我用ad軟件畫(huà)了原理圖跟pcb圖,并且利用手頭資源做了出來(lái),現(xiàn)在把這個(gè)給大家拿出來(lái)共享,因?yàn)槲沂菍W(xué)硬件的,所以軟件編程不是太好,程序都是自己打的,但是沒(méi)用到中斷跟延時(shí)。望各位大神給指點(diǎn)程序的改進(jìn)之處。
2017-11-21 18:05 上傳
2017-11-21 18:04 上傳
下面是程序
下面是初始界面跟計(jì)算器還有密碼鎖的圖片
2017-11-21 17:56 上傳
2017-11-21 17:56 上傳
2017-11-21 17:56 上傳
2017-11-21 17:56 上傳
2017-11-21 17:56 上傳
- #include<reg52.h>
- #include<stdio.h>
- #include"1602.h"
- #include"delay.h"
- #include"keyboard.h"
- sbit key1=P3^0;
- sbit key2=P3^1;
- unsigned char code password[]={'1','2','3','4','5','6','7','8'};//可以更改此密碼做多組測(cè)試
- //定義密碼,實(shí)際上密碼需要存在eeprom中,可以通過(guò)程序更改。
- unsigned char code cg_1602[]={ 0x08,0x0f,0x12,0x0f,0x0a,0x1f,0x02,0x02,
- 0x0f,0x09,0x0f,0x09,0x0f,0x09,0x11,0x00,
- 0x0f,0x09,0x09,0x0f,0x09,0x09,0x0f,0x00,
- 0x1f,0x04,0x04,0x0e,0x04,0x04,0x04,0x1f,
- 0x0a,0x1f,0x0a,0x1f,0x02,0x04,0x09,0x1f,
- 0x00,0x1b,0x1b,0x00,0x11,0x1b,0x0e,0x04};//"年月日王藝xiaolian"
- 主程序
- main()
- unsigned char num,i,j;
- unsigned char passwordtemp[16]; //最大輸入16個(gè)
- unsigned char inputtimes; //密碼輸入錯(cuò)誤次數(shù)
- unsigned char passwordlength,PLEN=8; //輸入密碼長(zhǎng)度,實(shí)際密碼長(zhǎng)度
- unsigned char q,p,sign;
- unsigned char temp[16]; //最大輸入16個(gè)
- unsigned char s,num1;
- float a=0,b=0;
- bit firstflag;
- bit Flag;
- LCD_Init(); //初始化液晶屏
- DelayMs(10); //延時(shí)用于穩(wěn)定,可以去掉
- LCD_Clear(); //清屏
- LCD_Write_Com(0x40); //設(shè)定CGRAM地址
- for(num1=0;num1<48;num1++) //將自定義字型碼寫(xiě)入CGRAM中
- LCD_Write_Data(cg_1602[num1]);
- LCD_Write_Com(0x82);//年
- LCD_Write_Data(0);
- LCD_Write_Com(0x85);//月
- LCD_Write_Data(1);
- LCD_Write_Com(0x88);//日
- LCD_Write_Data(2);
- LCD_Write_Com(0x8a);//王
- LCD_Write_Data(3);
- LCD_Write_Com(0x8b);//藝
- LCD_Write_Data(4);
- LCD_Write_Com(0x89);//
- LCD_Write_Data(5);
- LCD_Write_String(0,0,"17");
- LCD_Write_String(3,0,"11");
- LCD_Write_String(6,0,"19");
- LCD_Write_String(12,0,"Chao");
- LCD_Write_String(1,1,"Welcome to YOU");
- for(s=0;s<5;s++)//延時(shí)5s
- DelayMs(500);
- LCD_Write_Com(0x01);
- if(key1==0)
- { LCD_Init(); //初始化液晶屏
- LCD_Clear(); //清屏
- LCD_Write_String(0,0,"I LIKE MCU"); //寫(xiě)入第一行信息,主循環(huán)中不再更改此信息,所以在while之前寫(xiě)入
- LCD_Write_String(0,1,"Tian He Number 1"); //寫(xiě)入第二行信息,提示輸入密碼 //寫(xiě)入第二行信息,提示輸入密碼
- for(s=0;s<25;s++)//延時(shí)5s
- DelayMs(200);
- while (1) //主循環(huán)
- q=KeyPro(); //掃描鍵盤(pán)
- if(q!=0xff) //如果掃描是按鍵有效值則進(jìn)行處理
- if(p==0) //輸入是第一個(gè)字符的時(shí)候需要把改行清空,方便觀看
- if(('+'==q)|| (p==16) || ('-'==q) || ('x'==q)|| ('/'==q) || ('='==q))//輸入數(shù)字最大值16,輸入符號(hào)表示輸入結(jié)束
- p=0; //計(jì)數(shù)器復(fù)位
