DS18b20數(shù)碼管顯示
#include<reg52.h> //包含頭文件,一般情況不需要改動(dòng),頭文件包含特殊功能寄存器的定義
#include "18b20.h"
#include"delay.h"
#define DataPort P0 //定義數(shù)據(jù)端口 程序中遇到DataPort 則用P0 替換
sbit LATCH1=P2^2; //定義鎖存使能端口 段鎖存
sbit LATCH2=P2^3; // 位鎖存
sbit RELAY1 = P2^1; //定義繼電器信號(hào)輸出端口1
sbit key=P3^2; //繼電器按鍵控制
sbit mq2=P3^1; //定義煙霧傳感器輸入腳P10
sbit spk=P2^6; //定義蜂鳴器輸出腳
sbit led=P2^0; //定義報(bào)警指示燈輸出腳
sbit led2=P2^7; //照明燈
sbit in=P2^4; //人體傳感器接口
sbit gm=P2^5; //光敏傳感器接口
sbit keyk=P3^3; //按鍵開
sbit keyg=P3^4; //按鍵關(guān)
sbit keyt=P3^5; //按鍵停
sbit ledk=P3^6; //開指示燈
sbit ledg=P3^7; //關(guān)指示燈
//sbit ledt=P3^0; //停指示燈
bit ReadTempFlag; //定義讀時(shí)間標(biāo)志
unsigned char code dofly_DuanMa[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};// 顯示段碼值0~9
unsigned char code dofly_WeiMa[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//分別對(duì)應(yīng)相應(yīng)的數(shù)碼管點(diǎn)亮,即位碼
unsigned char TempData[8]; //存儲(chǔ)顯示值的全局變量
unsigned char code zz[]={0x01,0x03,0x02,0x06,0x04,0x0c,0x08,0x09}; //正轉(zhuǎn)
unsigned char code fz[]={0x09,0x08,0x0c,0x04,0x06,0x02,0x03,0x01}; //反轉(zhuǎn)
void Display(unsigned char FirstBit,unsigned char Num);//數(shù)碼管顯示函數(shù)
void Init_Timer0(void);//定時(shí)器初始化
unsigned char frq;
opean the speaker函數(shù)
void speaker()
TR1=1;
DelayMs(1); //延時(shí)1ms,累加頻率值
frq++;
void closespeaker()
TR1=0;
void delay1(unsigned int ms)
unsigned int t;
while(ms--)
for(t=0;t<120;t++);
//延時(shí)程序//
void delay(int n) //int n 傳遞的是延時(shí)毫秒的數(shù),比如延時(shí)10毫秒則為10
unsigned char i; //定義三個(gè)全局變量
for(n=i;n>0;n--) //這個(gè)循環(huán)是毫秒數(shù)
for(i=250;i>0;i--); //這個(gè)循環(huán)是1毫秒循環(huán)次數(shù)
void motor_zz(unsigned int n)
unsigned int i,j;
for(i=0;i<200*n;i++)
for(j=0;j<8;j++)//步進(jìn)電機(jī)八個(gè)工作節(jié)拍
if(keyt==0)
break;
P1=zz[j];
delay1(1);
void motor_fz(unsigned int n)
unsigned int i,j;
for(j=0;j<8;j++)
if(keyt==0)
break;
P1=fz[j];
delay1(1);
void ywcgq()
if(mq2==0)
{ //煙霧傳感器報(bào)警
speaker();
led=0;
delay(1000);
closespeaker();
led=1;
delay(1000);
void rtdeng()
if(in==0&&gm==1)
led2 = 1;
delay(200);
led2 = 0;
void bjdj()
unsigned int N=3;
if(keyk==0||gm==0) //1111 1110
if(keyk==0||gm==0)
while(keyk==0||gm==0); //1111 1110
ledk=0; //1111 1110
motor_zz(N);
if(keyt==0) //1111 1011
ledk=1;
if(keyg==0) //1111 1101
if(keyg==0)
while(keyg==0); //1111 1101
ledg=0; //1111 1101
motor_fz(N);
ledg=1;
// break;
// else
// //ledt=0;
// if(keyk!=0||keyg!=0)
// // ledt=~ledt;
// P1=0x03;
主函數(shù)
unsigned int TempH,TempL,temp;
float temperature;
void dispplayTempu();
void main (void)
ReadTempFlag=1;
Init_Timer0();
RELAY1=0;
while (1) //主循環(huán)
rtdeng(); //人體光控?zé)?br />
ywcgq(); //煙霧傳感器報(bào)警
bjdj();
if(ReadTempFlag==1)
ReadTempFlag=0;
temp=ReadTemperature();
temperature=temp*0.0625; //溫度轉(zhuǎn)換
if(temperature>25||key==0) //繼電器控制
RELAY1=0;
else if(temperature<25)
RELAY1=1;
dispplayTempu();//顯示溫度
顯示函數(shù),用于動(dòng)態(tài)掃描數(shù)碼管
輸入?yún)?shù) FirstBit 表示需要顯示的第一位,如賦值2表示從第三個(gè)數(shù)碼管開始顯示
如輸入0表示從第一個(gè)顯示。
Num表示需要顯示的位數(shù),如需要顯示99兩位數(shù)值則該值輸入2
void dispplayTempu() //數(shù)碼管顯示 溫度
if(temp&0x8000)
TempData[0]=0x40;//負(fù)號(hào)標(biāo)志
temp=~temp; // 取反加1
temp +=1;
TempData[0]=0;
TempH=temp>>4;
TempL=temp&0x0F;
TempL=TempL*6/10;//小數(shù)近似處理
if(TempH/100==0)
TempData[1]=0;
TempData[1]=dofly_DuanMa[TempH/100]; //十位溫度
if((TempH/100==0)&&((TempH%100)/10==0))//消隱
TempData[2]=0;
TempData[2]=dofly_DuanMa[(TempH%100)/10]; //十位溫度
TempData[3]=dofly_DuanMa[(TempH%100)%10]|0x80; //個(gè)位溫度,帶小數(shù)點(diǎn)
TempData[4]=dofly_DuanMa[TempL];
TempData[6]=0x39;
static unsigned char i=0;
DataPort=0; //清空數(shù)據(jù),防止有交替重影
LATCH1=1; //段鎖存
LATCH1=0;
DataPort=dofly_WeiMa[i+FirstBit]; //取位碼
LATCH2=1; //位鎖存
LATCH2=0;
DataPort=TempData[i]; //取顯示數(shù)據(jù),段碼
LATCH1=1; //段鎖存
LATCH1=0;
i++;
if(i==Num)
i=0;
定時(shí)器初始化子程序
TMOD |= 0x21; //使用模式1,16位定時(shí)器,使用"|"符號(hào)可以在使用多個(gè)定時(shí)器時(shí)不受影響
//TH0=0x00; //給定初值
//TL0=0x00;
EA=1; //總中斷打開
ET0=1; //定時(shí)器中斷打開
TR0=1; //定時(shí)器開關(guān)打開
ET1 = 1; //開定時(shí)器0中斷
TR1 = 1; //允許定時(shí)器0定時(shí)
定時(shí)器中斷0程序
void time0_int() interrupt 1
static unsigned int num;
TH0=(65536-2000)/256; //重新賦值 2ms
TL0=(65536-2000)%256;
Display(0,8); // 調(diào)用數(shù)碼管掃描
num++;
if(num==300) //
num=0;
ReadTempFlag=1; //讀標(biāo)志位置1
void Timer1() interrupt 3
TH0=0xfe; //重新賦值
TL0=frq; //低8位值在主程序中不斷累加
spk=!spk; //端口電平取反
