <= 32))
            flag_c = 2;
         elseif((temp_2 >= 33 )&&( temp_2 <= 34) )
            flag_c = 3;
void flag_feq()                  //檔位標(biāo)志位與頻率的轉(zhuǎn)換
if(flag_c == 0)
    TR0 = 0;
          OUTPUT = 0;
             TR0 = 1;
     switch(flag_c)
        case 1:
              feq = 63000;
                   break;
              case 2:
              feq = 33000;
              break;
              case 3:
              feq = 13000;
              break;
                   default:
                   break;
void timer0() interrupt 1                  //定時(shí)器中斷函數(shù)
    TH0 = (65536-feq)/256;
   TL0 = (65536-feq)%256;
   //TR1=1;      //開定時(shí)器1;
   OUTPUT = ~OUTPUT;
  //LCD部分
void delayUs()                                             //毫秒延時(shí)函數(shù)
   _nop_();
void writeComm(uchar comm)                                           //LCD命令函數(shù)
    RS = 0;
   P2 = comm;
   LCDEN = 1;
    delayUs();
   LCDEN = 0;
   delayMs(1);
void writeData(uchar dat)                                  //寫數(shù)據(jù):RS=1,RW=0;
    RS = 1;
    P2 = dat;
    LCDEN = 1;
   delayUs();
   LCDEN = 0;
   delayMs(1);
voidinit()                                                            //LCD初始化
//    dula = wela = 0;
   writeComm(0x38);
   writeComm(0x0c);
   writeComm(0x06);
   writeComm(0x01);
void writeString(uchar * str, uchar length)                       //送字符函數(shù)
    uchar i;
   for(i = 0; i < length; i++)
        writeData(str);
/**//*****************************DS18B20溫度部分*******************************/
sbitds = P3^7;        //溫度計(jì)IO引腳
void dsInit()
   unsigned int i;
   ds = 0;
    i= 100;
    while(i>0)
          i--;
   ds = 1;
    i= 4;
    while(i>0)
          i--;
void dsWait()
     unsigned int i;
     while(ds);
     while(~ds);
     i = 4;
     while(i > 0)
           i--;
bit readBit()
   unsigned int i;
   bit b;
   ds = 0;
   i++;
   ds = 1;
   i++;
    i++;
    b= ds;
    i= 8;
   while(i>0) i--;
   return b;
unsigned char readByte()
   unsigned int i;
   unsigned char j, dat;
  dat = 0;
   for(i=0; i<8; i++)
       j = readBit();
       dat = (j << 7) | (dat >> 1);
    return dat;
void writeByte(unsigned char dat)
   unsigned int i;
   unsigned char j;
   bit b;
   for(j = 0; j < 8; j++)
       b = dat & 0x01;
       dat >>= 1;
       if(b)
          ds = 0;
                     i++;
                     i++;
           ds = 1;
           i = 8;
                          while(i>0)i--;
           ds = 0;
         i = 8;
                    while(i>0)
                    i--;
           ds = 1;
          i++;
                     i++;
void sendChangeCmd()
   dsInit();
   writeByte(0xcc);
   writeByte(0x44);
void sendReadCmd()
   dsInit()
   writeByte(0xcc);
   writeByte(0xbe);
int getTmpValue()
   unsigned int tmpvalue;
   int value;
   float t;
   unsigned char low, high;
   sendReadCmd();
   low = readByte();
   high = readByte();
   tmpvalue = high;
   tmpvalue <<= 8;
   tmpvalue |= low;
   value = tmpvalue;
    t= value * 0.0625;
   value = t * 100 + (value > 0 ? 0.5 : -0.5); //大于00.5, 小于00.5
   return value;
void display(int v)                               //LCD顯示函數(shù)
         uinta,b;
   unsigned char count;
   unsigned char datas[] = {0, 0, 0, 0, 0};
   unsigned int tmp = abs(v);
          uchar table[] = "warning";
          uchar table1[] = "safe   ";
   datas[0] = tmp / 10000;
   datas[1] = tmp % 10000 / 1000;
   datas[2] = tmp % 1000 / 100;
   datas[3] = tmp % 100 / 10;
   datas[4] = tmp % 10;
         a= datas[2];
         b= datas[1];
         temp_2= b * 10 + a;
          if(temp_2 > warn_temp)
              writeComm(0x80+ 9);
       writeString(table, 7);
          if(temp_2 <= warn_temp)
             writeComm(0x80 + 9);
       writeString(table1, 7);
   writeComm(0x80+0x40);
   if(v < 0)
       writeString("- ", 2);
      writeString("+ ", 2);
   if(datas[0] != 0)
       writeData('0' + datas[0]);
   for(count = 1; count != 5; count++)
       writeData('0' + datas[count]);
       if(count == 2)
           writeData('.');
         flag_auto_change();                   //檔位隨溫度智能轉(zhuǎn)換
         writeComm(0x80+ 6);
   writeData(0x30 + flag_c);
         writeComm(0x80+ 0x40 + 13);
   writeData(0x30 + warn_temp / 10);
         writeData(0x30+ warn_temp % 10);
/*************************主函數(shù)部分***********************/
         uchartable_lev[] = "level:" ;
         uchartable_set[] = "set:" ;
   sendChangeCmd();
   init();                                             //LCD初始化
         t_init();                                 //定時(shí)器初始化
         OUTPUT_0= 0;                                  //給電機(jī)驅(qū)動(dòng)一端始終賦零
          writeComm(0x80);
          writeString(table_lev, 6);
          writeComm(0x80 + 0x40 + 9);
          writeString(table_set, 4);
       delayMs(1000); //溫度轉(zhuǎn)換時(shí)間需要750ms以上
                  key_scan();        //按鍵掃描
       display(getTmpValue());   //顯示
                  flag_feq();                                    //檔位標(biāo)志位與頻率的轉(zhuǎn)換
       sendChangeCmd();
file:///C:/Users/Liu/AppData/Local/Temp/msohtmlclip1/01/clip_image001.png
