查看: 23181|回復: 0
OPA277,OPA2277,OPA4277運放引腳圖與pdf數(shù)據(jù)手冊下載
ID:251355 發(fā)表于 2017-11-20 11:22 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
opa277 運放芯片數(shù)據(jù)手冊介紹
Description
The OPAx277 series precision operational amplifiers replace the industry standard OP-177. They offer improved noise, wider output voltage swing, and are twice as fast with half the quiescent current. Features include ultralow offset voltage and drift, low bias
current, high common-mode rejection, and high power supply rejection. Single, dual, and quad versions have identical specifications, for maximum design flexibility.
OPA277引腳圖:
OPA227管腳功能定義:
OPA2277引腳圖:
OPA2277管腳功能定義:
OPA4277引腳圖:
OPA4277管腳功能定義:
完整的pdf格式文檔51黑下載地址(共42頁):
opa277數(shù)據(jù)手冊.pdf (1.55 MB, 下載次數(shù): 33)
