電陶爐電源板原理圖
燈板原理圖
電陶爐的單片機(jī)源程序如下:
- ;V1.4修改:童鎖鍵檢測(cè)時(shí)候由5S改成3S。
- ; 電陶爐
- ;O(∩_∩)O~O(∩_∩)O~O(∩_∩)O~O(∩_∩)O~O(∩_∩)O~
- IAR EQU 00H
- TMR0 EQU 01H
- PCL EQU 02H
- FLAGS EQU 03H
- C EQU 0
- DC EQU 1
- Z EQU 2
- MP EQU 04H
- P0 EQU 05H
- P1 EQU 06H
- P2 EQU 07H
- ;08H NOT USED
- P0CL EQU 09H
- P0CH EQU 0AH
- P1CL EQU 0BH
- P1CH EQU 0CH
- P2C EQU 0DH
- ;0EH,0FH NOT USED
- SYS_GEN EQU 10H
- INT_EN EQU 11H
- INT_FLAG EQU 12H
- INT_EXT EQU 13H
- ADDATA EQU 14H
- ADCON EQU 15H
- CONV EQU 0
- EOC EQU 3
- TMR1 EQU 16H
- TMR1C EQU 17H
- T2CNT EQU 18H
- T2CON EQU 19H
- T2DATA EQU 1AH
- ;1BH NOT USED
- PWM8DATA EQU 1CH
- PWM8CON EQU 1DH
- PWM10CON EQU 1EH
- PWM10DATA EQU 1FH
- COMPCON EQU 20H
- BUZCON EQU 21H
- TABLE_SPH EQU 22H
- TABLE_SPL EQU 23H
- TABLE_DATAH EQU 24H
- ADDATAL EQU 1BH
- KEY_C1 EQU 2CH
- KEY_C EQU 2DH
- KEY_DATAL EQU 2EH
- KEY_DATAH EQU 2FH
- ;P0口
- ;P1口
- STB EQU P1,0
- AC EQU P1,1
- EN EQU P1,2
- FAN EQU P1,3
- BELL EQU P1,3
- ;P2口
- DIO EQU P2,0
- CLK EQU P2,1
- GPR0 EQU ?
- GPR1 EQU ?
- TCOUNT EQU ?
- RBEEP EQU ?
- RBEEPL EQU ?
- RBEEPH EQU ?
- ACF EQU ?
- ACOLD EQU 0
- AC_EN EQU 1
- ACSET EQU ?
- ACNT EQU ?
- SEC EQU ?
- MIN EQU ?
- HOUR EQU ?
- SECL EQU ?
- SEC5S EQU ?
- AC_SEC EQU ?
- P_SEC EQU ?
- DELAY EQU ?
- COUNT EQU ?
- POWER EQU ?
- TEMP EQU ?
- BCD_REG EQU ?
- FEN1_COUNT EQU ?
- FEN3_COUNT EQU ?
- DISPLAY1 EQU ?
- DISPLAY2 EQU ?
- DISPLAY3 EQU ?
- DISPLAY4 EQU ?
- DISPLAY5 EQU ?
- FANT EQU ?
- FANT1 EQU ?
- B_SEC EQU ?
- DICOUNT EQU ?
- ADCOUNT EQU ?
- ADCOUNT1 EQU ?
- DATAL EQU ?
- DATAH EQU ?
- TMPR_VAC EQU ?
- TMPR_PAN EQU ?
- TMPR_TR EQU ?
- TR_COUNT EQU ?
- TR_COUNT1 EQU ?
- PAN_COUNT EQU ?
- PAN_COUNT1 EQU ?
- PAN_COUNT2 EQU ?
- VOL_COUNT EQU ?
- BCOUNT EQU ?
- SEC2S EQU ?
- ADAT0L EQU ?
- ADAT0H EQU ?
- ADCOUNT3 EQU ?
- TEMP1 EQU ?
- KCOUNT EQU ? ;按鍵掃描
- KDATA EQU ?
- POWER1 EQU ?
- KEYF EQU ?
- KEY_EN EQU 1
- KOLD EQU ?
- KCNTL EQU ?
- KCNTLL EQU ?
- KOLD1 EQU ?
- KOLD2 EQU ?
- KOLD3 EQU ?
- KOLD4 EQU ?
- KOLD5 EQU ?
- FCOUNT0 EQU ?
- FCOUNT EQU ?
- FCOUNT1 EQU ?
- ERRF EQU ?
- WORK EQU ?
- ONOFF EQU 0
- ERR EQU 1
- FAN1 EQU 2
- FON EQU 3
- TIMER EQU 4
- TONG EQU 5
- FLAG EQU ?
- SS EQU 0
- S05 EQU 1 ;0.5S
- TIME EQU 2
- DJ EQU 3
- T_CHANGE EQU 4
- FEN3 EQU 5
- DYE EQU 6 ;電壓錯(cuò)誤
- SS1 EQU 7
- FLAG1 EQU ?
- ;0蜂鳴器
- FIRST EQU 1 ;上電全亮
- GW EQU 2 ;高溫?zé)?br />
- KS EQU 3 ;到達(dá)降功率開(kāi)始計(jì)時(shí)
- HZ60 EQU 4 ;為1表示60HZ
- SD EQU 5 ;上電測(cè)試頻率
- GL EQU 7 ;開(kāi)可控硅處理
- ;EGWCOUNT1 EQU ?
- ;EGWCOUNT2 EQU ?
- EDYCOUNT1 EQU ?
- ENFLAG EQU ?
- ENFLAG1 EQU ?
- ENFLAG2 EQU ?
- PCOUNT EQU ?
- BBCOUNT EQU ?
- WEN_D EQU ?
- POWER_TEMP EQU ?
- COUNT10MS EQU ?
- POWER_J EQU ?
- GAOT EQU 2BH
- ORG 00H
- JP START
- ORG 01H
- NOP
- INTE_IN:
- LD GPR0,A ;中斷現(xiàn)場(chǎng)保護(hù)
- LD A,FLAGS
- LD GPR1,A
- SZB INT_FLAG,2 ;定時(shí)2中斷,125US進(jìn)一次
- JP INT_TMR2
- CLR INT_FLAG
- INT_TMR2: ;定時(shí)2中斷,125US進(jìn)一次
- CLRB INT_FLAG,2 ;清中斷標(biāo)志位
- CLRWDT
- INCR TCOUNT ;主程序時(shí)間計(jì)數(shù)
- ;(~ o ~)Y(~ o ~)Y(~ o ~)Y(~ o ~)Y
- ZZ_10MS:
- INCR COUNT10MS
- LDIA .80
- SUBA COUNT10MS
- SNZB FLAGS,C
- JP FAC_TESE
- CLR COUNT10MS
- INCR SECL
- INCR AC_SEC
- INCR B_SEC
- FAC_TESE:
- SNZB ACF,ACOLD
- JP FAC_LOW_TO_HIGH
- FAC_HIGH_TO_LOW:
- SZB AC
- JP AC_BACK
- SZB AC
- JP AC_BACK
- SZB AC
- JP AC_BACK
- CLRB ACF,ACOLD
- JP AC_COM
- FAC_LOW_TO_HIGH:
- SNZB AC
- JP AC_BACK
- SNZB AC
- JP AC_BACK
- SNZB AC
- JP AC_BACK
- SETB ACF,ACOLD
- JP AC_COM
- AC_COM:
- SETB ACF,AC_EN
- CLR ACNT
- INCR PCOUNT
- LDIA .20
- SUBA PCOUNT
- SNZB FLAGS,C
- JP AC_BACK
- CLR PCOUNT
- AC_BACK:
- BPBP:
- SNZB FLAG1,0
- JP BPBP_BACK
- SNZB RBEEP,0
- JP BPBP_OFF
- LDIA 08H
- XORR P1
- SZDECR RBEEPL
- JP BPBP_BACK
- SZDECR RBEEPH
- JP BPBP_BACK
- LDIA 02H
- LD RBEEPH,A
- CLRB RBEEP,0
- BPBP_OFF:
- SNZB WORK,FAN1
- CLRB BELL
- BPBP_BACK:
- LDIA 01H
- XORR FLAG1
- SET_WORK:
- SZB WORK,ERR
- JP WORK_OFF
- SNZB WORK,ONOFF
- JP WORK_OFF
- SZB FLAG,DJ
- JP WORK_OFF
- LDIA B'01111110'
- ANDA ERRF
- SNZB FLAGS,Z
- JP WORK_OFF
- SNZB ACF,AC_EN
- JP WORK_OFF1
- ;CALL SET_POWER
- SNZB FLAG1,GL ;控制當(dāng)前過(guò)零是否開(kāi)可控硅
- JP SET_WORK_KK_COM1
- SET_WORK_KK_COM:
- CLRB EN
- SET_WORK_KK_COM1:
- INCR DELAY
- LDIA D'20'
- SUBA DELAY
- SNZB FLAGS,C
- JP WORK_BACK
- SET_WORK_COM:
- CLR ACNT
- CLRB ACF,AC_EN
- CLR DELAY
- WORK_OFF:
- CLRB FLAG1,GL
- WORK_OFF1:
- SETB EN
- WORK_BACK:
- SZB RBEEP,0
- JP INT_BACK
- SZB WORK,ONOFF
- JP ON_FAN