- if(firstflag==0) //如果是輸入的第一個(gè)數(shù)據(jù),賦值給a,并把標(biāo)志位置1,到下一個(gè)數(shù)據(jù)輸入時(shí)可以跳轉(zhuǎn)賦值給b
- sscanf(temp,"%f",&a);
- firstflag=1;
- else
- sscanf(temp,"%f",&b);
- for(s=0;s<16;s++) //賦值完成后把緩沖區(qū)清零,防止下次輸入影響結(jié)果
- temp[s]=0;
- LCD_Write_Char(0,1,q);
- if(q!='=') //判斷當(dāng)前符號(hào)位并做相應(yīng)處理
- sign=q; //如果不是等號(hào)記下標(biāo)志位
- else
- firstflag=0; //檢測(cè)到輸入=號(hào),判斷上次讀入的符合
- switch(sign)
- case '+':a=a+b;
- break;
- case '-':a=a-b;
- break;
- case 'x':a=a*b;
- break;
- case '/':a=a/b;
- break;
- default:break;
- sprintf(temp,"%g",a); //輸出浮點(diǎn)型,無(wú)用的0不輸出
- LCD_Write_String(1,1,temp);//顯示到液晶屏
- sign=0;a=b=0; //用完后所有數(shù)據(jù)清零
- for(s=0;s<16;s++)
- temp[s]=0;
- else if(p<16)
- if((1==p)&& (temp[0]=='0') )//如果第一個(gè)字符是0,判讀第二個(gè)字符
- if(q=='.') //如果是小數(shù)點(diǎn)則正常輸入,光標(biāo)位置加1
- temp[1]='.';
- LCD_Write_Char(1,0,q);//輸出數(shù)據(jù)
- p++;
- } //這里沒(méi)有判斷連續(xù)按小數(shù)點(diǎn),如0.0.0
- else
- temp[0]=q; //如果是1-9數(shù)字,說(shuō)明0沒(méi)有用,則直接替換第一位0
- LCD_Write_Char(0,0,q);//輸出數(shù)據(jù)
- else
- temp[p]=q;
- LCD_Write_Char(p,0,q);//輸出數(shù)據(jù)
- p++; //輸入數(shù)值累加
- else if(key2==0)
- PLEN=sizeof(password)/sizeof(password[0]);//用于計(jì)算出實(shí)際密碼長(zhǎng)度
- LCD_Clear(); //清屏
- LCD_Write_String(0,0," Welcome! "); //寫(xiě)入第一行信息,主循環(huán)中不再更改此信息,所以在while之前寫(xiě)入
- LCD_Write_String(0,1,"Input password!");
- //寫(xiě)入第二行信息,提示輸入密碼
- num=KeyPro(); //掃描鍵盤(pán)
- if(num!=0xff) //如果掃描是按鍵有效值則進(jìn)行處理
- if(i==0) //輸入是第一個(gè)字符的時(shí)候需要把改行清空,方便觀看密碼
- LCD_Write_String(0,1," ");//清除該行
- if(i<16)
- passwordtemp[i]=num;
- LCD_Write_Char(i,1,'*');//輸入的密碼用"*"代替
- i++; //輸入數(shù)值累加
- if(('='==num)|| (i==16))//輸入按鍵值15或者密碼輸入到最大值16,表示輸入結(jié)束,需要進(jìn)行比對(duì)
- passwordlength=i-1; //計(jì)算輸入密碼長(zhǎng)度
- i=0; //計(jì)數(shù)器復(fù)位
- if(passwordlength==PLEN)//長(zhǎng)度相等則比較,否則直接輸出錯(cuò)誤
- Flag=1;//先把比較位置1
- for(j=0;j<PLEN;j++)//循環(huán)比較8個(gè)數(shù)值,如果有一個(gè)不等 則最終Flag值為0
- Flag=Flag&&(passwordtemp[j]==password[j]);//比較輸入值和已有密碼
- if(Flag)//如果比較全部相同,標(biāo)志位置1
- LCD_Write_String(0,1,"Right Open!>>>>");//密碼正確顯示的信息
- inputtimes=0;//輸入正確則次數(shù)清零,重新計(jì)數(shù)
- Flag=0; //清除正確標(biāo)志
- else
- LCD_Write_String(0,1,"Wrong! Retry!");//密碼錯(cuò)誤,提示重新輸入
- inputtimes++;//連續(xù)輸入錯(cuò)誤,則次數(shù)累加
- if(inputtimes==3)
- LCD_Write_String(0,1,"Wrong 3 times!");//密碼錯(cuò)誤,提示重新輸入
- while(1);//停止該位置,重啟電源后才能輸入,實(shí)際實(shí)用中則需要等到一定時(shí)間后才能再次輸入。
計(jì)算器.rar
(976.86 KB, 下載次數(shù): 13)
2017-11-21 20:31 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
143-實(shí)用密碼鎖.rar
(57.42 KB, 下載次數(shù): 14)
2017-11-21 18:07 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
