#include <reg51.h>
sbit rw = P3^6;
sbit RS = P3^5;
sbit ds = P2^2;
sbit LCDEN = P3^4;
beep=P2^3;
uchar code table[] = " test temp:";
int value;
void delayMs(uint a) //延時(shí)
uint i, j;
for(i = a; i > 0; i--)
for(j = 100; j > 0; j--);
void writeComm(uchar comm)
RS = 0;
P0 = comm;
delayMs(5);
LCDEN = 1;
delayMs(5);
LCDEN = 0;
void writeData(uchar dat)
RS = 1;
P0 = dat;
delayMs(1);
LCDEN = 1;
delayMs(1);
LCDEN = 0;
void init()
rw = 0;
writeComm(0x38);
writeComm(0x0c);
writeComm(0x06);
writeComm(0x01);
void writeString(uchar * str, uchar length)
uchar i;
for(i = 0; i < length; i++)
writeData(str[i]);
/**//*****************************DS18B20*******************************/
void dsInit()
unsigned int i;
ds = 0;
i = 100;
while(i>0)
i--;
ds = 1;
i = 4;
while(i>0)
i--;
bit readBit()
unsigned int i;
bit b;
ds = 0;
i++;
ds = 1;
i++;
i++;
b = ds;
i = 8;
while(i>0)
i--;
return b;
unsigned char readByte()
unsigned int i;
unsigned char j, dat;
dat = 0;
for(i=0; i<8; i++)
j = readBit();
dat = (j << 7) | (dat >> 1);
return dat;
void writeByte(unsigned char dat)
int i,j;
for(j=0;j<8;j++)
ds=0;
i++;
ds=dat&0x01;
i=6;
while(i--);
ds=1;
dat>>=1;
void sendChangeCmd()//溫度轉(zhuǎn)化命令
dsInit();
delayMs(1);
writeByte(0xcc);
writeByte(0x44);
void sendReadCmd() //讀取溫度
dsInit();
delayMs(1);
writeByte(0xcc);
writeByte(0xbe);
int getTmpValue()
unsigned int tmpvalue;
float t;
unsigned char low, high;
sendReadCmd();
low = readByte();
high = readByte();
tmpvalue = high;
tmpvalue <<= 8;
tmpvalue |= low;
value = tmpvalue;
t = value * 0.0625;
value = t * 100 + (value > 0 ? 0.5 : -0.5); //大于0加0.5, 小于0減0.5
return value;
void display()
unsigned char count;
unsigned char datas[] = {0, 0, 0, 0, 0};
unsigned int tmp =getTmpValue();
datas[0] = tmp / 10000;
datas[1] = tmp % 10000 / 1000;
datas[2] = tmp % 1000 / 100;
datas[3] = tmp % 100 / 10;
datas[4] = tmp % 10;
writeComm(0xc0+3);
if(tmp< 0)
writeString("- ", 1);
writeString("+ ", 1);
for(count = 1; count < 5; count++)
writeData('0'+datas[count]);
if(count == 2)
writeData('.');
init();
writeComm(0x80);
writeString(table,11);
sendChangeCmd();//發(fā)送溫度轉(zhuǎn)化命令
delayMs(750); //溫度轉(zhuǎn)換時(shí)間需要750ms以上
writeComm(0xc0);
display();
if(value>2000)
beep=0;
P1=0x00;
beep=1;
P1=0xff;