- SZB WORK,FAN1
- JP ON_FAN
- CLRB FAN
- JP INT_BACK
- ON_FAN:
- SETB FAN
- INT_BACK:
- REC_BACK:
- LD A,GPR0 ;中斷返回
- CLRB FLAGS,0 ;只用到C位跟Z位
- SZB GPR1,0
- SETB FLAGS,0
- CLRB FLAGS,2
- SZB GPR1,2
- SETB FLAGS,2
- RETI
- ;~~~~(>_<)~~~~ ~~~~(>_<)~~~~ ~~~~(>_<)~~~
- START:
- NOP
- CLRWDT
- LDIA 00H
- OPTION ;上電清WDT(必要)
- ;-------------初始化I/O------------------
- LDIA B'00000100'
- LD P1,A
- CLR P0
- CLR P2
- LDIA B'11111111'
- LD P0CH,A
- LDIA B'00111111'
- LD P0CL,A
- LDIA B'10010010'
- LD P1CH,A
- LDIA B'10100010'
- LD P1CL,A
- LDIA B'00010010'
- LD P2C,A
- LDIA B'00000100'
- LD P1,A
- CLR P0
- CLR P2
- SD_DELAY:
- CLRWDT
- NOP
- SZDECR RBEEPL ;上電延時(shí)
- JP SD_DELAY
- SZDECR RBEEPH
- JP SD_DELAY
- ;--------------清寄存器------------------
- CLR_RAM: ;清掉所有RAM
- LDIA 0FH
- LD MP,A
- CLR_LOOP:
- INCR MP
- CLR IAR
- LDIA 07FH
- SUBA MP
- SNZB FLAGS,0
- JP CLR_LOOP
- ;-------------初始化RAM------------------
- INIT_RAM:
- LDIA 03H
- LD SYS_GEN,A ;中斷,AD總使能
- LDIA 02H
- LD KEY_C1,A
- LDIA 2BH
- LD KEY_C,A
- NOP
- SETB KEY_C,7
- LDIA D'250' ;8下125US
- LD T2DATA,A ;TMR2設(shè)置成250US
- LDIA 30H
- LD T2CON,A
- SETB T2CON,0
- LDIA 04H
- LD INT_EN,A ;定時(shí)2中斷使能
- SETB RBEEP,0
- LDIA 02H
- LD RBEEPH,A
- LDIA D'250'
- LD RBEEPL,A
- SETB FLAG1,FIRST ;上電全亮
- SETB FLAG1,SD
- LDIA .60;D'100' ;長(zhǎng)按鍵后每次時(shí)間
- LD KCNTL,A
- LDIA D'10'
- LD KCNTLL,A
- LDIA B'00010110'
- LD ADCON,A
- SETB ADCON,CONV
- NOP
- NOP
- NOP
- NOP
- NOP
- CLRB ADCON,CONV
- ;\(^o^)/\(^o^)/\(^o^)/\(^o^)/\(^o^)/\(^o^)
- MAIN:
- LDIA D'20' ;125US*20=2.5MS一個(gè)分支
- SUBA TCOUNT
- SNZB FLAGS,C
- JP MAIN
- CLR TCOUNT
- CLRWDT
- LDIA 03H
- LD SYS_GEN,A ;中斷、AD總使能
- LDIA D'250' ;3.6M下250US
- LD T2DATA,A
- SETB INT_EN,2 ;定時(shí)2中斷使能
- LDIA B'00000100' ;除了TMR2跟EXT1中斷,其它中斷都關(guān)閉
- ANDR INT_EN
- LDIA 31H
- SUBA T2CON ;T2CON為31時(shí)不寫(xiě)
- SZB FLAGS,Z
- JP MAIN_SUB
- LDIA 30H ;寫(xiě)操作會(huì)影響計(jì)時(shí),在T2CON沒(méi)有亂的時(shí)候不寫(xiě)
- LD T2CON,A
- SETB T2CON,0
- MAIN_SUB: ;子程序
- CALL SET_IO
- CALL KSCAN
- CALL MAINK
- CALL SET_DISP
- CALL KSCAN
- CALL WR_CTRL_CMD ;設(shè)置寫(xiě)數(shù)據(jù)控制命令
- CALL DISP_ADR ;送顯示地址
- CALL MODE_SET ;設(shè)置COM與SEG位的個(gè)數(shù)
- CALL DISP_ON ;開(kāi)顯示/設(shè)置顯示亮度
- CALL KSCAN
- CALL SET_TIME
- CALL KSCAN
- CALL SET_TIME_AC
- CALL KSCAN
- CALL AD_TEST
- CALL SET_POWER
- CALL SET_FAN_DENG
- ;CALL ERR_GW_TIME
- CALL ERR_DY_TIME
- CALL ERR_CHECK
- ; CALL ERR_WX_TIME
- JP MAIN
- ERR_CHECK:
- SNZB WORK,ONOFF
- JP ERR_CHECK_BACK0
- SNZB WORK,ERR
- LDIA .100
- SUBA B_SEC
- SNZB FLAGS,C
- JP ERR_CHECK_BACK
- CLR B_SEC
- LDIA .4
- SUBA BBCOUNT
- SZB FLAGS,C
- JP ERR_CHECK_BACK
- INCR BBCOUNT
- SETB RBEEP,0
- LDIA 04H
- LD RBEEPH,A
- ERR_CHECK_BACK0:
- CLR B_SEC
- ERR_CHECK_BACK:
- RET
- SET_IO:
- LDIA B'11111111'
- LD P0CH,A
- LDIA B'00111111'
- LD P0CL,A
- ; LDIA B'10010010'
- ; LD P1CH,A
- LDIA B'10100010'
- LD P1CL,A
- LDIA B'00010010'
- LD P2C,A
- RET
- ;KSCAN:
- ; CLR KCOUNT
- ;KSCAN_1:
- ; INCR KCOUNT
- ; SNZB P0,3
- ; JP KHAVE
- ; INCR KCOUNT
- ; SNZB P0,4
- ; JP KHAVE
- ; INCR KCOUNT
- ; SNZB P0,5
- ; JP KHAVE
- ; INCR KCOUNT
- ; SNZB P0,6
- ; JP KHAVE
- ; INCR KCOUNT
- ; SNZB P0,7
- ; JP KHAVE
- ;KNO:
- ; LDIA 07EH
- ; ANDR KEYF
- ; CLR KOLD
- ; CLR KEYC
- ; JP KSCAN_BACK
- ;*************按鍵消抖***********
- ;KHAVE:
- ; LD A,KOLD
- ; SUBA KCOUNT
- ; SNZB FLAGS,Z
- ; JP KFLASH
- ; SZB KEYF,7
- ; JP KREPEAT
- ; INCR KEYC
- ; LDIA 010H
- ; SUBA KEYC
- ; SNZB FLAGS,C
- ; JP KSCAN_BACK
- ;KHAVE_1:
- ; SETB KEYF,0
- ;KHAVE_2:
- ; SETB KEYF,7
- ; JP KSCAN_BACK
- ;KFLASH:
- ; LD A,KCOUNT
- ; LD KOLD,A
- ; CLR KEYC
- ; JP KSCAN_BACK
- ;KREPEAT:
- ; CLR KEYC
- ;KSCAN_BACK:
- ; RET 00H
- KSCAN:
- SZB RBEEP,0 ;有蜂鳴器不掃按鍵
- JP KSCAN_BACK
- SNZB KEY_C1,7 ;判斷AD完成標(biāo)志
- JP KSCAN_BACK
- LD A,KEY_DATAL
- ADDR ADAT0L
- SZB FLAGS,C
- INCR ADAT0H
- INCR ADCOUNT3
- LDIA .8 ;8次計(jì)數(shù)
- SUBA ADCOUNT3
- SNZB FLAGS,C
- JP KEY_RESTA
- CLR ADCOUNT3
- KEY_DAT:
- RRCR ADAT0H
- RRCR ADAT0L ;除以8
- RRCR ADAT0H
- RRCR ADAT0L
- RRCR ADAT0H
- RRCA ADAT0L
- LD TEMP,A
- CLR ADAT0H
- CLR ADAT0L
- LD A,KCOUNT ;用間接尋址獲得該按鍵舊值
- CALL TABLE_MP
- LD MP,A
- LD A,TEMP ;比原來(lái)的大,沒(méi)有按鍵,刷新舊值
- SUBA IAR
- SNZB FLAGS,C
- JP K_MOVE
- LD TEMP1,A
- CALL KEY_EN_TAB ;不同的按鍵下降的值不同
- SUBA TEMP1
- SNZB FLAGS,C
- JP K_AVG
- K_HAVE:
- LD A,KCOUNT
- SUBA KOLD ;判斷是否跟上次一樣的按鍵,
- SNZB FLAGS,Z
- JP KFLASH
- SETB KEYF,KEY_EN
- ;INCR KEYC
- ;LDIA 01H
- ;SUBA KEYC
- ;SNZB FLAGS,C ;消抖
- ;JP NEXT_KEY
