- #include<reg52.h>
- #include <intrins.h>
- #define uint unsigned int
- #define uchar unsigned char
- sbit a1=P1^0;
- sbit a2=P1^1;
- sbit a3=P1^2;
- sbit key=P2^7;
- uchar code table[] = { 0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,
- 0x80,0x90,0x88};//,0x83,0xC6,0xA1,0x86,0x8E,0xFF};
- uchar code dispbit[]={0x01,0x02};//數(shù)碼管位選碼
- uchar dis1[]={0,0};
- uchar num,temp=10;
- uchar t0=0;
- void Delay(uint z)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--)
- void init()
- TMOD=0x01;
- TH0=(65536-50000)/256;
- TL0=(65536-50000)%256;
- EA=1;
- ET0=1;
- TR0=1;
- // temp=0xfb;
- // P1=temp;
- void Display()
- uchar i,x,y;
- dis1[0]=num/10;
- dis1[1]=num%10;
- for(i=0;i<2;i++)
- P0=table[dis1[i]];
- P3=table[dis1[i]];
- P2=dispbit[i];//位選
- Delay(5);
- P2=0x00;
- if(key==1)
- P1=0xf6;
- EA=0;
- for(x=5000;x>0;x--)
- for(y=110;y>0;y--);
- else EA=1;
- void main()
- init();
- num=30;
- while(num!=0)
- loop:Display();
- if(key==1)
- goto loop;
- P1=0xde;
- // Delay(10);
- if(num==5)
- while(num!=0)
- loop2:Display();
- if(key==1)
- goto loop2;
- P1=0xee;
- Delay(10);
- // P1=0xfe;
- // Delay(10);
- num=30;
- while(num!=0)
- loop1:Display();
- if(key==1)
- goto loop1;
- P1=0xf3;
- // Delay(10);
- if( num==5)
- while(num!=0)
- loop3:Display();
- if(key==1)
- goto loop3;
- P1=0xfd;
- Delay(3);
- // P1=0xfb;
- // Delay(3);
- void time0()interrupt 1 using 0
- t0++;
- if(t0==20)
- t0=0;
- num--;
復制代碼 |
