已經(jīng)看了很久很久很久了一直未能解決這個問題...很絕望啊,國慶節(jié)就寫好的,一直找到現(xiàn)在都還不知道哪里出了問題,太難受了。!這是定時采集溫度的單片機程序
- #include <reg52.h>
- #include <intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define MAIN_Fosc 11059200UL //宏定義主時鐘HZ
- 自定義類型名
- typedef unsigned char INT8U;
- typedef unsigned int INT16U;
- sbit TSCLK = P1^0;//時鐘線 接到P10上用杜邦線
- sbit TIO = P1^1;//數(shù)據(jù)線,接到P11上
- sbit TRST = P1^2;//使能端,接到P12上
- sbit DS = P2^2; //DS18B20單總線
- uint wenduzhi[10];
- static n=0;
- sbit DU = P2^6; //數(shù)碼管段選
- sbit WE = P2^7; //數(shù)碼管位選
- sbit we = P2^7;
- sbit du = P2^6;
- sbit KEY1=P3^0;
- sbit KEY2=P3^1;
- sbit KEY3=P3^2;
- sbit KEY4=P3^3;
- uchar time_1=1;
- uchar shi1=0,shi2=0;
- uint wenduzhi[10]={0};
- uint p_1=0;
- void timer();
- void ds18b20();
- unsigned char pp;
- 共陰極數(shù)碼管段選碼
- uchar code table[]={
- //0 1 2 3 4 5 6 7 8
- 0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F,
- //9 A B C D E F - . 關(guān)顯示
- 0x6F, 0x77, 0x7C, 0x39, 0x5E, 0x79, 0x71, 0x40, 0x80, 0x00
- 數(shù)碼管位選碼
- //第1位 2位 3位 4位 5位 6位 7位 8位
- uchar code T_COM[] = {0xfe, 0xfd, 0xfb, 0xf7, 0xef, 0xdf, 0xbf, 0x7f};//數(shù)碼管位碼
- uchar code leddata[]={
- 0x3F, //"0"
- 0x06, //"1"
- 0x5B, //"2"
- 0x4F, //"3"
- 0x66, //"4"
- 0x6D, //"5"
- 0x7D, //"6"
- 0x07, //"7"
- 0x7F, //"8"
- 0x6F, //"9"
- 0x77, //"A"
- 0x7C, //"B"
- 0x39, //"C"
- 0x5E, //"D"
- 0x79, //"E"
- 0x71, //"F"
- 0x76, //"H"
- 0x38, //"L"
- 0x37, //"n"
- 0x3E, //"u"
- 0x73, //"P"
- 0x5C, //"o"
- 0x40, //"-"
- 0x00, //熄滅
- 0x00 //自定義
- void delay1(uint z)
- uint x,y;
- for(x = z; x > 0; x--)
- for(y = 114; y > 0 ; y--);
- uchar code leddata[];
- void delay(uint z)
- uint x,y;
- void Delay_us(uchar us)
- while(us--);
- void smg()
- char i=0;
- unsigned char sj[4]={1,5,30,60};
- while(1)
- we = 1;
- P0=0x7f;
- we=0;
- du=1;
- P0=leddata[sj[i]%10];
- du=0;
- delay(5);
- we = 1;
- P0=0xbf;
- we=0;
- du=1;
- P0=leddata[sj[i]/10];
- du=0;
- delay(5);
- we = 1;
- P0=0xdf;
- we=0;
- du=1;
- P0=leddata[22];
- du=0;
- delay(5);
- if(0==KEY1)
- delay(10);
- if(0==KEY1)
- i++;
- if(4==i)
- i=0;
- time_1=sj[i];
- if(0==KEY2) //檢測按鍵是否按下
- delay(10); //延時去抖
- if(0==KEY2)
- break;
- void Delay_Ms(INT16U ms)
- INT16U i;
- do{
- i = MAIN_Fosc / 96000;
- while(--i); //96T per loop
- }while(--ms);
- void Display(uchar Hour, Min, Sec)
- DU = 0;
- P0 = table[Hour/10];
- DU = 1;
- DU = 0;
- WE = 0;
- P0 = T_COM[0];
- WE = 1;
- WE = 0;
- Delay_Ms(3);
- DU = 0;
- P0 = table[Hour%10]; //為了加點|0x80
- DU = 1;
- DU = 0;
- WE = 0;
- P0 = T_COM[1];
- WE = 1;
- WE = 0;
- Delay_Ms(3);
- DU = 0;
- P0 = table[16];
- DU = 1;
- DU = 0;
- WE = 0;
- P0 = T_COM[2];
- WE = 1;
- WE = 0;
- Delay_Ms(3);