- ;CLR KEYC
- KHAVE1:
- SZB KEYF,7 ;重鍵標(biāo)志位
- JP KREPEAT
- SETB KEYF,7
- SETB KEYF,0 ;按鍵標(biāo)志位
- LD A,KCOUNT
- LD KDATA,A
- JP NEXT_KEY
- KFLASH:
- SZB KEYF,KEY_EN
- JP K_CLEAR
- SZB KEYF,7
- JP K_CLEAR ;有按鍵再檢測(cè)到其他鍵,取消按鍵
- SETB KEYF,KEY_EN
- LD A,KCOUNT ;保存鍵值
- LD KOLD,A
- ;CLR KEYC
- JP NEXT_KEY
- KREPEAT:
- LDIA 05H
- SUBA KCOUNT
- SZB FLAGS,Z
- JP K_REP_LONG1
- LDIA 01H
- SUBA KCOUNT
- SZB FLAGS,Z
- JP K_REP_LONG1
- ;ADD和DEC這2個(gè)有長(zhǎng)按鍵
- LDIA 03H
- SUBA KCOUNT
- SNZB FLAGS,Z
- JP NEXT_KEY
- K_REP_LONG:
- SNZB WORK,ONOFF ;判斷長(zhǎng)按鍵條件
- JP NEXT_KEY
- ; SNZB FLAG,T_CHANGE
- ; JP NEXT_KEY
- K_LONG:
- SZDECR KCNTL
- JP NEXT_KEY
- LD KCNTL,A
- SETB KEYF,0
- SETB KEYF,6 ;長(zhǎng)按鍵標(biāo)志位
- JP NEXT_KEY
- K_REP_LONG1:
- SNZB WORK,ONOFF
- JP NEXT_KEY
- SNZB FLAG,T_CHANGE
- JP NEXT_KEY
- SZDECR KCNTLL
- JP NEXT_KEY
- LDIA D'10'
- LD KCNTLL,A
- SETB KEYF,0
- JP NEXT_KEY
- K_CLEAR:
- CLR KOLD1
- CLR KOLD2
- CLR KOLD3
- CLR KOLD4
- CLR KOLD5
- CLRB KEYF,3
- CLRB KEYF,6
- CLRB KEYF,0
- NEXT_KEY:
- INCR KCOUNT ;按鍵計(jì)數(shù)加一,檢測(cè)下一個(gè)按鍵
- LDIA 06H
- SUBA KCOUNT
- SNZB FLAGS,C
- JP KEY_RESTA ;掃完一輪按鍵后,清狀態(tài)
- LDIA 01H
- LD KCOUNT,A
- SNZB KEYF,KEY_EN
- JP KEY_NO
- CLRB KEYF,KEY_EN
- JP KEY_RESTA
- KEY_NO:
- CLR KEYF ;沒(méi)有按鍵,清RAM
- ;CLR KEYC
- LDIA .60;D'100'
- LD KCNTL,A
- LDIA D'10'
- LD KCNTLL,A
- SETB KOLD,7
- KEY_RESTA:
- CLR KEY_C1
- CLR KEY_C
- LDIA B'10010010' ;放電
- LD P1CH,A
- CLRB P1,5
- NOP
- NOP
- NOP
- NOP
- NOP
- NOP
- NOP
- NOP
- NOP
- NOP
- LDIA B'10001010'
- LD P1CH,A
- LDIA 02H
- LD KEY_C1,A
- CALL KSCAN_TAB
- LD KEY_C,A
- NOP
- SETB KEY_C,7
- JP KSCAN_BACK
- K_AVG: ;3/4舊+1/4新給前一次
- CLR TEMP1
- LD A,IAR
- ADDR TEMP
- SZB FLAGS,C
- INCR TEMP1
- LD A,IAR
- ADDR TEMP
- SZB FLAGS,C
- INCR TEMP1
- LD A,IAR
- ADDR TEMP
- SZB FLAGS,C
- INCR TEMP1
- RRCR TEMP1
- RRCR TEMP
- RRCR TEMP1
- RRCA TEMP
- LD IAR,A
- JP NEXT_KEY
- K_MOVE:
- LD A,TEMP
- LD IAR,A
- JP NEXT_KEY
- KSCAN_BACK:
- RET
- MAINK:
- SNZB KEYF,0
- JP MAINK_BACK
- CLRB KEYF,0
- SETB RBEEP,0
- LDIA 02H
- LD RBEEPH,A
- LDIA D'156'
- LD RBEEPL,A
- MAINK_LOOP:
- LDIA 07H
- ANDA KDATA ;判斷哪個(gè)按鍵
- ADDR PCL
- JP MAINK_NO_BUZ
- JP MAINK_DEC
- JP MAINK_TIMER
- JP MAINK_TONG
- JP MAINK_ONOFF
- JP MAINK_ADD
- JP MAINK_NO_BUZ
- JP MAINK_NO_BUZ
- MAINK_NO_BUZ:
- CLRB RBEEP,0
- JP MAINK_BACK
- MAINK_TONG:
- SNZB KEYF,6
- JP MAINK_NO_BUZ
- CLRB KEYF,6
- SNZB WORK,TONG
- JP TONG_ON
- TONG_OFF:
- CLRB WORK,TONG
- JP MAINK_BACK
- TONG_ON:
- SETB WORK,TONG
- JP MAINK_BACK
- MAINK_ONOFF:
- CLRB KEYF,6
- ;SZB WORK,TONG
- ;JP MAINK_NO_BUZ
- SZB WORK,ONOFF
- JP MAINK_OFF
- MAINK_ON:
- CLR WORK
- CLR FLAG
- SETB WORK,ONOFF ;以下為開(kāi)機(jī)默認(rèn)
- SETB FLAG,DJ ;待命狀態(tài)
- SETB WORK,FAN1
- ; SETB FLAG1,GW
- CLR POWER
- CLR GAOT
- CLRB FLAG1,KS
- LDIA .2
- LD HOUR,A
- CLR MIN
- CLR P_SEC
- JP MAINK_BACK
- MAINK_OFF:
- SZB FLAG,DJ
- JP MAINK_OFF1
- CALL SYS_OFF
- JP MAINK_BACK
- MAINK_OFF1:
- CALL SYS_OFF1
- JP MAINK_BACK
- MAINK_TIMER:
- CLRB KEYF,6
- SNZB WORK,ONOFF
- JP MAINK_NO_BUZ
- LDIA B'01011110'
- ANDA ERRF
- SNZB FLAGS,Z
- JP MAINK_NO_BUZ
- SZB WORK,TONG
- JP MAINK_NO_BUZ
- SZB FLAG,DJ
- JP MAINK_NO_BUZ
- SZB FLAG,T_CHANGE
- JP MAINK_TIMER_OFF
- MAINK_TIMER_ON:
- SETB WORK,TIMER
- SETB FLAG,TIME
- SETB FLAG,T_CHANGE
- LDIA .30
- LD MIN,A
- CLR HOUR
- LDIA .60
- LD SEC,A
- CLRB FLAG,SS
- CLR SECL
- LDIA .10
- LD SEC5S,A
- JP MAINK_BACK
- MAINK_TIMER_OFF:
- CLRB WORK,TIMER
- CLRB FLAG,TIME
- CLRB FLAG,T_CHANGE
- CLR MIN
- LDIA .2
- LD HOUR,A
- LDIA .60
- LD SEC,A
- JP MAINK_BACK
- NOP
- MAINK_ADD:
- SZB KEYF,6
- CLRB RBEEP,0
- CLRB KEYF,6
- SNZB WORK,ONOFF
- JP MAINK_NO_BUZ
- LDIA B'01011110'
- ANDA ERRF
- SNZB FLAGS,Z
- JP MAINK_NO_BUZ
- SZB WORK,TONG
- JP MAINK_NO_BUZ
- SNZB WORK,TIMER
- JP MAINK_ADD_POWER
- SZB FLAG,T_CHANGE ;1表示時(shí)間加減模式
- JP MAINK_ADD_TIME
- MAINK_ADD_POWER:
- SZB WORK,TIMER
- JP MAINK_ADD_POWER1
- LDIA D'2'
- LD HOUR,A
- CLR MIN
- LDIA D'60'
- LD SEC,A
- MAINK_ADD_POWER1:
- CALL SJ_SHUAXIN
- CLRB FLAG,TIME ;顯示功率
- SZB FLAG,DJ
- JP MR_MAX
- CLRB FLAG,DJ
- INCR POWER
- LDIA D'11' ;只有10檔
- SUBA POWER
- SNZB FLAGS,C
- JP MAINK_BACK
- LDIA D'10'
- LD POWER,A
- JP MAINK_NO_BUZ
- MAINK_ADD_TIME:
- CALL SJ_SHUAXIN ;定時(shí)
- SETB FLAG,TIME
- LDIA .10
- ADDR MIN
- LDIA D'60'
- SUBA MIN
- SNZB FLAGS,C
- JP MAINK_BACK
- LDIA D'60'
- SUBR MIN
- INCR HOUR
- LDIA .3
- SUBA HOUR
- SNZB FLAGS,C
- JP MAINK_BACK
- CLR HOUR
- CLR MIN
