查看: 3647|回復: 5
從0-99數(shù)碼管顯示,用EEPROM掉電保存數(shù)據(jù), 但是程序正確, 為什么掉電數(shù)據(jù)不能保存
ID:244748 發(fā)表于 2017-11-14 22:17 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
# include <reg52.h>
# define uchar unsigned char
# define uint unsigned int
sbit scl = P2^1;
sbit sda = P2^0;
sbit        P_HC595_SER   = P2^7;        //pin 14        SER                data input
sbit        P_HC595_RCLK  = P2^5;        //pin 12        RCLk        store (latch) clock
sbit        P_HC595_SRCLK = P2^6;        //pin 11        SRCLK        Shift data clock
char code t_display[]={
//         0    1    2    3    4    5    6    7    8    9  //
        0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F, 0};
void init();
void start();
void stop();
void respons();
void write_byte(uchar);
uchar read_byte();
void delay();
//void delay1(uint);
void write_add(uchar, uchar);
uchar read_add(uchar);
void init1();
void we();
void dage(uchar, uchar);
void Send_595(uchar);
uchar shu, shi, ge, write, aa;
        init();
        //delay1(100);
        shu = read_add(2);
        init1();
        dage(11, 11);
        we();
        dage(shi, ge);
                if(write == 1)
                        write = 0;
                        write_add(2, shu);
void init()
        sda = 1;
        delay();
        scl = 1;
        delay();
void start()
        sda = 1;
        delay();
        scl = 1;
        delay();
        sda = 0;
        delay();
void stop()
        sda = 0;
        delay();
        scl = 1;
        delay();
        sda = 1;
        delay();
void respons()
        uchar i;
        scl = 1;
        delay();
        while((sda == 1) && (i<250))
                i++;
        scl = 0;
        delay();
void write_byte(uchar date)
        uchar i, temp;
        scl = 0;
        delay();
        temp = date;
        for(i=0; i<8; i++)
                temp = temp << 1;
                sda = CY;
                delay();
                scl= 1;
                delay();
                scl =0;
          delay();
        sda = 1;
        delay();
uchar read_byte()
        uchar i, k;
        scl = 0;
        delay();
        sda = 1;
        delay();
        for(i=0; i<8; ++i)
                scl = 1;
                delay();
                k = (k<<1)|sda;
                scl = 0;
                delay();
        return k;
void delay()
/*void delay1(uint z)
        uchar x, y;
        for(x=z; x>0; x--)
          for(y=110; y>0; y--);
void write_add(uchar address, uchar date)
        start();
        write_byte(0xa0);
        respons();
        write_byte(address);
        respons();
        write_byte(date);
        respons();
        stop();
uchar read_add(uchar address)
        uchar date;
        start();
        write_byte(0xa0);
        respons();
        respons();
        start();
        write_byte(0xa1);
        respons();
        date = read_byte();
        stop();
        return date;
void init1()
        TMOD = 0x01;
        TH0 = (65535-50000)/256;
        TL0 = (65535-50000)%256;
        EA = 1;
        ET0 = 1;
        TR0 = 1;
        aa = 0;
        shu = 0;
void timer0() interrupt 1
        aa++;
void we()
        if(aa == 20)
                aa =0;
                shu++;
                if(shu == 100)
                   shu = 0;
                shi = shu/10;
                 ge = shu%10;
                write = 1;
void dage(uchar aa, uchar bb)
          Send_595(0xfe);
                Send_595(t_display[aa]);
                P_HC595_RCLK = 0;
                P_HC595_RCLK = 1;
          Send_595(0xff);
                Send_595(0xfd);
                Send_595(t_display[bb]);
                P_HC595_RCLK = 0;
                P_HC595_RCLK = 1;
void Send_595(uchar dat)
        uint         i;
        for(i=0; i<8; i++)
                if(dat & 0x80)        P_HC595_SER = 1;
                else                        P_HC595_SER = 0;
                P_HC595_SRCLK = 0;
                P_HC595_SRCLK = 1;
                dat = dat << 1;
JW-51開發(fā)板.pdf
99.63 KB, 下載次數(shù): 14
ID:213173 發(fā)表于 2017-11-15 07:40 | 只看該作者
需要有外電源掉電檢測電路,一旦檢測到外電源掉電,立即保存相關數(shù)據(jù),單片機電源要有足夠大的電容容量維持寫EEPROM的這段時間。
ID:249544 發(fā)表于 2017-11-15 09:10 | 只看該作者
掉電了怎么寫進去?保證掉電前有足夠的時間寫完需要保存的內(nèi)容,一般用一個單片機管教采樣輸入電源,單片機供電用大電容或電池。我們這邊用時鐘芯片DS1302的,每分鐘把要保存的數(shù)據(jù)更新寫進1302的ram,上電讀就行了。
ID:244748 發(fā)表于 2017-11-15 12:48 | 只看該作者
51單片機內(nèi)部EEPROM實現(xiàn)掉電保存數(shù)據(jù),不需要外部電路,這個程序該怎么改
ID:976070 發(fā)表于 2021-12-19 16:33 | 只看該作者
同樣的問題,樓主問題解決沒有?
ID:994918 發(fā)表于 2021-12-20 20:40 | 只看該作者
在電源端并一個大電容,電容前串一個正向二極管,用一個外中斷接在二極管前面,當電源掉電時,電容中存的電能讓單片機工作足夠時間,進入中斷寫數(shù)據(jù)進EEPROM