- DU = 0;
- P0 = table[Min/10];
- DU = 1;
- DU = 0;
- WE = 0;
- P0 = T_COM[3];
- WE = 1;
- WE = 0;
- Delay_Ms(3);
- DU = 0;
- P0 = table[Min%10]; // 為了加點|0x80 不錯的算法
- DU = 1;
- DU = 0;
- WE = 0;
- P0 = T_COM[4];
- WE = 1;
- WE = 0;
- Delay_Ms(3);
- DU = 0;
- P0 = table[16];
- DU = 1;
- DU = 0;
- WE = 0;
- P0 = T_COM[5];
- WE = 1;
- WE = 0;
- Delay_Ms(3);
- DU = 0;
- P0 = table[Sec/10];
- DU = 1;
- DU = 0;
- WE = 0;
- P0 = T_COM[6];
- WE = 1;
- WE = 0;
- Delay_Ms(3);
- DU = 0;
- P0 = table[Sec%10];
- DU = 1;
- DU = 0;
- WE = 0;
- P0 = T_COM[7];
- WE = 1;
- WE = 0;
- Delay_Ms(3);
- //寫DS1302數(shù)據(jù)
- void Write_DS1302_DAT(uchar cmd, uchar dat)
- uchar i;
- TRST = 0; //拉低使能端
- TSCLK = 0;//拉低數(shù)據(jù)總線
- TRST = 1; //拉高使能端,產(chǎn)生上升沿開始寫數(shù)據(jù)
- for(i = 0; i < 8; i++)//每次寫1位,寫8次
- TSCLK = 0; //拉低時鐘總線
- TIO = cmd & 0x01; //寫1位數(shù)據(jù),從最低位開始寫
- TSCLK = 1; //拉高時鐘總線,產(chǎn)生上升沿數(shù)據(jù)被DS1302讀走
- cmd >>=1; //右移一位
- TIO = dat & 0x01; //寫1位數(shù)據(jù),從最低位開始寫
- dat >>= 1; //右移一位
- //讀DS1302數(shù)據(jù)
- uchar Read_DS1302_DAT(uchar cmd)
- uchar i, dat;
- TRST = 0; //拉低使能端
- TSCLK = 0; //拉低數(shù)據(jù)總線
- TIO = cmd & 0x01;//寫1位數(shù)據(jù),從最低位開始寫
- cmd >>=1; //右移一位
- for(i = 0; i < 8; i++)//每次讀1位,讀8次
- TSCLK = 0; //拉低時鐘總線,產(chǎn)生下降沿,DS1302把數(shù)據(jù)放到TIO上
- dat >>= 1; //右移一位
- if(TIO) dat |= 0x80;//讀取數(shù)據(jù),從最低位開始
- TSCLK = 1; //拉高時鐘總線,以備下一次產(chǎn)生下降沿
- return dat; //返回讀出數(shù)據(jù)
- //數(shù)據(jù)轉(zhuǎn)BCD碼
- uchar Dat_Chg_BCD(uchar dat)
- uchar dat1, dat2;
- dat1 = dat / 10;
- dat2 = dat % 10;
- dat2 = dat2 + dat1 * 16;
- return dat2;
- //BCD碼轉(zhuǎn)換為數(shù)據(jù)
- uchar BCD_Chg_Dat(uchar dat)
- uchar dat1, dat2;
- dat1 = dat / 16;
- dat2 = dat % 16;
- dat2 = dat2 + dat1 * 10;
- return dat2;
- void ds1302()
- uchar i;
- uchar Sec, Min, Hour;
- Write_DS1302_DAT(0x8e, 0);//清除寫保護
- Write_DS1302_DAT(0x80, Dat_Chg_BCD(10));//30秒(并且進行BCD碼轉(zhuǎn)換)
- Write_DS1302_DAT(0x82, Dat_Chg_BCD(0));//15分
- Write_DS1302_DAT(0x84, Dat_Chg_BCD(0));//19時
- Write_DS1302_DAT(0x8e, 0x80);//開寫保護
- while(1)
- Write_DS1302_DAT(0x8e, 0); //清除寫保護
- Sec = BCD_Chg_Dat(Read_DS1302_DAT(0x81));//讀秒寄存器(并且進行BCD碼轉(zhuǎn)換)
- Min = BCD_Chg_Dat(Read_DS1302_DAT(0x83));//讀分寄存器
- Hour = BCD_Chg_Dat(Read_DS1302_DAT(0x85));//讀時寄存器
- for(i = 0; i < 50; i++) //循環(huán)顯示時鐘
- Display(Hour, Min, Sec);
- if(n==10)
- TR0=0;
- P1=0; // 最好寫0x00 不然后面會誤解 成位 就會 寫錯
- break;
- bit ds_init()
- bit i;
- DS = 1;
- _nop_();
- DS = 0;
- Delay_us(75); //拉低總線499.45us 掛接在總線上的18B20將會全部被復位
- DS = 1; //釋放總線
- Delay_us(4); //延時37.95us 等待18B20發(fā)回存在信號
- i = DS;
- Delay_us(20); //141.95us
- DS = 1;
- _nop_();
- return (i);