- JP MAINK_BACK
- MAINK_DEC:
- SZB KEYF,6
- CLRB RBEEP,0
- CLRB KEYF,6
- SNZB WORK,ONOFF
- JP MAINK_NO_BUZ
- LDIA B'01011110'
- ANDA ERRF
- SNZB FLAGS,Z
- JP MAINK_NO_BUZ
- SZB WORK,TONG
- JP MAINK_NO_BUZ
- SNZB WORK,TIMER
- JP MAINK_DEC_POWER
- JP MAINK_DEC_TIME
- MAINK_DEC_POWER:
- SZB WORK,TIMER
- JP MAINK_DEC_POWER1
- LDIA D'2'
- LD HOUR,A
- CLR MIN
- LDIA D'60'
- LD SEC,A
- MAINK_DEC_POWER1:
- CALL SJ_SHUAXIN
- CLRB FLAG,TIME
- SZB FLAG,DJ
- JP MR_MIN
- CLRB FLAG,DJ
- LDIA 02H ;最低為1檔
- SUBA POWER
- SNZB FLAGS,C
- JP MAINK_NO_BUZ
- DECR POWER
- JP MAINK_BACK
- MAINK_DEC_TIME:
- CALL SJ_SHUAXIN
- SETB FLAG,TIME
- DECR MIN
- LDIA .60
- SUBA MIN
- SNZB FLAGS,C
- JP MAINK_BACK
- LDIA .59
- LD MIN,A
- DECR HOUR
- LDIA .3
- SUBA HOUR
- SNZB FLAGS,C
- JP MAINK_BACK
- LDIA .2
- LD HOUR,A
- JP MAINK_BACK
- MR_MIN:
- LDIA 01H
- LD POWER,A
- CLRB FLAG,DJ
- JP MAINK_BACK
- MR_MAX:
- LDIA 0AH
- LD POWER,A
- CLRB FLAG,DJ
- JP MAINK_BACK
- MAINK_BACK:
- RET
- SET_DISP:
- CLR DISPLAY1
- CLR DISPLAY2
- CLR DISPLAY3
- CLR DISPLAY4
- CLR DISPLAY5
- SET_DISP_ON:
- SNZB FLAG1,GW
- JP DISP_JIXU
- SNZB FLAG,SS1
- SETB DISPLAY5,4 ;高溫?zé)?br />
- DISP_JIXU:
- SZB FLAG1,FIRST ;初始為1,上電顯示
- JP SET_DISP_START
- SNZB WORK,ONOFF
- JP SET_DISP_OFF
- SETB DISPLAY5,2 ;電源燈
- SZB WORK,TIMER
- SETB DISPLAY5,3
- SZB WORK,TONG
- SETB DISPLAY5,5
- SZB ERRF,1
- JP DISP_ERR_1
- SZB ERRF,2
- JP DISP_ERR_2
- SZB ERRF,3
- JP DISP_ERR_3
- SZB ERRF,4
- JP DISP_ERR_4
- ; SZB ERRF,5
- ; JP DISP_ERR_5
- SZB ERRF,6
- JP DISP_ERR_6
- SZB FLAG,DJ ;待機(jī)顯示
- JP SET_DISP_DAIJI
- SNZB WORK,TIMER
- JP SET_DISP_POWER
- SZB FLAG,T_CHANGE
- JP SET_DISP_TIME
- SNZB FLAG,TIME
- JP SET_DISP_POWER
- JP SET_DISP_TIME
- ;-----------設(shè)置時(shí)間顯示---------------
- SET_DISP_TIME:
- LD A,MIN
- CALL BCD_CH
- LD A,BCD_REG
- CALL TABLE_SEG
- LD DISPLAY4,A
- LD A,TEMP
- CALL TABLE_SEG
- LD DISPLAY3,A
- LD A,HOUR
- CALL TABLE_SEG
- LD DISPLAY2,A
- LDIA 0D7H ; 0
- LD DISPLAY1,A
- DISPLAY1_1_1:
- SETB DISPLAY2,3
- SETB DISPLAY3,3
- SNZB FLAG,SS
- JP SET_DISP_BACK
- CLRB DISPLAY2,3
- CLRB DISPLAY3,3
- JP SET_DISP_BACK
- CLR DISPLAY1
- CLR DISPLAY2
- CLR DISPLAY3
- CLR DISPLAY4
- JP SET_DISP_BACK
- ;-----------設(shè)置功率顯示---------------
- SET_DISP_POWER:
- LDIA 0D7H ;0
- LD DISPLAY4,A
- LD DISPLAY3,A
- LD A,POWER
- CALL TABLE_DISP_POWER
- CALL BCD_CH
- LD A,BCD_REG
- CALL TABLE_SEG
- LD DISPLAY2,A
- LD A,TEMP
- SZB FLAGS,Z
- JP DISPLAY1_2_1
- CALL TABLE_SEG
- LD DISPLAY1,A
- JP SET_DISP_BACK
- DISPLAY1_2_1:
- CLR DISPLAY1
- JP SET_DISP_BACK
- SET_DISP_START:
- LDIA 0FFH
- LD DISPLAY1,A
- LD DISPLAY2,A
- LD DISPLAY3,A
- LD DISPLAY4,A
- LD DISPLAY5,A
- JP SET_DISP_BACK
- SET_DISP_OFF:
- SNZB FLAG,SS
- JP SET_DISP_BACK
- SET_DISP_DAIJI:
- SETB DISPLAY5,2
- LDIA 020H
- LD DISPLAY1,A
- LD DISPLAY2,A
- LD DISPLAY3,A
- LD DISPLAY4,A
- JP SET_DISP_BACK
- DISP_ERR_1:
- LDIA 067H
- LD DISPLAY2,A
- LDIA 090H
- LD DISPLAY3,A
- JP SET_DISP_BACK
- DISP_ERR_2:
- LDIA 067H
- LD DISPLAY2,A
- LDIA 0A7H
- LD DISPLAY3,A
- JP SET_DISP_BACK
- DISP_ERR_3:
- LDIA 067H
- LD DISPLAY2,A
- LDIA 0B5H
- LD DISPLAY3,A
- JP SET_DISP_BACK
- DISP_ERR_4:
- LDIA 067H
- LD DISPLAY2,A
- LDIA 0F0H
- LD DISPLAY3,A
- JP SET_DISP_BACK
- DISP_ERR_5:
- LDIA 067H
- LD DISPLAY2,A
- LDIA 075H
- LD DISPLAY3,A
- JP SET_DISP_BACK
- DISP_ERR_6:
- LDIA 067H
- LD DISPLAY2,A
- LDIA 077H
- LD DISPLAY3,A
- JP SET_DISP_BACK
- SET_DISP_BACK:
- RET
- WR_CTRL_CMD:
- SETB STB
- LDIA B'01000100' ;送讀/寫(xiě)控制命令
- CALL WR_1628
- SETB STB
- RET
- DISP_ADR:
- SETB STB ;一個(gè)總周期送一個(gè)顯示地址
- DISP_1_DATA:
- LDIA 0C8H
- CALL WR_1628
- LD A,DISPLAY1
- CALL WR_1628
- DISP_2_DATA:
- SETB STB
- LDIA 0CAH
- CALL WR_1628
- LD A,DISPLAY2
- CALL WR_1628
- DISP_3_DATA:
- SETB STB
- LDIA 0CCH
- CALL WR_1628
- LD A,DISPLAY3
- CALL WR_1628
- DISP_4_DATA:
- SETB STB
- LDIA 0C6H
- CALL WR_1628
- LD A,DISPLAY4
- CALL WR_1628
- DISP_5_DATA:
- SETB STB
- LDIA 0C4H
- CALL WR_1628
- LD A,DISPLAY5
- CALL WR_1628
- RET
- MODE_SET:
- SETB STB
- LDIA B'00000011' ;設(shè)置顯示模式(7 COM +10 SEGS)
- CALL WR_1628
- SETB STB
- RET
- NOP
- DISP_ON:
- SETB STB
- LDIA B'10001001' ;開(kāi)顯示/灰度為4/16
- CALL WR_1628
- SETB STB
- RET
- SET_TIME:
- LDIA D'50'
- SUBA SECL
- SNZB FLAGS,C
- JP SET_TIME_BACK
- CLR SECL
- SETB FLAG,S05
- LDIA 01H
- XORR FLAG
- INCR SEC2S
- LDIA D'2'
- SUBA SEC2S
- SNZB FLAGS,C
- JP SET_TIME_5S
- CLR SEC2S
- CLRB FLAG1,FIRST
- SET_TIME_5S:
- SZDECR SEC5S
