查看: 2015|回復: 6
哪位幫我看看這個程序哪里出問題了
ID:248836 發(fā)表于 2017-11-13 10:03 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg51.h>
uint num,num1,num2,num3,num4,num5,num6;    //numóÃà′
sbit dula=P2^6;                  //éùÃ÷¶ÎÑ¡μÄËø′æ¶Ë
sbit wela=P2^7;                  //éùÃ÷λѡμÄËø′æ¶Ë
uchar code table[]={            //12òõêyÂë1ü0-FμĶÔó|μÄ16½øÖÆ′úÂë
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71}
void delay(int z)             //¾§Õñ12MhzÑóê±zoáÃëμÄÑóê±×ó3ìDò
        int i,j;
        for(i=z;i>0;i--)
            for(j=110;j>0;j--);
void dislpay()
        P0=0xff;                   //Ïûó°
        wela=1;                   //′ò¿aλѡ¶Ë
        P0=0xf7;                  //′ò¿aμúò»Î»êyÂë1ü
        wela=0;                   //Ëø′æÎ»Ñ¡DÅoÅ
        P0=0xff;
        dula=1;
        P0=table[num6];
        dula=0;                //¶ÎÑ¡êy¾YËø′æ
        delay(1);
        P0=0xff;                   //Ïûó°
        wela=1;                   //′ò¿aλѡ¶Ë
        P0=0xfb;                  //′ò¿aμúò»Î»êyÂë1ü
        P0=0xff;
        dula=1;
        P0=table[num5];
        delay(1);
        P0=0xff;                   //Ïûó°
        wela=1;                   //′ò¿aλѡ¶Ë
        P0=0xfd;                  //′ò¿aμúò»Î»êyÂë1ü
        P0=0xff;
        dula=1;
        P0=table[num4];
        delay(1);
        P0=0xff;                   //Ïûó°
        wela=1;                   //′ò¿aλѡ¶Ë
        P0=0xfe;                  //′ò¿aμúò»Î»êyÂë1ü
        P0=0xff;
        dula=1;
        P0=table[num3];
        delay(1);
void T0_time interrupt 1
        TH0=0x3C;
  TL0=0xB0;
        num++;
        if(num==20)                  //ËμÃ÷1s¶¨ê±òÑμ½
                num=0;                    //ÖÃ0£¬ÏÂ′ÎÖØD¼Æêy
                num1++;
                if(num1==60)              //ËμÃ÷1·ÖÖó¶¨ê±òѾ-μ½
                        num1=0;
                        num2++;
                        if(num2==60)           //ËμÃ÷ò»D¡ê±¶¨ê±μ½áË
                                num2=0;
                        num3=num2/10;         //óÃà′ÏÔê¾·Öμĸß룬±èèç23·Ö£¬ÏÔê¾2
                        num4=num2%10;         //óÃà′ÏÔê¾·ÖμÄμí룬±èèç23·Ö£¬ÏÔê¾3
                num5=num1/10;           //óÃà′ÏÔê¾Ãëμĸß룬±èèç23Ã룬ÏÔê¾2
                num6=num1%10            //óÃà′ÏÔê¾ÃëμÄμí룬±èèç23Ã룬ÏÔê¾3
void init()                   //¶¨ê±ÖD¶Ï3õê¼»ˉ3ìDò
        TMOD=0x01;                 //¶¨ê±Æ÷0£¬1¤×÷·½ê½116붨ê±/¼ÆêyÆ÷
        TH0=0x3C;                  //éèÖÃ50ms¶¨ê±
  TL0=0xB0;
        ET0=1;
        EA=1;
        TR0=1;
        init();
                display();
實驗5.c(15): error C141: syntax error near 'for'
實驗5.c(12): error C141: syntax error near 'void'
實驗5.c(13): error C141: syntax error near '{'
ID:248848 發(fā)表于 2017-11-13 10:37 | 只看該作者
uchar code table[]={&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;//12ò&otilde;êy&Acirc;&euml;1ü0-Fμ&Auml;&para;&Ocirc;ó|μ&Auml;16&frac12;&oslash;&Ouml;&AElig;′ú&Acirc;&euml;
0x39,0x5e,0x79,0x71};     //這里要加一個分號
ID:248853 發(fā)表于 2017-11-13 10:42 | 只看該作者
uchar code table[]數(shù)組后面加一個分好
ID:248859 發(fā)表于 2017-11-13 11:02 | 只看該作者
              num5=num1/10;
                num6=num1%10 //這里應(yīng)加上;
ID:248893 發(fā)表于 2017-11-13 12:44 | 只看該作者
兄弟少了個分號num5=num1/10;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;
&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp; num6=num1%10 //這里加上;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;
&nbsp;&nbsp;}
ID:248870 發(fā)表于 2017-11-13 13:14 | 只看該作者
for(i=z;i>0;i--)多了一個Z
ID:248920 發(fā)表于 2017-11-13 13:57 | 只看該作者
在void delay(int z)&nbsp;前在粘貼一個void delay(int z)&nbsp;