- /*寫一個字節(jié)*/
- void write_byte(uchar dat)
- uchar i;
- for(i=0;i<8;i++)
- DS = 0;
- _nop_();//產(chǎn)生些時序
- DS = dat & 0x01;
- Delay_us(10);//76.95us
- DS = 1; //釋放總線準備下一次數(shù)據(jù)寫入
- _nop_();
- dat >>= 1;
- uchar read_byte()
- uchar i, j, dat;
- for(i=0;i<8;i++)
- DS = 0;
- _nop_();//產(chǎn)生讀時序
- DS = 1;
- _nop_();//釋放總線
- j = DS;
- DS = 1;
- _nop_();
- dat = (j<<7)|(dat>>1);
- return (dat);
- void ds18b20()
- uint i;
- uchar L, M;
- /* ds_init();//初始化DS18B20
- write_byte(0xcc);//發(fā)送跳躍ROM指令
- write_byte(0x4e);//寫暫存器指令
- write_byte(0x7f);
- write_byte(0xf7);
- write_byte(0x1f);//配置工作在9位模式下
- ds_init();//初始化DS18B20
- write_byte(0x48);*/
- // while(1)
- write_byte(0x44);//發(fā)送溫度轉(zhuǎn)換指令
- write_byte(0xbe);//讀取DS18B20暫存器值
- L = read_byte();
- M = read_byte();
- i = M;
- i <<= 8;
- i |= L;
- i = i * 0.0625 * 10 + 0.5;
- // Display(i);
- wenduzhi[n]=i;
- n++;
- void smg2()
- n=0;
- while(1)
- DU = 0;
- P0 = table[16];
- DU = 1;
- DU = 0;
- WE = 0;
- P0 = T_COM[0];
- WE = 1;
- WE = 0;
- Delay_Ms(3);
- DU = 0;
- P0 = table[n/10]; //為了加點|0x80
- DU = 1;
- DU = 0;
- WE = 0;
- P0 = T_COM[1];
- WE = 1;
- WE = 0;
- Delay_Ms(3);
- DU = 0;
- P0 = table[n%10];
- DU = 1;
- DU = 0;
- WE = 0;
- P0 = T_COM[2];
- WE = 1;
- WE = 0;
- Delay_Ms(3);
- DU = 0;
- P0 = table[18];
- DU = 1;
- DU = 0;
- WE = 0;
- P0 = T_COM[3];
- WE = 1;
- WE = 0;
- Delay_Ms(3);
- DU = 0;
- P0 = table[18]; // 為了加點|0x80 不錯的算法
- DU = 1;
- DU = 0;
- WE = 0;
- P0 = T_COM[4];
- WE = 1;
- WE = 0;
- Delay_Ms(3);
- DU = 0;
- P0 = table[16];
- DU = 1;
- DU = 0;
- WE = 0;
- P0 = T_COM[5];
- WE = 1;
- WE = 0;
- Delay_Ms(3);
- DU = 0;
- P0 = table[wenduzhi[n]/100]; //溫度值擴大了 10倍 所以有三位數(shù) 23.5——235 個位實際上是十位,這樣便于計算
- DU = 1;
- DU = 0;
- WE = 0;
- P0 = T_COM[6];
- WE = 1;
- WE = 0;
- Delay_Ms(3);
- DU = 0;
- P0 = table[wenduzhi[n]/10%10];
- DU = 1;
- DU = 0;
- WE = 0;
- P0 = T_COM[7];
- WE = 1;
- WE = 0;
- Delay_Ms(3);
- if(0==KEY3)
- delay(10);
- if(0==KEY3)
- n++;
- P1=0XFF;
- // P1=1; 這里p1是一個字節(jié)有八位 送1的話會默認為是十進制 也就是0x01了
- if(10==n)
- n=0;
- if(0==KEY4)
- delay(10);
- if(0==KEY4)
- break;
- void T0Init()
- TMOD=0X01;
- TL0 = 0x00; //設(shè)置定時初值
- TH0 = 0x4C; //設(shè)置定時初值 50MS
- TR0=1;
- ET0=1;
- EA=1;
- void main()
- while(1)
- // T0Init();
- smg();
- T0Init();//在數(shù)碼管之后不行 1秒的時候會異常 在按鍵里設(shè)置tr0=1也是一樣。
- ds1302();
- smg2();
- void T0timer() interrupt 1 //using 1 //加上會出現(xiàn)異常,我也不知道為什么
- p_1++;
- switch(time_1)
- case(1):
- if(p_1==20)
- p_1=0;
- ds18b20();
- case(5):
- if(p_1==100)
- p_1=0;
- ds18b20();
- case(30):
- if(p_1==600)
- p_1=0;
- ds18b20();
- case(60):
- if(p_1==1200)
- p_1=0;
- ds18b20();
復制代碼 |