- JP SET_TIME_DJ ;待機(jī)一分鐘后轉(zhuǎn)關(guān)機(jī)
- LDIA D'10'
- LD SEC5S,A
- LDIA 04H ;FLAG,TIME
- XORR FLAG ;時(shí)間功率之間切換
- JP SET_TIME_DJ
- SETB FLAG,TIME
- LD A,MIN
- SNZB FLAGS,Z
- JP SET_TIME_DJ
- LD A,HOUR
- SNZB FLAGS,Z
- JP SET_TIME_DJ
- LDIA D'2'
- LD HOUR,A
- CLR MIN
- CLRB FLAG,TIME
- CLRB WORK,TIMER
- SET_TIME_DJ:
- SNZB WORK,ONOFF
- JP SET_TIME_BACK1
- SNZB FLAG,DJ
- JP SET_TIME_BACK1
- LDIA B'01011110'
- ANDA ERRF
- SNZB FLAGS,Z
- JP SET_TIME_BACK1
- INCR FEN1_COUNT
- LDIA D'120'
- SUBA FEN1_COUNT
- SNZB FLAGS,C
- JP SET_TIME_BACK
- CLR FEN1_COUNT
- CALL SYS_OFF1
- SET_TIME_BACK1:
- CLR FEN1_COUNT
- SET_TIME_BACK:
- RET
- SET_TIME_AC:
- LDIA D'100'
- SUBA AC_SEC ;制造1S
- SNZB FLAGS,C
- JP SET_TIME_AC_BACK
- CLR AC_SEC
- LDIA 80H
- XORR FLAG
- SNZB WORK,ONOFF
- SZB WORK,ERR
- SZB FLAG,DJ
- LDIA .3 ;小于3擋不檢測(cè)短路
- SUBA POWER
- SNZB FLAGS,C
- JP SET_TIME_AC_GO_0
- INCR FEN3_COUNT
- LDIA D'180'
- SUBA FEN3_COUNT
- SNZB FLAGS,C
- JP SET_TIME_AC_GO
- SETB FLAG,FEN3
- SET_TIME_AC_GO_0:
- CLR FEN3_COUNT
- SET_TIME_AC_GO:
- SZB FLAG,T_CHANGE
- LD A,HOUR
- SNZB FLAGS,Z
- JP TIME_AC_1
- LD A,MIN
- SNZB FLAGS,Z
- JP TIME_AC_1
- JP TIME_AC_OFF
- TIME_AC_1:
- SZDECR SEC
- LDIA D'60'
- LD SEC,A
- DECR MIN
- LDIA D'60'
- SUBA MIN
- SNZB FLAGS,C
- LDIA D'59'
- LD MIN,A
- DECR HOUR
- TIME_AC_OFF:
- SETB RBEEP,0
- LDIA 04H
- LD RBEEPH,A
- LDIA D'156'
- LD RBEEPL,A
- CALL SYS_OFF
- SET_TIME_AC_BACK:
- RET
- AD_TEST:
- LDIA 03H
- LD SYS_GEN,A
- LDIA B'11111111'
- LD P0CH,A
- LDIA B'00111111'
- LD P0CL,A
- SZB RBEEP,0
- JP AD_BACK
- AD_START:
- LD A,ADCOUNT
- ADDR PCL
- JP CHECK_VAD
- JP CHECK_TR
- JP CHECK_PAN
- CHECK_VAD:
- LDIA B'00000110'
- JP AD_START1
- CHECK_TR:
- LDIA B'00100110'
- JP AD_START1
- CHECK_PAN:
- LDIA B'00010110'
- JP AD_START1
- AD_START1:
- LD ADCON,A
- NOP
- SETB ADCON,CONV
- NOP
- NOP
- NOP
- NOP
- NOP
- NOP
- NOP
- NOP
- NOP
- NOP
- NOP
- CLRB ADCON,CONV
- NOP
- WAIT1:
- SNZB ADCON,EOC
- JP WAIT1
- LD A,ADDATA
- ADDR DATAL
- SZB FLAGS,C
- INCR DATAH
- INCR ADCOUNT1
- LDIA D'32'
- SUBA ADCOUNT1
- SNZB FLAGS,C
- JP AD_BACK
- CLR ADCOUNT1
- RRCR DATAH
- RRCR DATAL
- RRCR DATAH
- RRCR DATAL
- RRCR DATAH
- RRCR DATAL
- RRCR DATAH
- RRCR DATAL
- RRCR DATAH
- RRCR DATAL
- LDIA 03H
- ANDA ADCOUNT
- ADDR PCL
- JP AD_VAD
- JP AD_TR
- JP AD_PAN
- ;*****************電壓檢測(cè)*******************
- AD_VAD:
- LD A,DATAL
- LD TMPR_VAC,A
- SNZB WORK,ONOFF
- JP AD_COM
- SZB WORK,ERR
- JP AD_COM
- LDIA D'190'
- SUBA TMPR_VAC
- SZB FLAGS,C
- JP ERR_GAOYA
- LDIA D'97'
- SUBA TMPR_VAC
- SNZB FLAGS,C
- JP ERR_DIYA
- ;SZB FLAG,DYE
- ;JP VOL_NO_ERR
- SZB ERRF,1
- JP CLR_GAOYA
- SZB ERRF,2
- JP CLR_DIYA
- VOL_NO_ERR:
- CLR VOL_COUNT
- JP VAD_CHED
- ERR_GAOYA:
- SZB ERRF,1
- JP VOL_NO_ERR
- INCR VOL_COUNT
- LDIA D'5'
- SUBA VOL_COUNT
- SNZB FLAGS,C
- JP VAD_CHED
- CLR VOL_COUNT
- SETB ERRF,1
- SETB RBEEP,0
- LDIA 04H
- LD RBEEPH,A
- JP VAD_CHED
- ERR_DIYA:
- SZB ERRF,2
- JP VOL_NO_ERR
- INCR VOL_COUNT
- LDIA D'5'
- SUBA VOL_COUNT
- SNZB FLAGS,C
- JP VAD_CHED
- CLR VOL_COUNT
- SETB ERRF,2
- SETB RBEEP,0
- LDIA 04H
- LD RBEEPH,A
- JP VAD_CHED
- CLR_GAOYA:
- LDIA D'179'
- SUBA TMPR_VAC
- SZB FLAGS,C
- JP VAD_CHED
- INCR VOL_COUNT
- LDIA D'5'
- SUBA VOL_COUNT
- SNZB FLAGS,C
- JP VAD_CHED
- CLR VOL_COUNT
- CLRB ERRF,1
- LDIA D'60'
- LD ACSET,A
- JP VAD_CHED
- CLR_DIYA:
- LDIA D'98'
- SUBA TMPR_VAC
- SNZB FLAGS,C
- JP VAD_CHED
- INCR VOL_COUNT
- LDIA D'5'
- SUBA VOL_COUNT
- SNZB FLAGS,C
- JP VAD_CHED
- CLR VOL_COUNT
- CLRB ERRF,2
- JP VAD_CHED
- VAD_CHED:
- JP AD_COM
- ;*****************鍋底檢測(cè)*******************
- AD_PAN:
- LD A,DATAL ;溫度AD
- LD TMPR_PAN,A
- ; SNZB WORK,ONOFF
- ; JP AD_COM
- SNZB WORK,ONOFF
- JP AD_CHECK_RJ ;判斷是熱機(jī)還是冷機(jī)
- SZB FLAG,DJ
- JP AD_CHECK_RJ
- SZB WORK,ERR
- JP AD_COM
- LDIA D'185' ;開(kāi)路
- SUBA TMPR_PAN
- SZB FLAGS,C
- JP PAN_ERR_KAI
- LDIA D'4'
- SUBA TMPR_PAN
- SNZB FLAGS,C
- JP PAN_ERR_DUAN
- CLR PAN_COUNT
- LDIA D'161'
- SUBA TMPR_PAN
- SZB FLAGS,C
- JP PAN_ERR_GAO_G ;關(guān)斷
- ; LDIA D'105' ;650 DU
- ; SUBA TMPR_PAN
- ; SZB FLAGS,C
- ; JP PAN_ERR_GAO_J
- LDIA D'110' ;600 DU
- SUBA TMPR_PAN
- SNZB FLAGS,C
- JP PAN_CLR_GAO
- CLR PAN_COUNT1
- JP PAN_CHED
- AD_CHECK_RJ:
- LDIA .52 ;250度
- SUBA TMPR_PAN
- SNZB FLAGS,C
- JP LENG_JI
- RE_JI:
- INCR PAN_COUNT
- LDIA D'5'
- SUBA PAN_COUNT
- SNZB FLAGS,C
- JP AD_COM
- CLR PAN_COUNT
- CLRB ERRF,0
- JP AD_COM
- LENG_JI:
- INCR PAN_COUNT1
- LDIA D'5'
