查看: 2959|回復: 1
用1602單片機設計的可調(diào)電子鐘顯示不正確
ID:250133 發(fā)表于 2017-11-19 16:17 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
sbit rs=P2^0; //定義液晶顯示器控制端口
sbit rw=P2^1;
sbit en=P2^2;
sbit s1=P1^0; //定義按鍵控制
sbit s2=P1^1;
sbit s3=P1^2;
sbit s4=P1^3;
uchar shi,fen,miao,ri,yue,nin;
uchar code table[]={"      clock"};
uchar code table1[]={"    00:00:57"};
uchar num,num1,count;
uint i,sh,ge,s,g;
void delay(uchar time)   //延時
   uint j;
   for(;time>0;time--)
   for(j=0;j<125;j++);
void write_com(uchar com)    //寫指令函數(shù)
  en=0;
  rs=0;
  delay(5);
  P0=com;
  delay(5);
   en=1;
  delay(5);
  en=0;
void write_data(uchar dat)   //寫數(shù)據(jù)函數(shù)
   en=0;
  rs=1;
  delay(5);
   P0=dat;
  delay(5);
   en=1;
  delay(5);
  en=0;
void init()   //初始化
     en=0;
     rw=0;
    write_com(0x38);//設置16X2顯示,5X7點陣,8位數(shù)據(jù)接口
    write_com(0x0c);//設置開顯示,不顯示光標
    write_com(0x06);//寫一個字符后地址指針加1
    write_com(0x01);//顯示清零,數(shù)據(jù)指針清零
for(i=0;i<(sizeof(table)-1);i++)   //第一行寫
    write_com(0x80+i);
    write_data(table[i]);
for(i=0;i<(sizeof(table1)-1);i++) //第二行寫
       write_com(0x80+0x40+i);
    write_data(table1[i]);
miao=56;
fen=59;
shi=23;
TMOD=0x01;    //time0作為定時器工作在模式1下
TH0=(65536-50000)/256;
TL0=(65536-50000)%6;
EA=1;  //開啟總中斷
ET0=1;   //開啟time0中斷
TR0=1;   //啟動time0
void write_sfm(uchar add,uchar num)  //時分秒函數(shù)
    sh=num/10;   //分離出十位
    ge=num;    //分離出個位
   write_com(0x80+0x40+add); //第二行數(shù)據(jù)指針位置調(diào)整
   write_data(0x30+sh);   //更改顯示數(shù)據(jù)的十位
   write_data(0x30+ge);  //更改顯示數(shù)據(jù)的個位
void timer0() interrupt 1 //time0中斷
   TH0=(65536-50000)/256;  //重裝初始值
   count++;
if(count==20)  //20次到則滿一秒
     count=0;
     miao++;
   if(miao==60)
        miao=0;
        fen++;
      if(fen==60)
             fen=0;
              shi++;
     if(shi==24)
             shi=0;
          write_sfm(4,shi);
     write_sfm(7,fen);
   write_sfm(10,miao);
void keyscan()    //鍵盤掃描
{  if(s1==0) //按下S1
      delay(5);
     if(s1==0)
             num1++;
         while(!s1);//等待釋放
            if(num1==1)
                  TR0=0;
          write_com(0x0e);  //顯示光標,不閃爍
      write_com(0x80+0x40+0x0b);  //數(shù)據(jù)指針移動到秒的個位處
             write_com(0x0f);//顯示光標,閃爍
                if(num1==2)
          write_com(0x80+0x40+0x08);  //數(shù)據(jù)指針移到到分鐘的個位處
                            if(num1==3)
                 write_com(0x80+0x40+0x05);  //數(shù)據(jù)指針移到到小時的個位處
                                    if(num1==4)
                                         num1=0;    //清零
                                      write_com(0x0c);  //重新顯示
                                       TR0=1;   //重新啟動計時
           if(num1!=0)   //按下S2則選擇時/分/秒加1
             if(s2==0)
                delay(5);
                 if(s2==0)
                    while(!s2);
               if(num1==1)
                  delay(20);
                         miao++;
                       if(miao==60)
                      miao=0;
                       write_sfm(10,miao);
        write_com(0x80+0x40+0x0a);
                           if(num1==2)
                              fen++;
                             if(fen==60)
                             fen=0;
                          write_sfm(7,fen);
                     write_com(0x80+0x40+0x07);
                                  if(num1==3)
                                     shi++;
                                    if(shi==24)
                                     shi=0;
                                  write_sfm(4,shi);
                         write_com(0x80+0x40+0x04);
     if(num1!=0)
               if(s3==0) //按下S3則選擇時/分/秒 減1
                  delay(5);
                  if(s3==0)
                  while(!s3);
                     if(num1==1)
                     delay(20);
                      miao--;
                         if(miao==-1)
                       miao=59;
              write_sfm(10,miao);
                         if(num1==2)
                               fen--;
                             if(fen==-1)
                           fen=59;
               write_sfm(7,fen);
                              if(num1==3)
                                shi--;
                                if(shi==-1)
                                shi=23;
                             write_sfm(4,shi);
                              if(num1!=0)
            if(s4==0)   //確定按鍵
                                     delay(5);
                                       if(s4==0)
                                         while(!s4);
            num1=0;    //清零
                                            TR0=1;   //重新啟動計時
    init();
       keyscan();
ID:111634 發(fā)表于 2017-11-19 19:19 | 只看該作者
本帖最后由 zl2168 于 2017-11-19 19:20 編輯
給你介紹一個正確有效的案例,自己對照查錯吧!
實例91  具有校正功能的時鐘1302LCD1602顯示)
先Proteus仿真,確認有效。 實例91 帶校正時鐘1302(LCD1602顯示).rar (52.68 KB, 下載次數(shù): 6)
以上摘自張志良編著《80C51單片機仿真設計實例教程——基于Keil CProteus》清華大學出版社ISBN 978-7-302-41682-1,書中電路和程序設計有詳細說明,程序語句條條有注解。仿真電路和Hex文件能在清華出版社網(wǎng)站免費下載,程序源代碼只能到書上看了。到圖書館借,或到新華書店翻閱,或到網(wǎng)上書店打折購買。