- SUBA PAN_COUNT1
- SNZB FLAGS,C
- JP AD_COM
- CLR PAN_COUNT1
- SETB ERRF,0
- JP AD_COM
- PAN_ERR_KAI:
- INCR PAN_COUNT
- LDIA D'5'
- SUBA PAN_COUNT
- SNZB FLAGS,C
- JP PAN_CHED
- CLR PAN_COUNT
- SETB WORK,ERR ;不可恢復(fù)錯(cuò)誤
- SETB ERRF,3
- SETB RBEEP,0
- LDIA 04H
- LD RBEEPH,A
- JP PAN_CHED
- PAN_ERR_DUAN:
- SNZB FLAG,FEN3 ;3分鐘后
- JP PAN_CHED
- JP PAN_ERR_KAI
- PAN_ERR_GAO_G:
- INCR PAN_COUNT2
- LDIA D'5'
- SUBA PAN_COUNT2
- SNZB FLAGS,C
- JP PAN_CHED
- CLR PAN_COUNT2
- SETB ERRF,5
- JP PAN_CHED
- ;PAN_ERR_GAO_J:
- ; INCR PAN_COUNT1
- ; LDIA D'5'
- ; SUBA PAN_COUNT1
- ; SNZB FLAGS,C
- ; JP PAN_CHED
- ; CLR PAN_COUNT1
- ; SETB ERRF,0 ;降功率
- ; JP PAN_CHED
- PAN_CLR_GAO:
- SZB ERRF,5
- JP PAN_CLR_ON
- ; SZB ERRF,0
- ; JP PAN_CLR_ON
- CLR PAN_COUNT1
- CLR PAN_COUNT2
- JP PAN_CHED
- PAN_CLR_ON:
- INCR PAN_COUNT1
- LDIA D'5'
- SUBA PAN_COUNT1
- SNZB FLAGS,C
- JP PAN_CHED
- CLR PAN_COUNT1
- CLRB ERRF,5
- ; CLRB ERRF,0
- PAN_CHED:
- JP AD_COM
- ;*****************主板檢測(cè)*******************
- AD_TR:
- LD A,DATAL ;溫度AD
- LD TMPR_TR,A
- SNZB WORK,ONOFF
- JP AD_COM
- SZB WORK,ERR
- JP AD_COM
- LDIA 0E0H
- SUBA TMPR_TR
- SZB FLAGS,C
- JP TR_ERR_DUAN
- LDIA 05H
- SUBA TMPR_TR
- SNZB FLAGS,C
- JP TR_ERR_KAI
- CLR TR_COUNT
- LDIA .145;D'194' ;100
- SUBA TMPR_TR
- SZB FLAGS,C
- JP TR_GAOWEN_G
- LDIA .131;D'178' ;90
- SUBA TMPR_TR
- SZB FLAGS,C
- JP TR_GAOWEN_J
- LDIA .107;.159;D'105' ;80
- SUBA TMPR_TR
- SNZB FLAGS,C
- JP RT_CLR_GAOWEN
- CLR TR_COUNT1
- JP TR_CHED
- TR_ERR_DUAN:
- INCR TR_COUNT
- LDIA D'5'
- SUBA TR_COUNT
- SNZB FLAGS,C
- JP TR_CHED
- CLR TR_COUNT
- SETB WORK,ERR
- SETB ERRF,4
- SETB RBEEP,0
- LDIA 04H
- LD RBEEPH,A
- JP TR_CHED
- TR_ERR_KAI:
- JP TR_CHED
- JP TR_ERR_DUAN
- TR_GAOWEN_G:
- SZB ERRF,6
- JP TR_CHED
- INCR TR_COUNT1
- LDIA D'5'
- SUBA TR_COUNT1
- SNZB FLAGS,C
- JP TR_CHED
- CLR TR_COUNT1
- SETB ERRF,6
- SETB RBEEP,0
- LDIA 04H
- LD RBEEPH,A
- JP TR_CHED
- TR_GAOWEN_J:
- INCR TR_COUNT1
- LDIA D'5'
- SUBA TR_COUNT1
- SNZB FLAGS,C
- JP TR_CHED
- CLR TR_COUNT1
- SETB ERRF,7 ;降功率但是不報(bào)警
- JP TR_CHED
- RT_CLR_GAOWEN:
- SZB ERRF,6
- JP CLR_RT_ON
- SZB ERRF,7
- JP CLR_RT_ON
- CLR TR_COUNT1
- JP TR_CHED
- CLR_RT_ON:
- INCR TR_COUNT1
- LDIA D'5'
- SUBA TR_COUNT1
- SNZB FLAGS,C
- JP TR_CHED
- CLR TR_COUNT1
- CLRB ERRF,7
- CLRB ERRF,6
- JP TR_CHED
- TR_CHED:
- JP AD_COM
- AD_COM:
- CLR DATAL
- CLR DATAH
- INCR ADCOUNT
- LDIA D'3'
- SUBA ADCOUNT
- SNZB FLAGS,C
- JP AD_BACK
- CLR ADCOUNT
- AD_BACK:
- RET
- SET_POWER:
- SNZB WORK,ONOFF
- JP SET_POWER_OFF
- SZB FLAG,DJ
- JP SET_POWER_OFF
- ; SNZB ACF,AC_EN
- ; JP SET_POWER_OFF
- SZB ERRF,7
- JP QZ_200 ;強(qiáng)制最低檔
- ; SZB ERRF,0 ;冷機(jī)為1,熱機(jī)為0
- ; JP QZ_200 ;強(qiáng)制1000W
- LD A,POWER
- LD POWER_TEMP,A
- SET_POWER1:
- CALL SET_TABLE_POWER
- LD A,POWER1
- LD POWER_J,A
- SET_POWER_DOWN:
- LDIA .92 ;冷機(jī)降公率點(diǎn)
- SNZB ERRF,0
- LDIA .129 ;熱完機(jī)后溫度點(diǎn)
- LD WEN_D,A
- SET_POWER_DOWN_WEN:
- LD A,WEN_D
- SUBA TMPR_PAN
- SNZB FLAGS,C
- JP SET_POWER_1
- SZB ERRF,0
- SETB FLAG1,KS
- DECR POWER_J
- LDIA .8
- ADDR WEN_D
- LDIA D'2'
- SUBA POWER_J
- SNZB FLAGS,C
- JP SET_POWER_LOW
- LD A,WEN_D
- SUBA TMPR_PAN
- SNZB FLAGS,C
- JP SET_POWER_1
- DECR POWER_J
- LDIA .11
- ADDR WEN_D
- LDIA D'2'
- SUBA POWER_J
- SNZB FLAGS,C
- JP SET_POWER_LOW
- LD A,WEN_D
- SUBA TMPR_PAN
- SNZB FLAGS,C
- JP SET_POWER_1
- DECR POWER_J
- LDIA .4
- ADDR WEN_D
- LDIA D'2'
- SUBA POWER_J
- SNZB FLAGS,C
- JP SET_POWER_LOW
- SZB ERRF,0
- JP SET_POWER_1
- LD A,WEN_D
- SUBA TMPR_PAN
- SNZB FLAGS,C
- JP SET_POWER_1
- DECR POWER_J
- INCR WEN_D
- INCR WEN_D
- LDIA D'2'
- SUBA POWER_J
- SNZB FLAGS,C
- JP SET_POWER_LOW
- LD A,WEN_D
- SUBA TMPR_PAN
- SNZB FLAGS,C
- JP SET_POWER_1
- DECR POWER_J
- ;DECR POWER_J
- ;INCR WEN_D
- LDIA D'2'
- SUBA POWER_J
- SNZB FLAGS,C
- JP SET_POWER_LOW
- LD A,WEN_D
- SUBA TMPR_PAN
- SNZB FLAGS,C
- JP SET_POWER_1
- DECR POWER_J
- DECR POWER_J
- INCR WEN_D
- LDIA D'2'
- SUBA POWER_J
- SNZB FLAGS,C
- JP SET_POWER_LOW
- LD A,WEN_D
- SUBA TMPR_PAN
- SNZB FLAGS,C
- JP SET_POWER_1
- DECR POWER_J
- ;DECR POWER_J
- ; INCR WEN_D
- LDIA D'2'
- SUBA POWER_J
- SNZB FLAGS,C
- JP SET_POWER_LOW
- LD A,WEN_D
- SUBA TMPR_PAN
- SNZB FLAGS,C
- JP SET_POWER_1
- DECR POWER_J
- DECR POWER_J
- INCR WEN_D
- LDIA D'2'
- SUBA POWER_J
- SNZB FLAGS,C
- JP SET_POWER_LOW
- LD A,WEN_D
- SUBA TMPR_PAN
- SNZB FLAGS,C
- JP SET_POWER_1
- DECR POWER_J
- DECR POWER_J
- INCR WEN_D
- LDIA D'2'
- SUBA POWER_J
- SNZB FLAGS,C
- JP SET_POWER_LOW
- LD A,WEN_D
- SUBA TMPR_PAN
- SNZB FLAGS,C
- JP SET_POWER_1
- DECR POWER_J
- DECR POWER_J
- ;INCR WEN_D
- LDIA D'2'
- SUBA POWER_J
- SNZB FLAGS,C
- JP SET_POWER_LOW
- LD A,WEN_D
- SUBA TMPR_PAN
- SNZB FLAGS,C
- JP SET_POWER_1
- DECR POWER_J
- DECR POWER_J
- ;DECR POWER_J
- INCR WEN_D
- LDIA D'2'
- SUBA POWER_J
- SNZB FLAGS,C
- JP SET_POWER_LOW
- LD A,WEN_D
- SUBA TMPR_PAN
- SNZB FLAGS,C
- JP SET_POWER_1
- DECR POWER_J
- DECR POWER_J
- INCR WEN_D
- LDIA D'2'
- SUBA POWER_J
- SNZB FLAGS,C
- JP SET_POWER_LOW
- SET_POWER_LOW:
- LDIA D'2'
- LD POWER_J,A
- JP SET_POWER_1
- SET_POWER_1:
- LDIA 1FH
- ANDA POWER_J
- ADDR PCL
- JP SET_POWER_OFF
- JP POWER_100
- JP POWER_200
- JP POWER_300
- JP POWER_400
- JP POWER_500
- JP POWER_600
- JP POWER_700
- JP POWER_800
- JP POWER_900
- JP POWER_1000
- JP POWER_1100
- JP POWER_1200
- JP POWER_1300
- JP POWER_1400
- JP POWER_1500
- JP POWER_1600
- JP POWER_1700
- JP POWER_1800
- JP POWER_1900
- JP POWER_2000
- POWER_100:
- LDIA B'00000001'
- LD ENFLAG,A
- CLR ENFLAG1
- CLR ENFLAG2
- JP POWER_COM
- POWER_200:
- LDIA B'00000001'
- LD ENFLAG,A
- LDIA B'00000100'
- LD ENFLAG1,A
- LDIA B'00000000'
- LD ENFLAG2,A
- JP POWER_COM
- POWER_300:
- LDIA B'01000001'
- LD ENFLAG,A
- LDIA B'00100000'
- LD ENFLAG1,A
- LDIA B'00000000'
- LD ENFLAG2,A
- JP POWER_COM
- POWER_400:
- LDIA B'00100001'
- LD ENFLAG,A
- LDIA B'10000100'
- LD ENFLAG1,A
- LDIA B'00000000'
- LD ENFLAG2,A
- JP POWER_COM
- POWER_500:
- LDIA B'00010001'
- LD ENFLAG,A
- LDIA B'00010001'
- LD ENFLAG1,A
- LDIA B'00000001'
- LD ENFLAG2,A
- JP POWER_COM
- POWER_600:
- LDIA B'10001001'
- LD ENFLAG,A
- LDIA B'00100100'
- LD ENFLAG1,A
- LDIA B'00000010'
- LD ENFLAG2,A
- JP POWER_COM
- POWER_700:
- LDIA B'01001001'
- LD ENFLAG,A
- LDIA B'01001010'
- LD ENFLAG1,A
- LDIA B'00000010'
- LD ENFLAG2,A
- JP POWER_COM
- POWER_800:
- LDIA B'10100101'
- LD ENFLAG,A
- LDIA B'10010100'
- LD ENFLAG1,A
- LDIA B'00000010'
- LD ENFLAG2,A
- JP POWER_COM
- POWER_900:
- LDIA B'10010101'
- LD ENFLAG,A
- LDIA B'00101010'
- LD ENFLAG1,A
- LDIA B'00000101'
- LD ENFLAG2,A
- JP POWER_COM
- POWER_1000:
- LDIA B'00110011'
- LD ENFLAG,A
- LDIA B'00110011'
- LD ENFLAG1,A
- LDIA B'00000011'
- LD ENFLAG2,A
- JP POWER_COM
- POWER_1100:
- LDIA B'00110011'
- LD ENFLAG,A
- LDIA B'00110111'
- LD ENFLAG1,A
- LDIA B'00000011'
- LD ENFLAG2,A
- JP POWER_COM
- POWER_1200:
- LDIA B'00110011'
- LD ENFLAG,A
- LDIA B'00111111'
- LD ENFLAG1,A
- LDIA B'00000011'
- LD ENFLAG2,A
- JP POWER_COM
- POWER_1300:
- LDIA B'00110011'
- LD ENFLAG,A
- LDIA B'00111111'
- LD ENFLAG1,A
- LDIA B'00001011'
- LD ENFLAG2,A
- JP POWER_COM
- POWER_1400:
- LDIA B'10110011'
- LD ENFLAG,A
- LDIA B'00111111'
- LD ENFLAG1,A
- LDIA B'00001011'
- LD ENFLAG2,A
- JP POWER_COM
- POWER_1500:
- LDIA B'10111011'
- LD ENFLAG,A
- LDIA B'00111111'
- LD ENFLAG1,A
- LDIA B'00001011'
- LD ENFLAG2,A
- JP POWER_COM
- POWER_1600:
- LDIA B'01111011'
- LD ENFLAG,A
- LDIA B'10111111'
- LD ENFLAG1,A
- LDIA B'00000111'
- LD ENFLAG2,A
- JP POWER_COM
- POWER_1700:
- LDIA B'10111111'
- LD ENFLAG,A
- LDIA B'10111111'
- LD ENFLAG1,A
- LDIA B'00001011'
- LD ENFLAG2,A
- JP POWER_COM
- POWER_1800:
- LDIA B'01111111'
- LD ENFLAG,A
- LDIA B'11111111'
- LD ENFLAG1,A
- LDIA B'00000111'
- LD ENFLAG2,A
- JP POWER_COM
- POWER_1900:
- LDIA B'11111111'
- LD ENFLAG,A
- LDIA B'11111111'
- LD ENFLAG1,A
- LDIA B'00001011'
- LD ENFLAG2,A
- JP POWER_COM
- POWER_2000:
- LDIA B'11111111'
- LD ENFLAG,A
- LDIA B'11111111'
- LD ENFLAG1,A
- LDIA B'00001111'
- LD ENFLAG2,A
- JP POWER_COM
- POWER_COM:
- SZB ACF,AC_EN
- JP SET_POWER_BACK
- CLRB FLAG1,GL
- LDIA 1FH
- ANDA PCOUNT
- ADDR PCL
- JP CL1
- JP CL2
- JP CL3
- JP CL4
- JP CL5
- JP CL6
- JP CL7
- JP CL8
- JP CL9
- JP CL10
- JP CL11
- JP CL12
- JP CL13
- JP CL14
- JP CL15
- JP CL16
- JP CL17
- JP CL18
- JP CL19
- JP CL20
- CL1:
- SNZB ENFLAG,0
- JP SET_POWER_BACK
- SETB FLAG1,GL
- JP SET_POWER_BACK
- CL2:
- SNZB ENFLAG,1
- JP SET_POWER_BACK
- SETB FLAG1,GL
- JP SET_POWER_BACK
- CL3:
- SNZB ENFLAG,2
- JP SET_POWER_BACK
- SETB FLAG1,GL
- JP SET_POWER_BACK
- CL4:
- SNZB ENFLAG,3
- JP SET_POWER_BACK
- SETB FLAG1,GL
- JP SET_POWER_BACK
- CL5:
- SNZB ENFLAG,4
- JP SET_POWER_BACK
- SETB FLAG1,GL
- JP SET_POWER_BACK
- CL6:
- SNZB ENFLAG,5
- JP SET_POWER_BACK
- SETB FLAG1,GL
- JP SET_POWER_BACK
- CL7:
- SNZB ENFLAG,6
- JP SET_POWER_BACK
- SETB FLAG1,GL
- JP SET_POWER_BACK
- CL8:
- SNZB ENFLAG,7
- JP SET_POWER_BACK
- SETB FLAG1,GL
- JP SET_POWER_BACK
- CL9:
- SNZB ENFLAG1,0
- JP SET_POWER_BACK
- SETB FLAG1,GL
- JP SET_POWER_BACK
- CL10:
- SNZB ENFLAG1,1
- JP SET_POWER_BACK
- SETB FLAG1,GL
- JP SET_POWER_BACK
- CL11:
- SNZB ENFLAG1,2
- JP SET_POWER_BACK
- SETB FLAG1,GL
- JP SET_POWER_BACK
- CL12:
- SNZB ENFLAG1,3
- JP SET_POWER_BACK
- SETB FLAG1,GL
- JP SET_POWER_BACK
- CL13:
- SNZB ENFLAG1,4
- JP SET_POWER_BACK
- SETB FLAG1,GL
- JP SET_POWER_BACK
- CL14:
- SNZB ENFLAG1,5
- JP SET_POWER_BACK
- SETB FLAG1,GL
- JP SET_POWER_BACK
- CL15:
- SNZB ENFLAG1,6
- JP SET_POWER_BACK
- SETB FLAG1,GL
- JP SET_POWER_BACK
- CL16:
- SNZB ENFLAG1,7
- JP SET_POWER_BACK
- SETB FLAG1,GL
- JP SET_POWER_BACK
- CL17:
- SNZB ENFLAG2,0
- JP SET_POWER_BACK
- SETB FLAG1,GL
- JP SET_POWER_BACK
- CL18:
- SNZB ENFLAG2,1
- JP SET_POWER_BACK
- SETB FLAG1,GL
- JP SET_POWER_BACK
- CL19:
- SNZB ENFLAG2,2
- JP SET_POWER_BACK
- SETB FLAG1,GL
- JP SET_POWER_BACK
- CL20:
- SNZB ENFLAG2,3
- JP SET_POWER_BACK
- SETB FLAG1,GL
- JP SET_POWER_BACK
- SET_POWER_OFF:
- SETB EN
- CLRB FLAG1,GL
- SET_POWER_BACK:
- RET
- QZ_200:
- LDIA D'2'
- LD POWER_TEMP,A
- JP SET_POWER1
- QZ_1000:
- LDIA D'5'
- SUBA POWER
- SZB FLAGS,C
- JP POWER_1000W
- LD A,POWER
- LD POWER_TEMP,A
- JP SET_POWER1
- POWER_1000W:
- LDIA D'5'
- LD POWER_TEMP,A
- JP SET_POWER1
- SET_FAN_DENG:
- ; SZB WORK,ONOFF
- ; JP SET_FAN_DENG_BACK
- ; LDIA .10 ;50 DU
- ; SUBA TMPR_PAN
- ; SZB FLAGS,C
- ; JP SET_FAN_DENG_ON
- ; CLRB FLAG1,GW
- ; CLRB WORK,FAN1
- ; JP CHECK_FAN_TR
- ;SET_FAN_DENG_ON:
- ; SETB FLAG1,GW
- ; SETB WORK,FAN1
- ;CHECK_FAN_TR:
- ; LDIA .91
- ; SUBA TMPR_TR
- ; SNZB FLAGS,C
- ; SETB WORK,FAN1
- ; SZB WORK,ONOFF
- LDIA .90
- SUBA TMPR_TR
- SZB FLAGS,C
- JP SET_WFAN_ON1
- LDIA .9
- SUBA TMPR_PAN
- SZB FLAGS,C
- JP SET_WFAN_ON2
- INCR FCOUNT1
- LDIA D'20'
- SUBA FCOUNT1
- SNZB FLAGS,C
- JP SET_FAN_DENG_BACK
- CLR FCOUNT1
- CLRB FLAG1,GW
- SNZB WORK,ONOFF
- CLRB WORK,FAN1
- SET_WFAN_ON1:
- LDIA .14
- SUBA TMPR_PAN
- SZB FLAGS,C
- JP SET_WFAN_ON2
- LDIA .95
- SUBA TMPR_TR
- SNZB FLAGS,C
- INCR FCOUNT
- LDIA D'20'
- SUBA FCOUNT
- SNZB FLAGS,C
- CLR FCOUNT
- SETB WORK,FAN1
- SET_WFAN_ON2:
- LDIA .14
- SUBA TMPR_PAN
- SNZB FLAGS,C
- INCR FCOUNT0
- LDIA D'20'
- SUBA FCOUNT0
- SNZB FLAGS,C
- CLR FCOUNT0
- SETB WORK,FAN1
- SETB FLAG1,GW
- SET_FAN_DENG_BACK:
- RET
- NOP
- ERR_DY_TIME:
- SNZB FLAG,S05
- JP ERR_DY_TIME_BACK
- CLRB FLAG,S05
- SNZB WORK,ONOFF
- JP XX_OOO
- SZB FLAG,DJ
- JP XX_OOO
- SZB WORK,ERR
- JP XX_OOO
- LDIA .110
- SUBA TMPR_PAN
- SZB FLAGS,C
- JP CLR_ERR0
- SNZB FLAG1,KS
- JP XX_OOO
- INCR GAOT
- LDIA D'240'
- SUBA GAOT
- SNZB FLAGS,C
- JP XX_OOO
- CLR GAOT
- CLR_ERR0:
- CLRB ERRF,0
- CLRB FLAG1,KS
- XX_OOO:
- SNZB WORK,ONOFF
- SZB WORK,ERR
- LDIA B'00000110'
- ANDA ERRF
- SZB FLAGS,Z
- JP CLR_ERR_DY_TIME
- INCR EDYCOUNT1
- LDIA D'120'
- SUBA EDYCOUNT1
- SNZB FLAGS,C
- CLR EDYCOUNT1
- CALL SYS_OFF1
- CLR_ERR_DY_TIME:
- CLR EDYCOUNT1
- ERR_DY_TIME_BACK:
- RET
- SJ_SHUAXIN:
- CLR SECL
- LDIA D'10'
- LD SEC5S,A
- CLRB FLAG,SS
- RET 00H
- SYS_OFF1:
- CLR WORK
- CLR FLAG
- JP SYS_COM
- SYS_OFF:
- CLR WORK
- SETB WORK,ONOFF
- CLR FLAG
- SETB FLAG,DJ
- SYS_COM:
- CLR ERRF
- CLR BBCOUNT
- CLR FEN3_COUNT
- CLR POWER
- LDIA 02H
- LD HOUR,A
- CLR MIN
- CLRB FLAG1,KS
- SETB WORK,FAN1
- LDIA D'100'
- LD FANT,A
- LDIA D'18'
- LD FANT1,A
- CLR TR_COUNT
- CLR TR_COUNT1
- CLR PAN_COUNT
- CLR PAN_COUNT1
- CLR VOL_COUNT
- CLR FCOUNT0
- CLR FCOUNT
- CLR FCOUNT1
- RET 00H
- TABLE_SEG:
- ADDR PCL
- RET 0D7H ; 0
- RET 090H ; 1
- RET 0A7H ; 2
- RET 0B5H ; 3
- RET 0F0H ; 4
- RET 075H ; 5
- RET 077H ; 6
- RET 091H ; 7
- RET 0F7H ; 8
- RET 0F5H ; 9
- RET 0F3H ; A
- RET 076H ; B
- RET 047H ; C
- RET 0B6H ; D
- RET 067H ; E
- RET 063H ; F
- TABLE_DISP_POWER:
- ADDR PCL
- RET .0
- RET .2
- RET .4
- RET .6
- RET .8
- RET .10
- RET .12
- RET .14
- RET .16
- RET .18
- RET .20
- BCD_CH:
- LD BCD_REG,A ;調(diào)用前先把要分解的數(shù)放在A
- BCD_ACT:
- CLR TEMP
- UP_10:
- LDIA D'10'
- SUBA BCD_REG
- SNZB FLAGS,C
- JP DO_10
- LDIA D'10'
- SUBR BCD_REG
- INCR TEMP
- JP UP_10
- DO_10: ;取個(gè)位給個(gè)位顯示寄存器
- RET 00H
- ORG 0700H
- WR_1628:
- LD TEMP,A
- CLRB STB
- LDIA 08H
- LD COUNT,A
- WR_LOOP:
- CLRB CLK
- RRCR TEMP
- CLRB DIO
- SZB FLAGS,C
- SETB DIO
- SETB CLK
- SZDECR COUNT
- JP WR_LOOP
- RET 00H
- KSCAN_TAB:
- LDIA 07H
- ANDA KCOUNT
http://www.torrancerestoration.com/bbs/dpj-95826-1.html
